Cost to earn a glider certificate?
Old June 8th 08, 11:59 PM posted to rec.aviation.soaring
Nyal Williams[_2_]
Default Cost to earn a glider certificate?
There are no wasted flights; you can learn something from every one. No
two days are alike and the weather has to be figured out each day.
That said, there are 17 things that have to be entered by an instructor
into your log book before it is legal to solo. The efficiency is to carry
that list, post a flight number by the item covered, and wave the list in
front of your instructor to be sure all items are planned for ahead of
time.
I had a student fly a two hour flight as his second flight after solo here
in the midwest. The next time he flew it was 16 minutes; he didn't sort
out the weather. You will have ups and downs in your whole career as a
glider pilot and that is what makes it interesting.
At 21:39 08 June 2008, Alan wrote:
In article "Vaughn Simon" writes:
"Tony Verhulst" wrote in message
m...
... your real question (IMHO) should be "what does it cost to
participate in
soaring?".
Well said! Since much of soaring is done solo anyhow, and much of
your
student flying is also solo, the cost to actually earn your certificate
is not
terribly relevant. Flying is flying...certificate or not, and flying
is
a
wonderful thing.
Vaughn (CFIG)
Much the same was true when I got my power license -- flying is
flying.
However, now I wonder about what sort of flights to expect while
getting
the rating -- how many useful flights and how many wasted ones? Does it
really
take 15 to 20 flights of dual before solo? What is covered in those,
and
how
can one take control of the process to make it more efficient?
How many more dual before "high solo", and how many more before the
check ride?
How many of these flights actually get into lift and give a good
learning period,
and how many are just a ride back down from release?
yes, I know, "ask the local group's instructors". I am asking here
first so I
am better equipped to evaluate their answers when I do so.
Alan
Old June 9th 08, 12:48 AM posted to rec.aviation.soaring
BT
"Nyal Williams" wrote in message
snip
time.
snip
Nyal.. would you care to list all 17 items?
BT
Old June 9th 08, 02:11 AM posted to rec.aviation.soaring
SoaringXCellence
snip
into your log book before it is legal to solo. *The efficiency is to carry
time.
snip
BT
The list of items is found in the Student Pilot section of the FAR
part 61.87(i) 1-19
(i) Maneuvers and procedures for pre-solo flight training in a glider.
A student pilot who is receiving training for a glider rating or
privileges must receive and log flight training for the following
maneuvers and procedures:
(1) Proper flight preparation procedures, including preflight
planning, preparation, aircraft systems, and, if appropriate,
powerplant operations;
(2) Taxiing or surface operations, including runups, if applicable;
(3) Launches, including normal and crosswind;
(4) Straight and level flight, and turns in both directions, if
applicable;
(5) Airport traffic patterns, including entry procedures;
(6) Collision avoidance, windshear avoidance, and wake turbulence
avoidance;
(7) Descents with and without turns using high and low drag
configurations;
(8) Flight at various airspeeds;
(9) Emergency procedures and equipment malfunctions;
(10) Ground reference maneuvers, if applicable;
(11) Inspection of towline rigging and review of signals and release
procedures, if applicable;
(12) Aerotow, ground tow, or self-launch procedures;
(13) Procedures for disassembly and assembly of the glider;
(14) Stall entry, stall, and stall recovery;
(15) Straight glides, turns, and spirals;
(16) Landings, including normal and crosswind;
(17) Slips to a landing;
(18) Procedures and techniques for thermalling; and
(19) Emergency operations, including towline break procedures.
Mike
Old June 9th 08, 03:13 AM posted to rec.aviation.soaring
noel.wade
There are two critically important things, in ensuring that your
training flights are not "wasted":
1) Your preparation. Prepare ahead of time. Most clubs are really
not that good at the ground-instruction side of things - so you have
to do a lot of the leg-work on this yourself. Be self-motivated, find
good books and DVDs on transitioning to gliders and learning to fly
gliders. Read / Watch them, and really try to absorb all the
knowledge from them that you can.
2) Your instructor(s). Many clubs have rotating duty cycles or
volunteer instructors that come out approximately "whenever they feel
like it" Their volunteerism is commendable, but it makes for a slower
training system because you will be repeating maneuvers to different
instructors (so that they confirm you know your stuff). Try to work
with just a few instructors - be respectful but aggressive in getting
just one or two scheduled to fly with you as much as possible. In my
club I flew with 6 (!!) instructors in my first few months; as a
result it took 20 flights to go solo (transitioning from PPL SEL) when
it should have taken 10. Once I *was* solo, none of the instructors
wanted to prep me for my ride. So I went to a commercial operation to
finish up and take my checkride, and got through in 3 days and only 7
or 8 flights (including my checkride flights).
Regarding flight length: Its hard to swallow this when you're eager
to soar - but thermalling and long flight times are NOT something to
aim for early on. Getting the instructor in the back seat, running
through the maneuvers (and getting comfortable with them) is the
hardest thing to schedule. More short flights is better than fewer
long ones - even if it costs a few $$ more for those extra tows.
Remember that once you're signed off to go solo, you can practice
thermalling and try to truly soar as much as you want (even before you
get your checkride)... With only a single person in the cockpit,
you'll also find that your glider will climb better and turn better -
so thermalling will be more enjoyable at that point, too!
Finally, one more tip: If you're computer-savvy, there's a great
flight simulator for soaring. Its called "Condor". It is best if you
have the basics of glider controls and aerotowing under your belt
before you try it, but once you're to the point where you want to
practice thermalling, cross-country flight, ridge-soaring, and other
advanced techniques, Condor is the way to go! But again, get
comfortable with gliding flight and towing first.
Take care,
--Noel
P.S. Sorry, there's one more thing some clubs are really bad at:
Teaching new members the non-soaring side of operations! Not only do
these duties help the club, but they help pass the time between
flights and help YOU be a better pilot (no joke!). Go out and have
someone teach you how to wing-run. You'll get to see a ton of
different take-off techniques over the course of a few hours (some of
which you may make a note to try - or avoid!); and you'll learn a lot
about safety on both ends of the line. Also, helping rig and pre-
flight other gliders (club and non-club) can be a great learning
experience. Be respectful of people's equipment and NEVER touch,
unless you're given permission. Seeing different equipment designs,
pre-flight techniques, assembly methods, and talking with other pilots
will help you learn things - some things you won't even realize you've
learned until later! One of the reasons we fly as "clubs" is because
gliding is really an all-day venture - there's a lot of value AND
enjoyment in the camaraderie and in being part of the entire operation
- not just getting "stick-time" and then going home... Have fun!
Old June 9th 08, 03:14 AM posted to rec.aviation.soaring
Nyal Williams[_2_]
Someone beat me to it, and there are 19 of them -- i goofed.
To reiterate: print it out, keep it with your logbook, and urge your
instructor to focus on missing items, and to USE THE LANGUAGE OF THE CFRs
in your logbook.
snip
instructor
carry
in
time.
snip
BT
Old June 9th 08, 04:57 AM posted to rec.aviation.soaring
BT
I figured that was what the answer would be.. and yes.. 19..
but all 19 need not be listed for which flight they occured on. "xxyz
taught to profiency on flight IAW FAR 61.87 yadayada yada
That's what a training folder is for.
Only the endorsement that states that ground (academic) and flight training
of the items in 61.87(c)(l) have been completed.
SSF had a great sample shown below, also 61.65E had copies of all
endorsements required, and there are not 19 training endorsements for the
glider student pilot.
STUDENT PILOT
Aeronautical Knowledge - FAR 61.87(b)
I certify that M _____________ has satisfactorily completed a pre-solo
written examination as required by FAR 61.87(b) demonstrating knowledge of
the portions of FAR Part 61 and Part 91 applicable to student pilots,
airspace rules and procedures, and the flight characteristics and
operational limitations for a (Glider Type), and that I have reviewed all
incorrect answers with him.
Pre-Solo Flight Training - FARs 61.31(j) and §61.87 (c)
(Aerotow)
I certify that M ___________ has received the instruction required by FAR
61.31(j) and FAR 61.87(c) and (i) in a (Glider Type) and that he has
satisfactorily accomplished ground and flight training in aerotow procedures
and operations and proficiency therein, has demonstrated proficiency in the
applicable maneuvers and procedures included in FAR 61.87(i), and has
demonstrated adequate knowledge of flight rules listed in FAR Part 91 and is
competent to make safe solo flights in that glider; provided that each such
flight is carried out when the surface wind (steady or gusting) does not
exceed ___ kts and the crosswind component does not exceed ___ kts. This
approval is valid for the ___ days immediately following this endorsement
and provided such flights are conducted entirely within gliding range of the
takeoff point.
Note: Ground and Self-Launch endorsement samples are found in the
"Additional Endorsements" section of this publication.
BT
in your logbook.
snip
instructor
carry
in
time.
snip
BT
Old June 9th 08, 06:14 AM posted to rec.aviation.soaring
Nyal Williams[_2_]
My recommendation to have these items in the log book is because an
extremely well-known examiner looks for these specific items when he
examines a student for a certificate.
One might be well-trained and slide by without these specific entries, but
they will smooth the process and they will also protect the instructor
against future difficulties.
training
STUDENT PILOT
of
(Aerotow)
procedures
and
is
such
takeoff point.
BT
CFRs
in your logbook.
snip
instructor
carry
list
in
of
time.
snip
BT
A Preliminary Assessment of the Potential Cost and Cost-Effectiveness of Space-Based Weapons. Mike[_7_] Naval Aviation 0 November 2nd 07 03:18 PM
EARN CASH WHILE SAVING GAS Gas Savers Home Built 0 June 29th 06 06:12 PM
USA Glider Experimental Airworthiness Certificate charlie foxtrot Soaring 4 April 15th 06 05:04 AM
Where to earn Glider Rating this fall / winter [email protected] General Aviation 0 September 5th 05 01:37 AM
Help me earn my Instrument Products 0 July 16th 03 07:46 AM
