Kennedy gets his own TFR
Old May 24th 08, 10:57 AM posted to rec.aviation.piloting
Steve Foley
Default Kennedy gets his own TFR
FDC 8/8593 ZBW MA.. FLIGHT RESTRICTION HYANNIS, MA EFFECTIVE IMMEDIATELY
UNTIL 0805272200 UTC. PURSUANT TO 14 CFR SECTION 91.137(A)(1), TEMPORARY
FLIGHT RESTRICTIONS ARE IN EFFECT DUE TO SAFETY OF FLIGHT WITHIN A 3
NAUTICAL MILE RADIUS OF 413749N/0701812W OR THE MVY VORTAC 060 DEGREE RADIAL
AT 19.8 NAUTICAL MILES UP TO AND INCLUDING 5000 MSL. ALL AIRCRAFT OPERATIONS
WITHIN THE AREA LISTED ABOVE ARE PROHIBITED EXCEPT FOR: FEDERAL, STATE,
LOCAL MEDEVAC AND MILITARY AIRCRAFT. VFR AND IFR OPPERATIONS TO AND FROM HYA
ARE AUTHORIZED. AIRCRAFT IN DIRECT COMMUNICATIONS WITH ATC ARE ALLOWED. NO
LOITERING, NO PRACTICE APPROACHES OR PATTERN WORK. CAPE APCH, 508-968-7126,
AND OR BOSTON ARTCC /ZBW/, 603-879-6655, ARE THE COORDINATION FACILITIES.
He gets the cape to himself for the holiday weekend.
Old May 24th 08, 11:42 AM posted to rec.aviation.piloting
Bob Noel
"Steve Foley" wrote:
[TFR snipped]
Should we start a pool on how many pilots violate this TFR over
the weekend? Sunday looks a perfect day for flying over the
cape.
Bob Noel
(goodness, please trim replies!!!)
Old May 24th 08, 12:57 PM posted to rec.aviation.piloting
Tina
It looks like the only restrictions are sightseeing and messing around
flights in that airspace -- vfr operations into Hyannis are allowed,
as are most other 'going somewhere' flights.
Could this be construed as an anti-press restriction, keeping CNN and
others from getting too close to his sailboat?
By the way, in spite of rumors otherwise, his 50 footer is fully
capable of turning to the right. Unless Sen Kerry is aboard, of
course, in which case it takes three lefts to make a right. Oh, all
right, three port turns to make a starboard.
By the way, since sails often do act like vertical wings generating
lift (thanks to the lift fairies) including sailing comments is still
on topic.
On May 24, 6:42 am, Bob Noel
[TFR snipped]
cape.
Bob Noel
Old May 24th 08, 01:55 PM posted to rec.aviation.piloting
Lou
You gotta love a sense of humor!!!!!!!!
Lou
Old May 24th 08, 03:05 PM posted to rec.aviation.piloting
Bob Fry
Looks like it's designed to keep out the paparrazi and looky-loos: 3nm
radius, sfc-5000 ft.
In the end, we will remember not the words of our enemies, but the
silence of our friends.
~ Martin Luther King, Jr.
Old May 24th 08, 04:23 PM posted to rec.aviation.piloting
More_Flaps
on topic.
Nope. Sails work by deflecting sea sprites. From personal experience,
I can tell you that a particular class of sprite sprite called sojo
(in Japanese) can be extremely troublesome and can loose you a lot of
sailing races -if you have alcohol on board. Lift faries like to sit
on wings (when they are not flying) and have no interest in vertical
sails at all.
Cheers
Old May 24th 08, 04:27 PM posted to rec.aviation.piloting
More_Flaps
Is he really that important?
Cheers
Old May 24th 08, 04:56 PM posted to rec.aviation.piloting
Steven P. McNicoll[_2_]
No.
Old May 24th 08, 04:59 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
"Steven P. McNicoll" wrote in
m:
No.
Can you be sure?
Bertie
Old May 24th 08, 06:32 PM posted to rec.aviation.piloting
Tina
I do not like the man, but would say his privacy should be respected.
If good taste won't keep people away, this minor inconvenience to
pilots is fine. Although, given the tastelessness of many who would
get close, the zone should be defined as anything within range of say
a 50 caliber round.
shoOn May 24, 11:59 am, Bertie the Bunyip wrote:
"Steven P. McNicoll" wrote innews:Xv6dndHFYIQAp6XVnZ2dnUVZ_sHinZ2d@earthlink. com:
No.
Can you be sure?
Bertie
Sen Kennedy learns value of local airport,... hopefully. Mike Isaksen Piloting 10 May 19th 08 08:05 PM
RIP J.F.Kennedy [email protected] Naval Aviation 8 January 21st 05 02:16 AM
USS John F. Kennedy to be retired in 2005 [email protected] Naval Aviation 2 January 3rd 05 08:13 AM
Ted Kennedy put on No Fly List Roger Long Piloting 14 August 22nd 04 02:08 PM
USS Kennedy at NAS Pensacola Keith King Naval Aviation 1 March 20th 04 07:21 PM
