On Feb 26, 7:28*am, Bertie the Bunyip wrote:
WingFlaps wrote : On Feb 26, 7:04*am, Bertie the Bunyip wrote: "gatt" wrote ews.com: In the book "Takeoffs and Landings" by Leighton Collins--who is referenced in "Stick and Rudder"--there is no mention of the term "ground effect." Rather, Collins talks briefly about "ground cushion" and how air "piles up" beneath the wings. Do people still teach this? Wel, it's a rose by any other name sort of thing.. Basicaly what's happening is the air around the wing's pressure is influenced by the ground. You have a high below the wing in flight and it gets higher and influences the way the air flows around the wing keeping it laminar longer . ( slower) I thought it was purely due to a reduction in induced drag. This causes the lift vector to be larger. ??I'm not with you here.. OK, I'll explain myself but I'm sure you know this stuff -you're not trolling me I hope ... The wing produces a force vector that is broken into 2 components lift and drag. The wing tip vortex is a major contributer to the rotation of the wing force vector. Within ~1.5 wingspans the wing tip vortex is suppressed by friction with the ground. This has two effects : a big reduction in drag (so you float a long way in landing as you do not shed energy so fast) and the rotation of the wing force vector towards vertical increases lift. In landing/takeoff configs the high AOA leads to a very backward wing force vector so ground effect increases lift a lot in those configs. This then easily explains a take off stall -as you rotate and climb out of ground effect drag increases and lift decreases. The loss of lift requireds you to further increases AOA which further increases drag. If drag becomes greater than thrust you stall. Cheers |
Phrase "landing runway" vs. "cleared to land" | Robert M. Gary | Piloting | 168 | February 5th 08 05:32 PM |
Phrase "landing runway" vs. "cleared to land" | Robert M. Gary | Instrument Flight Rules | 137 | February 5th 08 05:32 PM |
Can I still get "Bad day for JFK ground Controller"? | [email protected] | Piloting | 8 | October 19th 07 04:52 AM |
V-22 Osprey "ground effect" question | Robert | Naval Aviation | 6 | January 2nd 07 03:44 PM |
Old polish aircraft TS-8 "Bies" ("Bogy") - for sale | >pk | Aviation Marketplace | 0 | October 16th 06 07:48 AM |
