On Jan 27, 7:37 am, nimbusgb wrote:
On 26 Jan, 18:20, wrote: If you can stand the size and poor gas milage, it's hard to go wrong with a pickup or commercial van with a solid axle and a factory tow package, BTW My suggestions/opinions only; your milage may vary. Ray Warshaw 1LK I'm hoping for a solution to trailer sway in the Acura MDX that I am waiting for delivery next week. The MDX has a Trailer Stability Assist program included in the Vehicle Stability Assist system. Of course, TSA doesn't fix whatever is causing the sway in the first place but at least it should eliminate the effects. I've tried various solutions on my trailer and the one with the greatest positive effect was inflating the tires to max rated pressure. I think the fundamental problem on my trailer is the wimpy torsion bar suspension. Steve If you have an airfoil shaped fin box on the trailer try fitting a 'spoiler strip' to either side of the finbox! I had a ventus B Turbo in a Komet II trailer that used to quietly dance behind what was normally a perfect tow vehicle. The sway was usually kicked off by a passing car or when overtaking a big rig or bus on the motorway. Taping 2 25 mm aluminium right angles about 1m long, vertically about 100mm behind the leading edge of the fin box killed the horizontal lift on the box and transformed the handling. I often got some very strange looks from other club members about it but I swear it worked a treat. I'll second your comment. I have a Komet trailer with a symmetrical airfoil tailfin. Gusts from passing large trucks would cause it to sway. I think the curling air caused just the right angle of attack, and an ugly harmonic say until out of the wake of the truck. I also added the right angle aluminum bars just as you described. These spoilers really added 5-15mph more safe speed to the trailer, very dramatic change. As far as mechanical side sway [not the aerodynamic type] changing to stiff sidewall tires "V-rated" and keeping them inflated solved the issue for me. Factory tires/ones you get when you buy a car can be terrible. Instead of 32psi I keep the front tires inflated to 35psi and the rears at 40psi. Also helps gas mileage. Chris |
On Jan 27, 7:12 am, chris wrote:
On Jan 27, 7:37 am, nimbusgb wrote: On 26 Jan, 18:20, wrote: If you can stand the size and poor gas milage, it's hard to go wrong with a pickup or commercial van with a solid axle and a factory tow package, BTW My suggestions/opinions only; your milage may vary. Ray Warshaw 1LK I'm hoping for a solution to trailer sway in the Acura MDX that I am waiting for delivery next week. The MDX has a Trailer Stability Assist program included in the Vehicle Stability Assist system. Of course, TSA doesn't fix whatever is causing the sway in the first place but at least it should eliminate the effects. I've tried various solutions on my trailer and the one with the greatest positive effect was inflating the tires to max rated pressure. I think the fundamental problem on my trailer is the wimpy torsion bar suspension. Steve If you have an airfoil shaped fin box on the trailer try fitting a 'spoiler strip' to either side of the finbox! I had a ventus B Turbo in a Komet II trailer that used to quietly dance behind what was normally a perfect tow vehicle. The sway was usually kicked off by a passing car or when overtaking a big rig or bus on the motorway. Taping 2 25 mm aluminium right angles about 1m long, vertically about 100mm behind the leading edge of the fin box killed the horizontal lift on the box and transformed the handling. I often got some very strange looks from other club members about it but I swear it worked a treat. I'll second your comment. I have a Komet trailer with a symmetrical airfoil tailfin. Gusts from passing large trucks would cause it to sway. I think the curling air caused just the right angle of attack, and an ugly harmonic say until out of the wake of the truck. I also added the right angle aluminum bars just as you described. These spoilers really added 5-15mph more safe speed to the trailer, very dramatic change. As far as mechanical side sway [not the aerodynamic type] changing to stiff sidewall tires "V-rated" and keeping them inflated solved the issue for me. Factory tires/ones you get when you buy a car can be terrible. Instead of 32psi I keep the front tires inflated to 35psi and the rears at 40psi. Also helps gas mileage. Chris I've heard about the spoiler fix but never tried it. I was told to put the spoilers at the trailing edge of the fin. I also talked to a Komet factory rep at an SSA Convention a few years back and he told me the cause of sway was absolutely not aerodynamic! Steve |
I did almost the same with my LAK trailer but used pop rivits and
sealer when I was towing with a Chevy Blazer. Without them, the rig was dicy over 60 mph; after they were added it was rock-steady at Arizona highway speeds (75 mph). The P/U I replaced the Blazer with probably wouldn't have needed them, though. Ray Warshaw 1LK I had a ventus B Turbo in a Komet II trailer that used to quietly dance behind what was normally a perfect tow vehicle. The sway was usually kicked off by a passing car or when overtaking a big rig or bus on the motorway. Taping 2 25 mm aluminium right angles about 1m long, vertically about 100mm behind the leading edge of the fin box killed the horizontal lift on the box and transformed the handling. I often got some very strange looks from other club members about it but I swear it worked a treat. |
nimbusgb wrote:
If you have an airfoil shaped fin box on the trailer try fitting a 'spoiler strip' to either side of the finbox! I had a ventus B Turbo in a Komet II trailer that used to quietly dance behind what was normally a perfect tow vehicle. The sway was usually kicked off by a passing car or when overtaking a big rig or bus on the motorway. Taping 2 25 mm aluminium right angles about 1m long, vertically about 100mm behind the leading edge of the fin box killed the horizontal lift on the box and transformed the handling. I often got some very strange looks from other club members about it but I swear it worked a treat. Do you have any photos of this installation? I'm wondering if it'll help settle down my Komet. Jeremy |
Jeremy Zawodny wrote:
Do you have any photos of this installation? I'm wondering if it'll help settle down my Komet. Try it! Use some scrap 25mm (1") square scrap wood, steel tubing, etc. Anything that presents a 25mm flat surface at right angles to the fin box skin will do. Put it on temporarily with Gaffer, Duct or even parcel tape. Do a short tow. Try moving the strips to sere what works best. If/when it works well enough, spend the time and money to get 25 mm alloy angle strip and attach it properly. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Do you have any photos of this installation? I'm wondering if it'll help settle down my Komet. Jeremy All my photos are of the gliders not the trailer ! ![]() I taped a couple of pieces piece of angle, parallel to the leading edge of the finbox, 4 inches or so behind the L/E and about 75% of the height of the fin box. I pop-riveted them on once I was convinced it all worked. I'll sketch something if you want and mail it |
At 17:48 27 January 2008, Nimbusgb wrote:
Have you noticed how the boxes on new trailers are now square ![]() If we're talking Cobra, isn't it just metal top - square, grp top - curvy? |
On 27 Jan, 19:20, John Galloway wrote:
At 17:48 27 January 2008, Nimbusgb wrote: Have you noticed how the boxes on new trailers are now square ![]() If we're talking Cobra, isn't it just metal top - square, grp top - curvy? The latest square finbox I saw was on a GRP top. |
On Jan 31, 12:15*am, nimbusgb wrote:
On 27 Jan, 19:20, John Galloway wrote: At 17:48 27 January 2008, Nimbusgb wrote: Have you noticed how the boxes on new trailers are now square ![]() If we're talking Cobra, isn't it just metal top - square, grp top - curvy? The latest square finbox I saw was on a GRP top. I have a trailer that happily tows at 80mph and has behind a number of tow vehicles. I am currently towing with a short wheelbase Volvo SUV. This trailer is uniquely low, but seems to self damp when a semi passes or the wind gusts and has an aerodynamic fin. I have always suspected it has something to do with the fin to trailer wheel moment vs trailer wheel to hitch moment. I have never had to play with weights etc. The wheel placement is different than the Cobras which seem to be more centered. Picture at http://www.illunis.com/Files/trailer.jpg Scott |
| Tow vehicle -- electronic stability control | Greg Arnold | Soaring | 4 | June 8th 06 01:31 PM |
| Atmospheric stability and lapse rate | Andrew Sarangan | Piloting | 39 | February 11th 05 06:34 AM |
| Roll Stability in lifting body and flying wing aircraft | Fred the Red Shirt | Home Built | 2 | December 3rd 04 11:24 PM |
| U.S. Air Force Moves Ahead With Studies On Air-Breathing Engines | Otis Willie | Military Aviation | 0 | October 29th 03 04:31 AM |
| Air Force office studies aging aircraft | Otis Willie | Military Aviation | 2 | August 30th 03 07:05 PM |
