Solar charger damages batteies - what's good one?
Old March 25th 08, 06:57 PM posted to rec.aviation.soaring
Eric Greenwell
Default Solar charger damages batteies - what's good one?
I've just discovered the Morningstar Sunsaver 6 charge controller I've
been using with my 20 watt panel is a two stage controller, and does not
have a "float" stage. This appears to have damaged my batteries more in
one year than several batteries I've used for 3 years or more, but were
charged with a good 3 stage AC charger.
Are there recommendations for a more suitable charge controller? When
charging, the controller is placed in the trailer, or in the gear well
if the glider is tied out, so the battery and controller temperatures
are the same.
* Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4
* New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more
Old March 25th 08, 08:18 PM posted to rec.aviation.soaring
are the same.
Aren't the Morningstar Sunkeeper series 3-stage?
Old March 25th 08, 08:22 PM posted to rec.aviation.soaring
Herb
are the same.
* Updated! "Transponders in Sailplanes"http://tinyurl.com/y739x4
* "A Guide to Self-launching Sailplane Operation" atwww.motorglider.org
Eric,
I just bought this item on ebay for a 6 W solar panel that I will use
to tie together a trailer fan and a 5AH NiMH battery. It seems to
work great, keeping the battery charged but allowing the fan to run
day and night.
I tried to copy you the link from ebay but it wouldn't work. Here is
the search term:
Solar Panel Charge Regulator Controller 12V 5A 60W NEW
Herb, J7
Old March 26th 08, 02:31 AM posted to rec.aviation.soaring
Eric Greenwell
Default Solar charger damages batteries - what's good one?
Oops, misspelled batteries, but I fixed it.
Old March 26th 08, 11:27 PM posted to rec.aviation.soaring
The Steca looks interesting. It's got float, leds and fuse holder to
boot. As long as its got a blocking diode then that looks a good one
to go with. Even if not, you can easily add one.
Yes, they are. I don't like the shape, so I'm leaning towards the
Steca-5-c with similar specs and $30 instead of $60. But, I'm still
looking for recommendations and warnings.
Jim Weir's solar charger R. Lee Jarvis Home Built 2 February 17th 07 07:21 PM
12v - 12v charger 5Z Soaring 19 December 30th 05 09:58 PM
Hurricane Wilma Damages Marty from Florida Owning 22 November 2nd 05 01:24 AM
Protestor Damages Enola Gay B2431 Military Aviation 88 December 24th 03 05:24 AM
