STF question
Old March 16th 08, 02:09 AM posted to rec.aviation.soaring
Default STF question
The fact that the best speed to fly interthermal is independent of the
headwind-tailwind component confused me at first too, and for the same
reason as one of the other posters. If your STF is 50 kts and you have
a 50 kt HW, you'll make no distance. The problem is, flying faster
than 50 kts (assuming it is the value predicted by MacCready's
optimization) will actually blow you backward. Why? You make headway
while flying, but when you stop to tank up before hitting the ground
(an assumption in the MacCready model that is not often explicitly
stated: you can find a thermal with the lift you've dialed in whenever
you want it -- not very realistic!), you are blown backward at 50 kts
due to the tilt of the thermal. Because you flew faster than optimal,
you must tank up longer and are blown back more.
When on final glide, the optimal speed to fly is different and clearly
depends on the wind. It no longer depends on the speed of the "next"
thermal, since there isn't one. It seems like a totally different
optimization to me.
Hope this helps.
Martin
Old March 16th 08, 03:25 PM posted to rec.aviation.soaring
Andy[_1_]
optimization to me.
To determine the "optimum" speed to fly you need to state the
objective. The speed or MC setting to achive max glide distance may
not be the speed or MC setting that gives the shortest time to the
destination.
For best speed there is an interaction between thermal strength and MC
setting even though the final glide does not end with a thermal
climb. The MC setting is based on the strength of the thermal you are
currently using to reach final glide altitude. The combination of
wind, thermal strength, and distance to go, will determine not only
the final glide MC setting but also when to leave the last thermal.
Of course you can forget all that if you practice the start at zero MC
and bump up final glide technique.
Andy
One more question... john smith Aviation Photos 12 October 6th 07 07:32 PM
MRA Question [email protected] Instrument Flight Rules 3 April 16th 06 02:19 PM
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
