Turn to Final - Keeping Ball Centered
Old March 13th 08, 02:14 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Default Turn to Final - Keeping Ball Centered
Dudley Henriques wrote in
Roger wrote:
On Wed, 12 Mar 2008 10:52:38 -0800, Jim Stewart
Ken S. Tucker wrote:
On Mar 12, 3:39 am, Dan wrote:
On Mar 12, 2:18 am, "Ken S. Tucker" wrote:
-- IGNORE BELOW -- Depends on the A/C, what were you flying?
In an F-4 doing a 3-4g bank is easy, but in
a trainer I'd suggest 2g max.
Ken
-- IGNORE ABOVE ---
Assuming you're not flying an F-4 in a sim, we'll move on to
reality....
This fear is (correctly) pounded into every aspiring/training
pilot -- don't cross control stall on turn to final!
A pilot is trained to do 2g coordinated turns,
even in twink flying, gee I wonder why.
It's a perfectly safe thing to do and IIRC was
Perfectly safe if not close to the ground and the pilot is
proficient
ant not just current.
a requirement for a pilot's license.
Are you just making this stuff up as you go along?
The Practical Test Standard requires the
demonstration of a steep turn at 45 degree
bank and a safe or recommended airspeed.
That's as steep and high g as it gets and it's
not going to be 2g in my plane.
2Gg turns are fun nor are they hazardous when not done close to the
ground. When I took Bo specific training the instructor started
talking me into a steep turn. I asked if it was OK to just roll into
it and go. I He said "OK", so I just rolled left and pulled. Coming
up on the proper heading he said now lets do one the other direction
where by I rolled to the right and pulled. This brought a laughing
comment, "You really like to do these things don't you?" My puzzled
"sure", brought the explanation that most of the Bo pilots would only
grudgingly do 45 degrees let alone 60. You should have heard them
complain when told the instructors would be blocking the yokes so
they couldn't use the ailerons when doing stalls.:-))
I've found few of newer pilots and instructors like 2G at 60 degrees
or the stalling characteristics of the Deb so when I go out to
practice it's only the "old timers" who go along.
When I took the PTS it was 60 degrees and 2Gs. By not going to 60
degrees in steep turns the students miss out on the different banking
tendencies/characteristics. I often think it should be put back to
that. There have been moments where I've been glad they did things
that way back then. One such moment was when a ultra light flying
far later than allowed popped out of the dark directly in front of me
when I was no more than a couple hundred yards (if that) from the end
of the runway. Another was on the VOR approach to MtPleasant where
you fly directly over the runway at 500 feet to the VOR to go missed
on 27. When the instructor's voice went up an octave and he said and
I quote..."What that...Oh, ****! Pull UP, Pull UP! I went full
power, stood the Deb on end and did a push over to level off that
left things floating. He never would tell me how close we came but
from his actions I'd say probably no more than a few feet. BTW I did
all of that under the hood. I mentioned to the CFI that I figured
had it been really close he'd have taken over. He said he figured
that I knew the limits of the plane and would react quicker than he
could even if he could see. He was right though, The urgency (I
couldeven feel him tense sitting next to me) told me that this should
be a maximum effort and not just a climb. Made me glad I use 120 for
approaches instead of 80 or 90 too:-))
Neither of these were things covered in primary training or the PTS.
They took a lot of time and practice getting to know the limits of
the Deb.
www.rogerhalstead.com
I agree. I had to do 60 degree banked turns for my Private as well.
Sheesh. I can't remember what I had to do . I do remember spins, some
hood time and an engine failure on takeoff. I also remember filing and
putting in a cruising altitude of say, 3500 and then being so afraid to
deviate from it I flew underneat an overcast at that alt with my fin in
the clouds..
Bertie
Old March 13th 08, 02:23 PM posted to rec.aviation.piloting
Dudley Henriques[_2_]
Ken
-- IGNORE ABOVE ---
reality....
proficient
the Deb.
the clouds..
Bertie
A lot has changed since those days. If I remember right, the requirement
was for a 60 degree banked turn in both directions entering one from the
other within an altitude parameter either way of 50 feet. Just racking
my memory here but that sounds close.....and this was for the PRIVATE!!
Dudley Henriques
Old March 13th 08, 03:53 PM posted to rec.aviation.piloting
Ken
-- IGNORE ABOVE ---
reality....
proficient
into
direction
only
degrees
banking
to
me
end
where
missed
and
but
did
should
for
PTS.
the Deb.
and
to
in
the clouds..
Bertie
requirement
PRIVATE!!
I really can't remember, but I do remember being surprised when
instructing years later that i learned that many considered 45 deg to be
steep, so I must have learned at 60 degrees as well.
Bertie
Old March 13th 08, 04:35 PM posted to rec.aviation.piloting
Ken
-- IGNORE ABOVE ---
reality....
proficient
into
direction
only
degrees
banking
to
me
end
where
missed
and
but
did
should
for
PTS.
the Deb.
and
to
in
the clouds..
Bertie
requirement
PRIVATE!!
Bertie
I'm sure you did.
The problem with 45 degrees of bank is that it teaches little about
control in steep banked attitudes such as shallowing the bank before
raising the nose in a nose low condition caused by over bank.
I've never liked the 45 degree parameter and have always recommended to
instructors that they teach bank control all the way out to 60 degrees
regardless of the requirement.
This entire movement to make flying more "comfortable" for the masses to
sell airplanes and push aviation by lowering the requirements has been
flawed from the beginning in my opinion.
If I've flown with one pilot I've flown with a hundred who, when put in
a 60 degree banked turn with the nose going down and being told to raise
the nose, pulled instead of
shallowing out the bank first, tightening up the nose low condition.
It's a shame really, and I hate to see it.
Dudley Henriques
Old March 13th 08, 04:55 PM posted to rec.aviation.piloting
flying?
Ken
-- IGNORE ABOVE ---
reality....
proficient
the ground. When I took Bo specific training the instructor
started talking me into a steep turn. I asked if it was OK to
just roll
into
Coming up on the proper heading he said now lets do one the other
direction
laughing comment, "You really like to do these things don't you?"
My puzzled "sure", brought the explanation that most of the Bo
pilots would
only
them complain when told the instructors would be blocking the
yokes so they couldn't use the ailerons when doing stalls.:-))
degrees
banking
to
things that way back then. One such moment was when a ultra
light flying far later than allowed popped out of the dark
me
end
where
missed
and
but
did
figured had it been really close he'd have taken over. He said he
figured that I knew the limits of the plane and would react
quicker than he could even if he could see. He was right though,
The urgency (I couldeven feel him tense sitting next to me) told
me that this
should
for
PTS.
of the Deb.
well.
some hood time and an engine failure on takeoff. I also remember
filing
and
afraid
to
fin
in
the clouds..
Bertie
requirement
racking my memory here but that sounds close.....and this was for
PRIVATE!!
be steep, so I must have learned at 60 degrees as well.
Bertie
I'm sure you did.
Yeah. OK. That makes sense.
to instructors that they teach bank control all the way out to 60
degrees regardless of the requirement.
to sell airplanes and push aviation by lowering the requirements has
been flawed from the beginning in my opinion.
Well, exactly.
in a 60 degree banked turn with the nose going down and being told to
raise the nose, pulled instead of
Hmm. I've never othought of steep turns as this sort of exercise. I've
alwyas looked at them as keeping, rather than a regaining control type
of thing, but I might try this with some of my guys if we ever get the
damned airplane!
You're sort of crossing over into the spiral dive lesson there. Not a
bad thing...
Bertie
Old March 13th 08, 05:28 PM posted to rec.aviation.piloting
flying?
Ken
-- IGNORE ABOVE ---
reality....
proficient
just roll
into
direction
pilots would
only
degrees
banking
to
me
end
where
missed
and
but
did
me that this
should
for
PTS.
of the Deb.
well.
filing
and
afraid
to
fin
in
the clouds..
Bertie
requirement
PRIVATE!!
Bertie
I'm sure you did.
Well, exactly.
damned airplane!
bad thing...
Bertie
Actually you're right on how you view the exercise. It is an exercise in
maintaining control. What happens however, with the average pilot,
especially those not trained in steep turns at around 60 degrees, is
that invariably, pilots trying to maintain that 60 degree bank will
allow the nose to get lower than the horizon line as they attempt to
maintain and control the over bank.
When this happens, the only way to correct and get the nose back
tracking again on the horizon is to shallow out FIRST, then raise the
nose back up where it belongs. Trying to solve the error by pulling the
nose back up without shallowing first just takes the pilot deeper into
the error.
The secondary error that is most common is in not releasing the back
pressure properly then reapplying it again as the turn is reversed.
All in all, 60 degree banked turn to alternating sides is a wonderful
training tool. These turns teach control pressure blending and
coordination better than any other maneuver I've ever used .
If a pilot can enter alternating 720's and perform the turns AND the
transition through the reversal between them within a 50 foot altitude
error parameter, they KNOW control pressure and can FLY the airplane!
A side advantage to learning steep 720's VFR really comes in handy later
on if
a pilot goes into serious instrument training where recovery from nose
low unusual attitudes requires correcting the bank first, then raising
the nose........as I've always maintained and always will...it's the way
you learn the basics that will determine how well you eventually will
fly all through your career in aviation.
Dudley Henriques
Old March 13th 08, 05:47 PM posted to rec.aviation.piloting
Dan Luke[_2_]
"Dudley Henriques" wrote:
When this happens, the only way to correct and get the nose back tracking
again on the horizon is to shallow out FIRST, then raise the nose back up
where it belongs.
I guess a little top rudder is right out, eh?
You're on. That will be the drill for Saturday.
I've done a lot of low/slow/steep flying lately on photo missions. Your
drill should help.
Dan
T-182T at BFM
Old March 13th 08, 07:19 PM posted to rec.aviation.piloting
Ken S. Tucker
Ken
-- IGNORE ABOVE ---
reality....
proficient
the Deb.
the clouds..
Bertie
Dudley Henriques
An instrument that was stressed for me during
instruction was this,
http://en.wikipedia.org/wiki/Attitude_indicator
The 60 degree banked turn (IIRC), did require that
50' +/- altitude, keeping the ball centered, and
maintaining a constant KIAS with some +power.
When that 50' +/- requirement was spec'd by the
instructor I got fixated on the "rate of climb"
indicator.
Well he smirked and sent my concentration to the
attitude indicator and to learn to use that.
Other pilots have mentioned the attitude indicator
is the most important instrument.
What do you guys think?
Ken
Old March 13th 08, 07:42 PM posted to rec.aviation.piloting
instruction was this,http://en.wikipedia.org/wiki/Attitude_indicator
indicator.
Ken
We think it shows you have not had any training. PPL students
are told to LOOK OUTSIDE during steep turn training, not to fixate on
instruments. They need to see what the horizon is up to, not what
instruments are indicating. A glance at the ASI and altimeter every
few seconds is in order, but they're not to refer to the AI constantly
for steep turns. We've had students who were all over the sky, chasing
instrument needles, so we sometimes cover up the whole panel and make
them do it by looking outside; the airplane settles down and behaves
itself. Amazing.
This is standard Canadian PPL curriculum, and the US wouldn't
be much different.
Dan
Old March 13th 08, 08:32 PM posted to rec.aviation.piloting
Ken S. Tucker
Mr. BIG HEAD, you've lost a star and the Mr.
You now just *Big Head*, you make too many
mistakes.
indicator.
Ken
instruments.
Night flying, IFR initiation, in good VFR the OUTSIDE
is peripheral vision, if you ever really flew an airplane.
for steep turns.
How the **** do you set-up to a 60 bank?
and maintain constant altitude?
itself. Amazing.
No that's pure BS.
be much different.
Dan
Dan you don't even know what an Attitude Indicator does,
otherwise you would have opined on my question.
I'll leave *Big Head* Dan with one star, but probationary.
Ken
Implications of.....keeping the speed up [email protected] Instrument Flight Rules 48 January 14th 07 11:41 PM
Gamepad, stopping throttle axis from being auto-centered DenisK Simulators 1 December 20th 06 09:16 AM
Keeping a builders log Lou Home Built 24 January 28th 06 10:46 PM
Thanks for ideas on drilling a centered hole! Scott Home Built 12 October 25th 04 02:52 AM
Keeping Me Out of Your Warbird? Stephen Harding Military Aviation 47 February 12th 04 04:34 PM
