On May 16, 9:55 am, gatt wrote:
Mxsmanic wrote: In a small GA aircraft, in which phases of flight will you normally use mostly trim to adjust pitch, and in which phases will you normally mostly use the yoke? Good question for r.a.s. You don't want to use the trim to adjust pitch, just to relieve the control pressure. Electronic trim switches mounted to the yoke are a bad habit waiting to happen; they're disabled in a lot of training aircraft. Always remember "Pitch, power, trim." The Airplane Flying Handbook, FAA-H-8083-3A, states: "The pilot must avoid using the trim to establish or correct airplane attitude. The airplane attitude must be established and held first, then control pressures trimmed out so that the airplane will maintain the desired attitude in 'hands off' flight. Attempting to 'fly the airplane with trim tabs' is a common fault in basic flying technique even among experienced pilots." It's important for the pilot to feel the elevator pressure whereas with a trim tab you're delegating that to mechanical authority. Also, if you get out of the habit of knowing where your trim is set, you increase the likelihood of approaching an elevator trim stall in a missed approach or go-around. This can be demonstrated pretty well in MSFS2004--I think in the Mooney--by adjusting the elevator trim as if you were in full-flaps landing configuration and then adding full power; back-elevator trim will cause a radical nose-up pitch, exceeding the critical angle of attack. To avoid elevator trim stall the pilot must exert a great deal of forward pressure on the nose -and- retrim the airplane, and it has to be brisk and smooth. Whether by hand or electric motor, controlling it by trim is too slow. -c Quick question, (it's been awhile since I've piloted) is the trim (Cessna 152) in the center, right of the pilot, and has zero mark to be set null in pre-flight? Personally I had real friggin hassle with trim. I'd get to 4000' set a course for x-country, maybe an hour away, set cruise, then touch-up trim, to relieve yoke control. Well it never really worked for me. As soon as I thought I had it right, by Descent Indicator (no jokes guys, women of the opposite sex might be lurkin) would start wandering off zero. My habit became, set Trim slightly down and use my pinky pressure back on the yoke to keep my Descent Indicator at zero, with an occasional glance so I could enjoy the view and work nav. Ken PS: Kens Rule: Use your pinky to stop being InDescent, and use the rest of your fingers anyway you want. |
On May 17, 5:51*am, "Ken S. Tucker" wrote:
On May 16, 9:55 am, gatt wrote: Mxsmanic wrote: In a small GA aircraft, in which phases of flight will you normally use mostly trim to adjust pitch, and in which phases will you normally mostly use the yoke? Good question for r.a.s. You don't want to use the trim to adjust pitch, just to relieve the control pressure. *Electronic trim switches mounted to the yoke are a bad habit waiting to happen; they're disabled in a lot of training aircraft. *Always remember "Pitch, power, trim." The Airplane Flying Handbook, FAA-H-8083-3A, states: "The pilot must avoid using the trim to establish or correct airplane attitude. The airplane attitude must be established and held first, then control pressures trimmed out so that the airplane will maintain the desired attitude in 'hands off' flight. Attempting to 'fly the airplane with trim tabs' is a common fault in basic flying technique even among experienced pilots." It's important for the pilot to feel the elevator pressure whereas with a trim tab you're delegating that to mechanical authority. Also, if you get out of the habit of knowing where your trim is set, you increase the likelihood of approaching an elevator trim stall in a missed approach or go-around. *This can be demonstrated pretty well in MSFS2004--I think in the Mooney--by adjusting the elevator trim as if you were in full-flaps landing configuration and then adding full power; back-elevator trim will cause a radical nose-up pitch, exceeding the critical angle of attack. *To avoid elevator trim stall the pilot must exert a great deal of forward pressure on the nose -and- retrim the airplane, and it has to be brisk and smooth. *Whether by hand or electric motor, controlling it by trim is too slow. -c Quick question, (it's been awhile since I've piloted) is the trim (Cessna 152) *in the center, right of the pilot, and has zero mark to be set null in pre-flight? It's also around the windows and other edges. Hope this helps your understading what you are seeing on your computer screen. Cheers |
Ken S. Tucker wrote:
Quick question, (it's been awhile since I've piloted) is the trim (Cessna 152) in the center, right of the pilot, and has zero mark to be set null in pre-flight? Correct. (Well it has a "takeoff position" which is more or less center.) In the '74 PA-28R I rent it's between the seats and harder to see, and takeoff position is about "a quarter-inch back" on the slot since there's no visible mark. I don't like the trim-wheel there. The first time I flew in the right seat and reached for the trim handle I cracked my knuckle against the door. -c |
On May 16, 12:19 pm, gatt wrote:
Ken S. Tucker wrote: Quick question, (it's been awhile since I've piloted) is the trim (Cessna 152) in the center, right of the pilot, and has zero mark to be set null in pre-flight? Correct. (Well it has a "takeoff position" which is more or less center.) In the '74 PA-28R I rent it's between the seats and harder to see, and takeoff position is about "a quarter-inch back" on the slot since there's no visible mark. I don't like the trim-wheel there. The first time I flew in the right seat and reached for the trim handle I cracked my knuckle against the door. Ok thanks. I was ok with the location of the trim wheel, but the adjustment was too coarse for me, but I could be a bitchy sissy. My wheel was graduated, with a zero mark and did not quite give the fine adjustment I wanted. That could be cables out to the tail, I should have learned the mechanism! Regards Ken |
"Ken S. Tucker" wrote in
: On May 16, 12:19 pm, gatt wrote: Ken S. Tucker wrote: Quick question, (it's been awhile since I've piloted) is the trim (Cessna 152) in the center, right of the pilot, and has zero mark to be set null in pre-flight? Correct. (Well it has a "takeoff position" which is more or less center.) In the '74 PA-28R I rent it's between the seats and harder to see, and takeoff position is about "a quarter-inch back" on the slot since there's no visible mark. I don't like the trim-wheel there. The first time I flew in the right seat and reached for the trim handle I cracked my knuckle against the door. Ok thanks. I was ok with the location of the trim wheel, but the adjustment was too coarse for me, but I could be a bitchy sissy. My wheel was graduated, with a zero mark and did not quite give the fine adjustment I wanted. That could be cables out to the tail, I should have learned the mechanism! Good grief, he's criticising design now. Bertie |
On May 16, 1:49 pm, "Ken S. Tucker" wrote:
I was ok with the location of the trim wheel, but the adjustment was too coarse for me, but I could be a bitchy sissy. My wheel was graduated, with a zero mark and did not quite give the fine adjustment I wanted. That could be cables out to the tail, I should have learned the mechanism! Nothing to do with the cables. Cessna's trim is anything but sensitive, having four or five full turns of the wheel for the trim range. Try a Citabria sometime, where the trim is a lever that moves about eight or ten inches for the full range. Much more twitchy. As far as others have asked about sim trim, the good, commercial training sims (Level II) have a pitch control mechanism centered by some strong springs that supposedly simulate elevator pressures. The anchor points for those springs are movable, and those are what the trim mechanism moves. So in slow flight the yoke is well back, against the springs, so that the trim moves the spring anchors back until the pressure disappears. The yoke does not move and the pilot, if he's "flying" right, doesn't let it move. He just trims off the pressure. Mx's stick, on the other hand, trims electronically so that he has to gradually center the stick to keep the nose where it's supposed to be. Not realistic at all. And the springs in those cheap things are so feeble as to be a joke. Flying the real airplane is much more work. If you had realistic spring forces you'd have to bolt the stick to the desk and anchor the chair to the floor. I built our own procedures sim here. Proper frame welded up, proper adjustable seat, huge monitor, real rudder pedals with realistic spring feel, real stick with a heavy non-discrete center spring and an adjustable anchor to simulate a reaslistic trim. Real steel throttle/prop/mixture quadrant. Robbed the electronics out of the CH stick and pedals to drive it. But still, it's used only as a procedures trainer, not for teaching how to fly. The students use it for free to practice what they learned on our certified Elite sim or in the air under the hood. It's much more work to fly it, thanks to the big springs I put in it. I need to redesign the mechanical trim to get more travel, though. Underestimated the degree of elevator movement between high cruise and slow flight. And it has a collective for helicopter flight. Dan |
On May 27, 7:42 am, wrote:
On May 16, 1:49 pm, "Ken S. Tucker" wrote: I was ok with the location of the trim wheel, but the adjustment was too coarse for me, but I could be a bitchy sissy. My wheel was graduated, with a zero mark and did not quite give the fine adjustment I wanted. That could be cables out to the tail, I should have learned the mechanism! Nothing to do with the cables. Cessna's trim is anything but sensitive, having four or five full turns of the wheel for the trim range. Try a Citabria sometime, where the trim is a lever that moves about eight or ten inches for the full range. Much more twitchy. As far as others have asked about sim trim, the good, commercial training sims (Level II) have a pitch control mechanism centered by some strong springs that supposedly simulate elevator pressures. The anchor points for those springs are movable, and those are what the trim mechanism moves. So in slow flight the yoke is well back, against the springs, so that the trim moves the spring anchors back until the pressure disappears. The yoke does not move and the pilot, if he's "flying" right, doesn't let it move. He just trims off the pressure. Mx's stick, on the other hand, trims electronically so that he has to gradually center the stick to keep the nose where it's supposed to be. Not realistic at all. And the springs in those cheap things are so feeble as to be a joke. Flying the real airplane is much more work. If you had realistic spring forces you'd have to bolt the stick to the desk and anchor the chair to the floor. I built our own procedures sim here. Proper frame welded up, proper adjustable seat, huge monitor, real rudder pedals with realistic spring feel, real stick with a heavy non-discrete center spring and an adjustable anchor to simulate a reaslistic trim. Real steel throttle/prop/mixture quadrant. Robbed the electronics out of the CH stick and pedals to drive it. But still, it's used only as a procedures trainer, not for teaching how to fly. The students use it for free to practice what they learned on our certified Elite sim or in the air under the hood. It's much more work to fly it, thanks to the big springs I put in it. I need to redesign the mechanical trim to get more travel, though. Underestimated the degree of elevator movement between high cruise and slow flight. And it has a collective for helicopter flight. Dan IIRC you (Dan) are in Sask, I'm just over the hills in BC. If we're ever going by your place I'd love to try that sim, how much do you charge? Ken |
On May 27, 10:10 pm, "Ken S. Tucker" wrote:
On May 27, 7:42 am, wrote: On May 16, 1:49 pm, "Ken S. Tucker" wrote: I was ok with the location of the trim wheel, but the adjustment was too coarse for me, but I could be a bitchy sissy. My wheel was graduated, with a zero mark and did not quite give the fine adjustment I wanted. That could be cables out to the tail, I should have learned the mechanism! Nothing to do with the cables. Cessna's trim is anything but sensitive, having four or five full turns of the wheel for the trim range. Try a Citabria sometime, where the trim is a lever that moves about eight or ten inches for the full range. Much more twitchy. As far as others have asked about sim trim, the good, commercial training sims (Level II) have a pitch control mechanism centered by some strong springs that supposedly simulate elevator pressures. The anchor points for those springs are movable, and those are what the trim mechanism moves. So in slow flight the yoke is well back, against the springs, so that the trim moves the spring anchors back until the pressure disappears. The yoke does not move and the pilot, if he's "flying" right, doesn't let it move. He just trims off the pressure. Mx's stick, on the other hand, trims electronically so that he has to gradually center the stick to keep the nose where it's supposed to be. Not realistic at all. And the springs in those cheap things are so feeble as to be a joke. Flying the real airplane is much more work. If you had realistic spring forces you'd have to bolt the stick to the desk and anchor the chair to the floor. I built our own procedures sim here. Proper frame welded up, proper adjustable seat, huge monitor, real rudder pedals with realistic spring feel, real stick with a heavy non-discrete center spring and an adjustable anchor to simulate a reaslistic trim. Real steel throttle/prop/mixture quadrant. Robbed the electronics out of the CH stick and pedals to drive it. But still, it's used only as a procedures trainer, not for teaching how to fly. The students use it for free to practice what they learned on our certified Elite sim or in the air under the hood. It's much more work to fly it, thanks to the big springs I put in it. I need to redesign the mechanical trim to get more travel, though. Underestimated the degree of elevator movement between high cruise and slow flight. And it has a collective for helicopter flight. Dan IIRC you (Dan) are in Sask, I'm just over the hills in BC. If we're ever going by your place I'd love to try that sim, how much do you charge? Ken It's for our College students only. Dan |
On May 28, 7:10 am, wrote:
On May 27, 10:10 pm, "Ken S. Tucker" wrote: On May 27, 7:42 am, wrote: On May 16, 1:49 pm, "Ken S. Tucker" wrote: I was ok with the location of the trim wheel, but the adjustment was too coarse for me, but I could be a bitchy sissy. My wheel was graduated, with a zero mark and did not quite give the fine adjustment I wanted. That could be cables out to the tail, I should have learned the mechanism! Nothing to do with the cables. Cessna's trim is anything but sensitive, having four or five full turns of the wheel for the trim range. Try a Citabria sometime, where the trim is a lever that moves about eight or ten inches for the full range. Much more twitchy. As far as others have asked about sim trim, the good, commercial training sims (Level II) have a pitch control mechanism centered by some strong springs that supposedly simulate elevator pressures. The anchor points for those springs are movable, and those are what the trim mechanism moves. So in slow flight the yoke is well back, against the springs, so that the trim moves the spring anchors back until the pressure disappears. The yoke does not move and the pilot, if he's "flying" right, doesn't let it move. He just trims off the pressure. Mx's stick, on the other hand, trims electronically so that he has to gradually center the stick to keep the nose where it's supposed to be. Not realistic at all. And the springs in those cheap things are so feeble as to be a joke. Flying the real airplane is much more work. If you had realistic spring forces you'd have to bolt the stick to the desk and anchor the chair to the floor. I built our own procedures sim here. Proper frame welded up, proper adjustable seat, huge monitor, real rudder pedals with realistic spring feel, real stick with a heavy non-discrete center spring and an adjustable anchor to simulate a reaslistic trim. Real steel throttle/prop/mixture quadrant. Robbed the electronics out of the CH stick and pedals to drive it. But still, it's used only as a procedures trainer, not for teaching how to fly. The students use it for free to practice what they learned on our certified Elite sim or in the air under the hood. It's much more work to fly it, thanks to the big springs I put in it. I need to redesign the mechanical trim to get more travel, though. Underestimated the degree of elevator movement between high cruise and slow flight. And it has a collective for helicopter flight. Dan IIRC you (Dan) are in Sask, I'm just over the hills in BC. If we're ever going by your place I'd love to try that sim, how much do you charge? Ken It's for our College students only. No problemo, I'll enroll...which college? Ken |
Typical power settings during cruise and other phases of flight | Mxsmanic | Piloting | 99 | October 2nd 06 10:12 AM |
Making a pitch trim indicator for a Glasair | [email protected] | Home Built | 5 | September 13th 06 02:30 AM |
$30,000 pitch links | Stuart Fields | Home Built | 3 | January 16th 06 02:13 AM |
Cherokee Electric Pitch Trim | Jonathan Goodish | Owning | 4 | November 18th 04 02:43 AM |
ALTRAK pitch system flight report | optics student | Home Built | 2 | September 21st 03 11:49 PM |
