Questions Regarding Becoming a Marine Fighter Pilot. ? Thanks!
Old December 3rd 03, 10:24 PM
Harry Andreas
In article , wrote:
On Wed, 03 Dec 2003 15:16:37 GMT, Ed Rasimus
On Tue, 02 Dec 2003 21:04:05 -0800, Mary Shafer
On Tue, 02 Dec 2003 14:45:06 GMT, Ed Rasimus
Suppose they opt to fly missions from Aircraft carriers. How long
would this take? (Basic training, flight school, etc.)
I assume you mean training. All USMC and USN aviators are carqual.
About two years.
I don't think the P-3 or C-130 communities carqual, Ed.
Caught me in the act of being elitist, didn't you?
Not at all. I caught you saying something I'd normally say.
Can I defend myself by saying that I was narrowly focused on the
question regarding "Marine Fighter Pilot"? Nahh, I forgot the heavy
operators, pure and simple.
All fighter pilots in the Navy and Marines carqual. That's what we
both would mean, but not say.
If I hadn't just been talking to a former P-3 pilot, I would have
forgotten them, too. We were talking about tanker aircraft or the
C-130s would have never occurred to me, either.
I'm not even going to mention the adversary F-16s that were,
presumably, flown by both Navy and Marine aviators. That way lies
madness and an interminable thread about hook size, training, and
"what if".
Rejoice with me. They've got the rafters and roof sheathing on our
house, having put up the load-bearing walls in two days, and have
started on the non-load-bearing walls and the water lines and wiring.
The sheer-wall sheathing is being done today. We have the pre-drywall
walk-through on Tuesday, a week from now.
If your area is as prone to termites as the South Bay (LA county) you're
at just the right time to have your new house tented. All the wood should
be in, electrical and water in, but not drywall.
It turns out that the lumber yard is termite central.
(Where would you choose to live if you were a termite?)
The wood is not treated. This from a contractor friend.
Most new houses in SoCal start showing termite signs in 2-3 years from
the wood carried in from the lumberyard.
I understand it used to be a problem in wooden-frame aircraft
back in the day (just to keep on topic).
Harry Andreas
Engineering raconteur
Old December 4th 03, 04:36 AM
Mary Shafer
On Wed, 03 Dec 2003 14:24:45 -0800, (Harry
It's apparently not a huge problem here. Maybe termites don't like
the 118 degF summer weather; I know I don't. Anyway, they did
saturate the soil twice with some sort of anti-termite chemical before
they poured the slab and this, it seems, is good enough.
Termites are exceedingly rare in the High Desert, too. Not
non-existant, but certainly far from common. My neighborhood is full
of houses built about 30 years ago and a fair number have been sold
recently, meaning termite inspections for escrow. No one has had any
found so far.
That doesn't surprise me at all, although I hope it wasn't
subterranean termites, with their little mud tunnels from under the
ground to the airframe. A good pre-flight should catch that one, I'd
think.
Then there are the mud-daubber wasps that build their nests in such
inopportune site as pitot tubes and static ports. Apparently, this
happens without being caught on the preflight now and then, usually
with unpleasant results.
Mary
Mary Shafer Retired aerospace research engineer
Old December 4th 03, 04:58 AM
Pete
found so far.
Termites need not just wood, but moisture as well. Florida, Lousyana, etc
are termite havens.
Pete
Old December 4th 03, 06:52 AM
Michael Williamson
found so far.
are termite havens.
Pete
Interestingly though, there are termites all over the place here in
Tucson, which isn't exactly a rain forest...
Mike
Old December 4th 03, 05:03 AM
Bob McKellar
found so far.
think.
Mary
I understand a lot of the homebuilt composite aircraft have had problems with
polyestermites.....
Bob McKellar, ducking and running for cover
Old December 4th 03, 08:40 PM
Harry Andreas
In article , Bob McKellar
found so far.
think.
Mary
polyestermites.....
LOL! ouch, that's so bad it's funny.
Harry Andreas
Old December 5th 03, 01:24 AM
Duke of URL
"Harry Andreas" wrote in message
problems with polyestermites.....
Grroooaannn... Oh, man, I managed to miss that the first time past. I
really WISH you hadn't reposted it.
Old December 4th 03, 05:45 AM
user
Short attention span have we??
On Wed, 03 Dec 2003 20:36:36 -0800, Mary Shafer
found so far.
think.
Mary
Old December 11th 03, 10:49 PM
Mary Shafer
On Sat, 6 Dec 2003 06:23:26 +0000 (UTC), David Lesher
Hope you wired the house with CAT5 here/there/everywhere, as
well as RG-6 for the boob tube..
Fifteen dataports (two-line phone, Cat5e, two sets of coax), including
one on the patio and one on the front porch (two dataports came
standard with the house). Plus six or seven two-line phone outlets
and one set of coax, standard. And another wiring box to hold all of
this.
I also put in electrical receptacles right by the outside dataports.
It's nice enough here to sit outside and read Usenet on my laptop
during the day. Retirement is fun.
They put in the additional can lights and the quadraplex outlets
yesterday. They've put in the fireplace, the HVAC units and ducting,
the alarm system, and the J-boxes, wrapped the house in tar paper, and
started putting the foam and chickenwire on the outside. I think
we're about a week from drywall now. They put on the brown coat a
couple of days after that. They've got the tiles on the roof already,
not in place, but up there to put the weight on for the frame and
stucco.
The insulation is a combination of blown cellulose and 1-in. foam, but
I don't see how they're going to get the blown stuff in there, unless
they go through the foam just before they stucco. All the studs have
firebreaks, of course, and the twelve-foot studs have two, so it's not
going to be quick. They do use bats in the garage, though. Maybe
they use a smaller hole to blow the cellulose in than I think they do.
Mary
A-4 / A-7 Question Tank Fixer Military Aviation 135 October 25th 03 03:59 AM
Why did Britain win the BoB? Grantland Military Aviation 79 October 15th 03 03:34 PM
Marine fighter pilots? Navin R. Johnson Military Aviation 18 October 12th 03 02:39 AM
FS Books USAF, Navy, Marine pilots and planes Ken Insch Military Aviation 0 July 20th 03 02:36 AM
Joint Russian-French 5th generation fighter? lihakirves Military Aviation 1 July 5th 03 01:36 AM
