Tow vehicle -- electronic stability control
Old June 6th 06, 06:13 PM posted to rec.aviation.soaring
Default Tow vehicle -- electronic stability control
My understanding is that electronic stability control is a device that
selectively applies individual brakes in an attempt to prevent oversteer
and understeer. Does anyone know whether this reduces the swaying of a
tow vehicle, or maybe even increases swaying if the device reacts too
slowly?
Old June 6th 06, 07:43 PM posted to rec.aviation.soaring
This is different, but related to your subject. I found that if I was
looking in the rear view mirror at the tail of the glider trailer that I
could actively damp out trailer sway by gentle steering inputs that were
opposite the perceived tail direction in the rear view.
If, looking at the image in the rear view, the tail was going left to
right, then I applied a left steering input and vice versa. This seemed
to help quite a bit when the occasional gust would get things moving.
Experiment with care...it was very tempting initially to steer "with"
the tail and took some focus to time the inputs in the opposite direction.
slowly?
Old June 6th 06, 10:44 PM posted to rec.aviation.soaring
"Greg Arnold" wrote in message
news:8Rhhg.11367$KB.7672@fed1read08...
slowly?
I don't mean to sound like a smartass (for a change), but what does the
owners manual say?
If the stability control is going to cause problems when towing a trailer,
it makes sense that the manual would suggest turning it off, eh?
I did find a manual that suggested that you turn off the stability control
when you have chains on the tires, but nothing about trailer towing.
Geoff
Old June 8th 06, 04:18 AM posted to rec.aviation.soaring
If an "occasional gust would get things moving", I think you are driving
too fast. Oscillations that last long enough to damp out the way you
describe indicate you are close, maybe very close, to diverging
oscillations. It might take only a larger gust (or a couple in row),
tires that are a few pounds low (trailer or tow vehicle), or a sharp
avoidance maneuver, and suddenly you are a passenger.
www.motorglider.org - Download "A Guide to Self-launching Sailplane
Operation"
Old June 8th 06, 01:31 PM posted to rec.aviation.soaring
I'm not talking about white-knuckle trailer oscillations (I've been
there) but just some gentle swaying back and forth passing an 18
wheeler, etc. It was just something I elected to tinker with since the
trailer swaying subject seems to be a regular subject. But it might be
handy to know if something like this would work for the occasion where
things got a little hairy.
I could actively damp out trailer sway by gentle steering inputs that
were opposite the perceived tail direction in the rear view.
seemed to help quite a bit when the occasional gust would get things
moving. Experiment with care...it was very tempting initially to steer
"with" the tail and took some focus to time the inputs in the opposite
direction.
UAV's and TFR's along the Mexico boarder John Doe Piloting 145 March 31st 06 07:58 PM
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 01:56 AM
Who's At Fault in UAV/Part91 MAC? Larry Dighera Instrument Flight Rules 24 April 29th 04 04:08 PM
Control Tower Controversy brewing in the FAA PlanetJ Instrument Flight Rules 168 December 6th 03 02:51 PM
USAF = US Amphetamine Fools RT Military Aviation 104 September 25th 03 04:17 PM
