"Jay Honeck" wrote:
I love some of the threads you start, Jay. :-) [snip] As I'm typing this, I'm trying to remember the last time I opened my sectional chart. With a Lowrance 2000c on the pilot's yoke, and a Garmin 496 in the panel, there is literally no reason for us to EVER open a sectional anymore. Both of those instruments have far more information than a chart could ever display -- yet I feel sloppy for not having opened my paper map in the last dozen or so flights. I have a tandem aircraft (Varga), and the partner I fly with most frequently and I each have portable Garmin 296s that we use on every flight. The panel page gives the backseat pilot some instruments he/she can't see on the actual panel, and it's a backup if the actual instruments fail (we're planned to be only VFR). In addition, if ALL GPS/nav equipment fails, I also make specific "nav cards" for every flight designating the headings and altitudes to fly, frequencies along the route, distance/pattern & runway info and alternates; on the back, I make a copy of the sectional with a line showing the route, and then I laminate the whole thing. Most cards are half-page, and I keep them in a half-page size binder in the airplane. Can fit most on ONE half-page, but use one for each leg of longer x-cs. So...we always have the info/sectional backup if the other, more convenient methods of navigation, fail. I make two of each laminated card, so both front- and back-seat pilot have one. This also saves having to write down the same info *every time* you go to frequently chosen destinations, and having to unfold and find the part of the sectional you need *if* you need it. It is especially helpful when you make a longer flight that you haven't done in 2 or 3 years ... instead of trying to remember and argue about what route you flew, you can just pull the cards and see what it was and it's easy to update if need be (most of the time, it's all the same). Sometimes I add info I didn't realize we needed until AFTER we've made the flight or comments we should remember for next time. With two pilots on board, we have a good system to offset any inclination to get too sloppy -- it's called "spouse pressure". For example, if I fly a non-rectangular pattern, I'm sure to hear about it -- and vice versa. But even after 30 years we can't read each other's minds, and -- especially after a long lay-off from flying -- it's easy to develop sloppy thought processes. Piloting requires linear thinking, and much of it is habit developed over time, so it's the first thing to go when you haven't flown much. I'm interested in hearing what you do to combat the human tendency toward sloppiness? Any tricks that you might use, or methods you might employ? We use a system similar to what you describe as "spouse pressure" that we refer to as "backseat piloting" (ala "backseat driving"). Pilot in the backseat is responsible for reading the checklist to the frontseat pilot as he/she calls for various sections of it, double-verifies the steps, keeps a vigilant eye for traffic (I can't begin to say how many times we've commented that without two sets of eyeballs in the cockpit, it would be much more difficult to see-and-avoid *and* fly at the same time, especially with the difficulty understanding the quality of "English" spoken over the radio these days), and occasionally makes suggestions that cause the threat of the backseat intercom to be shut off! Sounds like a lot of work, but being a relatively low-time pilot, making the cards is a way for me to familiarize myself with the details of each flight (I have a home office with all the equipment needed to make the cards, so that makes it easier, too), and then all the info is readily available for re-familiarizing each time. And my higher-time partner has said it's helpful, too, so it works well for us. Shirl |
the cards is a way for me to familiarize myself with the details of each flight (I have a home office with all the equipment needed to make the cards, so that makes it easier, too), and then all the info is readily available for re-familiarizing each time. And my higher-time partner has said it's helpful, too, so it works well for us. I used to do something very similar to this, back in our pre-GPS, pre-two-pilot days. I found my "cheat sheets" to be extremely helpful, especially when flying into unknown or big-city airports. These sheets really help because they eliminate more than a few things to remember. As a new(er) pilot, I remember feeling like I was close to mental overload when flying into complex airspace, and anything you can do to minimize that load is definitely helpful. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
These sheets really help because they eliminate more than a few things to remember. As a new(er) pilot, I remember feeling like I was close to mental overload when flying into complex airspace, and anything you can do to minimize that load is definitely helpful. One of the handiest "cheat sheets" you can find are the terminal procedures, or approach plates. Even if I'm not flying IFR I always bring a set with me. All the information you need to know about an airport is on one piece of paper. |
Piloting | Brandon[_2_] | Piloting | 3 | August 4th 07 10:37 PM |
Now this is piloting... | Gig 601XL Builder | Piloting | 26 | June 9th 06 05:27 PM |
Responsible Piloting | Icebound | Piloting | 2 | May 14th 05 04:18 AM |
GWB's piloting fun.... | David E. Powell | Military Aviation | 27 | May 8th 04 04:05 AM |
Ler's clean up some sloppy terrminology here | Bob | Rotorcraft | 1 | January 16th 04 05:03 AM |
