B A R R Y wrote:
gliderguynj wrote: On Apr 18, 9:46 am, B A R R Y wrote: Define "bad gas". Gas that makes your engine stop... Fuel mixed with water isn't "bad gas". We drain the water and the fuel left behind is usable. Unless it is Ethanol laced. |
Gig 601Xl Builder wrote:
B A R R Y wrote: gliderguynj wrote: On Apr 18, 9:46 am, B A R R Y wrote: Define "bad gas". Gas that makes your engine stop... Fuel mixed with water isn't "bad gas". We drain the water and the fuel left behind is usable. Unless it is Ethanol laced. That actually depends on how much water is in the fuel. There's a limit, of course, but the engine will still run with some water suspended in the fuel. |
B A R R Y wrote:
Gig 601Xl Builder wrote: B A R R Y wrote: gliderguynj wrote: On Apr 18, 9:46 am, B A R R Y wrote: Define "bad gas". Gas that makes your engine stop... Fuel mixed with water isn't "bad gas". We drain the water and the fuel left behind is usable. Unless it is Ethanol laced. That actually depends on how much water is in the fuel. There's a limit, of course, but the engine will still run with some water suspended in the fuel. And how much Ethanol. |
And how much Ethanol. Agreed. I don't know the answer to this, but I wonder... Would too much ethanol would make the gas smell or feel funny during the sampling? |
B A R R Y wrote:
I don't know the answer to this, but I wonder... Would too much ethanol would make the gas smell or feel funny during the sampling? Nope. Unlike the old (legal for airplanes) oxygenate, MTBE, the presence of ethanol is not obvious by odor or appearance. You just have to mix the fuel with some water and shake it up in order to test it (at least in quantites used for oxygenated car gas). E-85, on the other hand, seems to be detectable by smell. Although pure ethanol has no odor, E-85 has a noticably weaker gasoline component to its odor. John Galban=====N4BQ (PA28-180) -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200804/1 |
On Fri, 18 Apr 2008 21:26:55 GMT, "JGalban via AviationKB.com"
u32749@uwe wrote: B A R R Y wrote: I don't know the answer to this, but I wonder... Would too much ethanol would make the gas smell or feel funny during the sampling? Nope. Unlike the old (legal for airplanes) oxygenate, MTBE, the presence of ethanol is not obvious by odor or appearance. You just have to mix the fuel with some water and shake it up in order to test it (at least in quantites used for oxygenated car gas). E-85, on the other hand, seems to be detectable by smell. Although pure ethanol has no odor, E-85 has a noticably weaker gasoline component to its odor. Thanks! |
check it out | berben2 | Naval Aviation | 0 | January 17th 05 05:20 PM |
check it out! | [email protected] | General Aviation | 0 | November 30th 04 07:07 PM |
Check out this sim! | [email protected] | General Aviation | 1 | November 30th 04 01:16 AM |
Check this out! | [email protected] | Aerobatics | 0 | November 30th 04 12:58 AM |
check it out | berben2 | Naval Aviation | 0 | September 16th 04 01:04 AM |
