Piper single axis autocontrol question.
Old April 20th 08, 12:50 AM posted to rec.aviation.owning
Mike Noel
Default Piper single axis autocontrol question.
My '74 archer developed an intermittent problem where the aileron would have
a 'soft stop' at one end of the control throw. I thought a mechanic might
have left a rag or some such under the floor that moved around and sometimes
prevented full control deflection, so I removed the floorboard under the
back seats. I found instead that the aileron servo pulley had several wraps
of cable and what appears to be a pin stake to keep the cable against the
pulley, presumably to prevent the cable from sliding on the pulley. At one
end of throw the pin stops the cable from unwrapping from the pulley and the
cable bends down, giving the feel of a soft stop.
Anyone familiar with the mechanics of this arrangement? My best guess is
that the cable is actually sliding around the pulley slightly when I help
the autopilot in rough air and sometimes the pin is in a position to allow a
natural hard stop and at other times it stops the aileron short of full
throw.
Best Regards,
Mike
http://photoshow.comcast.net/mikenoel
Old April 21st 08, 05:50 PM posted to rec.aviation.owning
I don't know the pipers well enough to comment specifically,
but this surely shouldn't be happening. it's a safety of flight
issue.
The cable should be constrained so it can't slip on the capstain.
Sometimes this is done with a bead staked on the cable in the
middle of the capstain... it drops down into a small hole in the
capstain. There might be other mechanisms to do this, but there
will be some way to do this.
If the travel isn't well centered, something may collide near the
end in one direction or the other. There usually isn't a lot of
excess travel available; that is they only use enough wraps to
get the job done in the first place.
You may want to loosen the bridle cable clamps and reposition
them slightly so that travel to each end is the same.
The cables should have some tension in them; if they are loose,
the autopilot may oscillate.
bh
a 'soft stop' at one end of the control throw. *I thought a mechanic might
back seats. *I found instead that the aileron servo pulley had several wraps
pulley, presumably to prevent the cable from sliding on the pulley. *At one
Anyone familiar with the mechanics of this arrangement? *My best guess is
throw.
Best Regards,
Mike
Old April 22nd 08, 02:31 AM posted to rec.aviation.owning
Mike Noel
I pulled the rear floorboard again and tried turning the servo capstan with
a wrench on the center shaft nut. I was able to turn the capstan while the
aileron was at the end of its travel, confirming that the cable is able to
slip through the cable stake. Will the fix be inserting a new stake tightly
enough to keep the cable fixed on the capstan, or perhaps replacing the
capstan/cable assembly? Looks like the main trick for the mechanic will be
getting the tension correct on the bridle cable.
Best Regards,
Mike
" wrote in message
issue.
bh
have
sometimes
wraps
a
throw.
Best Regards,
Mike
Old May 20th 08, 09:12 PM posted to rec.aviation.owning
a wrench on the center shaft nut. *I was able to turn the capstan while the
slip through the cable stake. *Will the fix be inserting a new stake tightly
capstan/cable assembly? *Looks like the main trick for the mechanic will be
Buy turning with a wrench, you might not be getting the answer you
think.
Generally there will be a safety clutch between the shaft of the motor
and the
capstan. So if you turn the shaft and the ailerons have hit their
stop, you will
be slipping the clutch.
So you need to see if the cables move relative to the capstan.
Bill Hle
Old May 20th 08, 10:06 PM posted to rec.aviation.owning
Mike Noel
Bill, in this case I could see the capstan slipping under the cable.
Evidently the cable could slip on the capstan easier than the capstan could
slip on the clutch.
Best Regards,
Mike
" wrote in message
with
tightly
think.
and the
stop, you will
Bill Hle
Old April 21st 08, 08:56 PM posted to rec.aviation.owning
John Kunkel
"Mike Noel" wrote in message
have a 'soft stop' at one end of the control throw.
a natural hard stop and at other times it stops the aileron short of full
throw.
The cables don't stop the aileron travel, there are adjustable hard stops
near the bellcrank in each wing.
A Service ceiling question (Piper 235) falcon Piloting 0 December 6th 04 10:28 PM
Piper PA-28 question GE Owning 14 September 21st 04 12:02 AM
A/D Question for Piper Cherokees zatatime Owning 6 June 11th 04 01:43 AM
Piper Autocontrol IIIB PaulaJay1 Owning 8 January 16th 04 09:43 PM
Autocontrol IIIB PaulaJay1 Owning 13 October 24th 03 02:39 PM
