Teaching Incremental Flaps in the Pattern
Old March 4th 08, 05:14 PM posted to rec.aviation.piloting
Default Teaching Incremental Flaps in the Pattern
On Mar 4, 12:07 pm, "Bob Gardner" wrote:
I am reluctant to teach anything that should "always" be used. Flaps are a
tool, and we learn early on in life that there are many ways to use a tool
to achieve different results. If there is a problem with the flap motor in
that specific airplane, why apply the same thinking to all airplanes? Flap
extension is a balance between lift and drag....whether you want more lift
or more drag depends on the situation.
Bottom line: I don't like it.
Bob Gardner
If I came across as "always in every instance" it was unintentional.
As in any art, it's best to start with simple principles, and then add
the exceptions later.
Dan
teaching emergency landings...How low do you go... gatt[_2_] Piloting 18 February 27th 08 09:57 PM
Aerotow - learning and teaching [email protected] Soaring 11 September 12th 05 09:53 PM
Teaching the aerotow Paul Moggach Soaring 5 September 12th 05 03:31 AM
Ground launch and the incremental vanishing of soaring Mark James Boyd Soaring 24 March 8th 04 10:50 PM
Teaching airworthiness Roger Long Piloting 28 October 2nd 03 09:08 PM
