I recently installed a new Colibri logger and cable set up so that the GPS
	antenna could, in addition to driving my Colibri, also provide GPS data to the IPAQ 3970 with WinPilot 7.0. After three good flights with no problems from the Colibri or the IPAQ I got airborne a fourth time to find a "NO GPS data" messsage on my IPAQ. I thought it would a simple case of just dong a soft reset of the PDA but no joy. Maybe a Comm Port issue so I tried all 8 Comm Ports at 9600 baud but still no GPS data. I then tried a friends IPAQ 3970 with WinPilot 8.0 but again no GPS data. This was looking more like a wiring problem or worse another damaged IPAQ input plug or receptacle. The guy who supplied the Colibri and cable set up was adamnant that the problem would be software related rather than the new cable and logger. He suggested I try a Trial Version of "FlywithCE". Surprise, surprise the IPAQ worked again and I got a good distance and bearing to a local Turnpoint. Winpilot however still fails to find GPS data. The Colibri is sending all of its possible data to the IPAQ so I have no idea what could have gone wrong with my WinPilot. Anyone like to offer a possible cause and/or fix? Peter  |
On Jan 7, 12:42 am, "PC"  wrote:
	I recently installed a new Colibri logger and cable set up so that the GPS antenna could, in addition to driving my Colibri, also provide GPS data to the IPAQ 3970 with WinPilot 7.0. After three good flights with no problems from the Colibri or the IPAQ I got airborne a fourth time to find a "NO GPS data" messsage on my IPAQ. I thought it would a simple case of just dong a soft reset of the PDA but no joy. Maybe a Comm Port issue so I tried all 8 Comm Ports at 9600 baud but still no GPS data. I then tried a friends IPAQ 3970 with WinPilot 8.0 but again no GPS data. This was looking more like a wiring problem or worse another damaged IPAQ input plug or receptacle. The guy who supplied the Colibri and cable set up was adamnant that the problem would be software related rather than the new cable and logger. He suggested I try a Trial Version of "FlywithCE". Surprise, surprise the IPAQ worked again and I got a good distance and bearing to a local Turnpoint. Winpilot however still fails to find GPS data. The Colibri is sending all of its possible data to the IPAQ so I have no idea what could have gone wrong with my WinPilot. Anyone like to offer a possible cause and/or fix? Peter Is this pro or advanced? Are you feeding it through a vario like a Borgelt, LX or Cambridge. 1st. Never run more than 4800 baud for Colibri and Ipaqs. 2nd. Downlaod WinPilotTTy and run that. Look at the data file and see if everything is coming through in the correct order. 3rd. Turn off the LXWP data stream from the Colibri. Mine caused an error in the TAS and therefore the Winds aloft. 4th. Make sure your WinPilot Password is in and correct (It will need to be the Ipaq Specific version to turn off the LXWP stream anyway). I am assuming you have all ready completely removed the software and reinstalled it fresh. If not start there. I spent nearly a year to solve mine with the Colibri, B50 and Ipaq. I had good support from Borgelt, WinPilot and Craggy Aero. Tim  |
Hi Peter,
	Colibris default to 19,200 Baud. GPS software expects the GPS data at 4800 baud (the NMEA standard). I recommend changing the baud rate in the Colibri and PDA to 4800 baud. There are a few other settings in the Colibri that need to be set for sending WinPilot data out. They are not the default settings in the Colibri. They are detailed in the back of my Colibri Tips document which is available near the top of the LX page he http://www.cumulus-soaring.com/lx.htm Good Soaring, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com "PC" wrote in message ... I recently installed a new Colibri logger and cable set up so that the GPS antenna could, in addition to driving my Colibri, also provide GPS data to the IPAQ 3970 with WinPilot 7.0. After three good flights with no problems from the Colibri or the IPAQ I got airborne a fourth time to find a "NO GPS data" messsage on my IPAQ. I thought it would a simple case of just dong a soft reset of the PDA but no joy. Maybe a Comm Port issue so I tried all 8 Comm Ports at 9600 baud but still no GPS data. I then tried a friends IPAQ 3970 with WinPilot 8.0 but again no GPS data. This was looking more like a wiring problem or worse another damaged IPAQ input plug or receptacle. The guy who supplied the Colibri and cable set up was adamnant that the problem would be software related rather than the new cable and logger. He suggested I try a Trial Version of "FlywithCE". Surprise, surprise the IPAQ worked again and I got a good distance and bearing to a local Turnpoint. Winpilot however still fails to find GPS data. The Colibri is sending all of its possible data to the IPAQ so I have no idea what could have gone wrong with my WinPilot. Anyone like to offer a possible cause and/or fix? Peter  |
I managed to resolve this problem by returning IPAQ to factory settings and
	reinstalling all software and files. Everything working correctly now. BTW to reset your IPAQ to factory settings - hold in the two outer buttons below the screen, hold in the soft reset button below unit and hold in the power button until screen goes dim. An extra hand would be be good. Then do another soft reset and you are back to square one. I hope this helps anyone else that this might happen to. Not the sort of problem you would want in the middle of a gliding contest. Might have to, heaven forbid, learn to read the maps again. Shudder. PC "PC" wrote in message ... I recently installed a new Colibri logger and cable set up so that the GPS antenna could, in addition to driving my Colibri, also provide GPS data to the IPAQ 3970 with WinPilot 7.0. After three good flights with no problems from the Colibri or the IPAQ I got airborne a fourth time to find a "NO GPS data" messsage on my IPAQ. I thought it would a simple case of just dong a soft reset of the PDA but no joy. Maybe a Comm Port issue so I tried all 8 Comm Ports at 9600 baud but still no GPS data. I then tried a friends IPAQ 3970 with WinPilot 8.0 but again no GPS data. This was looking more like a wiring problem or worse another damaged IPAQ input plug or receptacle. The guy who supplied the Colibri and cable set up was adamnant that the problem would be software related rather than the new cable and logger. He suggested I try a Trial Version of "FlywithCE". Surprise, surprise the IPAQ worked again and I got a good distance and bearing to a local Turnpoint. Winpilot however still fails to find GPS data. The Colibri is sending all of its possible data to the IPAQ so I have no idea what could have gone wrong with my WinPilot. Anyone like to offer a possible cause and/or fix? Peter  |
| Thread Tools | |
| Display Modes | |
| Winpilot | NGC | Soaring | 3 | November 22nd 07 07:00 AM |
| Winpilot and OLC | P. Corbett | Soaring | 3 | March 26th 06 11:54 PM |
| WinPilot and OLC | Doug LS4 | Soaring | 2 | December 15th 05 01:45 PM |
| WinPilot Offers Free WinPilot XP for your Desktop Computer | Richard Pfiffner | Soaring | 0 | November 8th 03 05:44 PM |
| Problem: Ground Speed Estimate with Volkslogger and WinPilot | RamyYanetz | Soaring | 3 | August 26th 03 04:06 PM |
