What glue to use for replacing cockpit interior fabric
Old February 7th 08, 03:19 AM posted to rec.aviation.soaring
Peter[_4_]
Default What glue to use for replacing cockpit interior fabric
I found the old fashioned "DAP" contact cement working the best. I am sure
others are fine as well. The ones to stay away from are the "green",
environmentally friendly labeled adhesives. They don't work worth a crap!
PeterK
On Feb 6, 4:38 am, Gary Emerson wrote:
Greetings,
I've got a SH glider. Have ordered new cockpit interior fabric, and am
ready to glue them in. Old fabric is removed, but there is some
residual glue on the cockpit sides that is pretty well stuck that I'd
prefer not to have to remove.
Asked SH, but got no reply.
One pilot suggested Pliobond, but it has a stronger odor that lingers
after it dries that I'm really not very excited about.
Has anyone used the Weldwood contact cement successfully or is there
another lower odor cement/glue that is recommended???
Many thanks in advance!
Gary
To get the best bond of the new fabric, regardles of what glue you
use, you will need to remove the old residue first. Time, scotchbrite
pads, and 3M General Adhesive Cleaner
http://www.3mestore.com/62478765092.html
Old February 7th 08, 05:37 AM posted to rec.aviation.soaring
Easy....first take off all the residual adhesive with a scotch brite
roloc pad on an air die grinder mandrel. Not very expensive but
effective without worry of hurting the underlying structure.
For adhesive.....3M 1300L. It's like contact cement on steroids,
holds up in the heat, and consequently is what they use to glue
interior fabric, carpet, insulation, plastic, leather...the list goes
on an on.....in everything from Cessna 150's to 747's. You know it's
good if they can use it to glue fabric to aluminum.
All this stuff is available from www.aircraftspruce.com or Brown Tool,
or probably even your local fbo. I think I've seen the roloc
scotchbright pads at the local Checker auto parts store.
Hope that helps.
Replacing Cockpit placards toad Soaring 9 March 28th 06 03:04 PM
Pirep on replacing interior plastic parts [email protected] Owning 1 April 12th 05 05:06 AM
Cobra Interior Carpet Glue Brian Iten Soaring 7 August 24th 04 05:35 AM
Looking for pics of SU-24 Fencer cockpit interior Boomer Naval Aviation 0 March 6th 04 12:43 AM
Looking for pics of SU-24 Fencer cockpit interior Boomer Military Aviation 0 March 6th 04 12:42 AM
