In rec.aviation.piloting Le Chaud Lapin wrote:
On Jun 19, 4:15?pm, wrote: In rec.aviation.piloting Le Chaud Lapin wrote: If history is any indicator, technology becomes cheaper as time moves forward, so whatever it is, it will probably be smaller, cheaper, faster, more reliable, better-featured, disposable (it breaks, no reason to cry as much), etc. None of the technology involved in building airplanes has gotten much cheaper in real dollars since airplanes were invented. There are only so many existing materials you can build an airplane from and they are all mature. The only significant difference is the avionics does more for the same cost. Which implies that, if it does the same (if doing the same is an option), then the cost is less. It isn't an option. There is no market for 12 channel comm radios. There are many ground-based vehicles (cars) that technologically more sophisticated than a new low-end Cessna but cost much less. And cars are not built in quatities of a few hundred tops a year nor does every little piece in them have to be certified. Well, there are a couple of low volume cars that cost about the same as a low end Cessna, to be totally accurate. -- Jim Pennino Remove .spam.sux to reply. |
FA: 1-Day-Left: 3 Advanced AVIATION Books: Aviation Electronics, Air Transportation, Aircraft Control and Simulation | Mel[_2_] | Aviation Marketplace | 0 | September 8th 07 01:37 PM |
FA: 3 Advanced AVIATION Books: Aviation Electronics, Air Transportation, Aircraft Control and Simulation | Derek | Aviation Marketplace | 0 | September 3rd 07 02:17 AM |
FA: 1-Day-Left: 3 AVIATION Books: Aviation Electronics, Air Transportation, Aircraft Control and Simulation | Jeff[_5_] | Aviation Marketplace | 0 | September 1st 07 12:45 PM |
FA: 3 AVIATION Books: Aviation Electronics, Air Transportation, Aircraft Control and Simulation | Jon[_4_] | Aviation Marketplace | 0 | August 24th 07 01:13 AM |
FA: 3 ADVANCED AVIATION Books: Aviation Electronics, Air Transportation, Aircraft Control and Simulation | Larry[_3_] | Aviation Marketplace | 0 | August 6th 07 02:23 AM |
