On Jun 17, 11:58 pm, Nyal Williams wrote:
At 22:04 17 June 2008, danlj wrote: snip If you look into the CFRs about parallel runways you will find that they must be separated by 750ft, IIRC. This means you cannot "formally designate" a second runway with markings, etc. at your site. There are lots of airports where gliders operate from the grass alongside the paved runway, but none of these are designated as separate runways. 3B3, in Sterling, Mass., home of the very active (150+ members) Greater Boston Soaring Club and MIT Soaring Association, is set up this way. The parallel grass strip is well maintained, but I do not believe it is listed as a separate runway. Landing pilots sequence, and when announcing on CTAF, we simply state "taking the grass." If power traffic is on final, launches from the grid are definitely put on hold |
Yes, we operate this way at our airport. The original poster was
considering "formal" designation with separate markings, etc. That would involve the FAA, paper work filing, a site visit possibly, and definitely a refusal. All of that together with a refusal would likely cause a municipal airport authority to become frightened and stop the operation. At 13:52 18 June 2008, jchutch wrote: On Jun 17, 11:58 pm, Nyal Williams wrote: At 22:04 17 June 2008, danlj wrote: If you look into the CFRs about parallel runways you will find that they must be separated by 750ft, IIRC. This means you cannot "formally designate" a second runway with markings, etc. at your site. There are lots of airports where gliders operate from the grass alongside the paved runway, but none of these are designated as separate runways. 3B3, in Sterling, Mass., home of the very active (150+ members) Greater Boston Soaring Club and MIT Soaring Association, is set up this way. The parallel grass strip is well maintained, but I do not believe it is listed as a separate runway. Landing pilots sequence, and when announcing on CTAF, we simply state "taking the grass." If power traffic is on final, launches from the grid are definitely put on hold |
GNS430W: Parallel offset course feature | Peter R. | Instrument Flight Rules | 34 | September 29th 07 02:25 AM |
grover cares, then Faris publicly designates a mere parallel apart from Jeremy's riot | R. Hamid | Piloting | 0 | August 13th 07 01:19 AM |
Hot grass fire at Sun-N-Fun | [email protected] | Home Built | 21 | April 12th 06 01:41 AM |
Greasy Grass | George Shirley | Naval Aviation | 1 | October 30th 04 06:20 PM |
Parallel Track function in GPS? | Roy Smith | Instrument Flight Rules | 25 | April 30th 04 12:57 AM |
