#11
"Peter Gottlieb" wrote in message . net...
"Kevin Brooks" wrote in message om... True, but which would you choose--an aircraft that remains within the primary engagement envelope of *most* of the threat AAW systems throughout the entire (slow) flight profile, or one that can operate above it if necessary and flies substantially faster to boot? I just hope they make it robust enough. Let them prove me wrong, but so far I don't have a good feeling about how complex it is. The CH-46 is complex. The CH-47 is complex. Even the UH-60 is rather complex. Heck, all modern multi-engine helos are complex, as are most of the single engine new aircraft. If by robust you mean bulletproof--no, it will not acheive that, but neither will any other airframe. But I believe its survivability will be enhanced by its ability to fly faster/higher, and I would guess that its climb rate will be another survivability advantage versus a lot of AAW threats. Brooks |
The composite body is hell for stout. The surviving AC at the Marana AZ crash hit the ground at more than 600 ft/min vertical speed. No damage. Dana, that airframe is now a maintanance trainer. It was so badly damaged it was not repairable...AL |
| Thread Tools | |
| Display Modes | |
| Navy special operations command version of the V-22 Osprey tilt-rotor aircraft | Larry Dighera | Military Aviation | 25 | September 30th 03 02:05 AM |
| Squadron formed to test Osprey for combat readiness | Otis Willie | Military Aviation | 0 | August 30th 03 08:33 PM |
| Osprey vs. Harrier | Stephen D. Poe | Military Aviation | 58 | August 18th 03 04:17 PM |
| "Target for Today" & "Thunderbolt" WWII Double Feature at Zeno'sDrive-In | Zeno | Aerobatics | 0 | August 2nd 03 08:31 PM |
| "Target for Today" & "Thunderbolt": An Awesome WWII DoubleFeature at Zeno's Drive-In | zeno | Military Aviation | 0 | July 14th 03 08:31 PM |
