On Jun 27, 8:07*am, "RST Engineering" wrote:
Describe the "old antenna" and how it is installed. Jim -- "It is the mark of an educated mind to be able to entertain a thought without accepting it." * * * * --Aristotle "et" wrote in message ... Is there an easy way for a novice to check an old antenna? thanks et- Hide quoted text - - Show quoted text - It is a VHF com, similar to the AV-529 that AC Spruce sells. Aluminum base, slanted whip off a late 60's pa-28. It is mounted on an al. base about8"x10" in the rear of a Glasair fuse. The base is connected to the a/c ground. I can turn on the runway lights from my hanger with the PTT switch on the control stick[about 200']. When I taxi tested for the first time, it wouldn't turn the lights on from the end of the runway[about 1500']. I don't have the headset jacks hooked up yet, just the PTT and a small speaker. I can recieve in the hanger from a/c in and near the pattern. et |
A "whip" or monopole antenna such as this requires a ground plane to operate
properly. In general, a metal airplane with metal fuselage in all directions will serve very well In a plastic airplane, a "ground plane" of several (four is the accepted number)radials quarter wave long (about 24") coming out at right angles at right angles from the antenna is a requirement. A single 8x10 aluminum bracket isn't going to cut it. Jim -- "It is the mark of an educated mind to be able to entertain a thought without accepting it." --Aristotle "et" wrote in message ... On Jun 27, 8:07 am, "RST Engineering" wrote: Describe the "old antenna" and how it is installed. Jim -- "It is the mark of an educated mind to be able to entertain a thought without accepting it." --Aristotle "et" wrote in message ... Is there an easy way for a novice to check an old antenna? thanks et- Hide quoted text - - Show quoted text - It is a VHF com, similar to the AV-529 that AC Spruce sells. Aluminum base, slanted whip off a late 60's pa-28. It is mounted on an al. base about8"x10" in the rear of a Glasair fuse. The base is connected to the a/c ground. I can turn on the runway lights from my hanger with the PTT switch on the control stick[about 200']. When I taxi tested for the first time, it wouldn't turn the lights on from the end of the runway[about 1500']. I don't have the headset jacks hooked up yet, just the PTT and a small speaker. I can recieve in the hanger from a/c in and near the pattern. et |
RST Engineering wrote:
A "whip" or monopole antenna such as this requires a ground plane to operate properly. In general, a metal airplane with metal fuselage in all directions will serve very well In a plastic airplane, a "ground plane" of several (four is the accepted number)radials quarter wave long (about 24") coming out at right angles at right angles from the antenna is a requirement. A single 8x10 aluminum bracket isn't going to cut it. Jim Would perforated aluminum foil or aluminum screen embedded in the skin and bonded to ground do the job? I'm assuming it wouldn't make for a strong lamination, but as a ground plane it seems kind of tidy. Dan, U.S. Air Force, retired |
Electrically it would work just fine. The problem is how to get the
grounding bolts of the antenna base to mechanically connect to the aluminum and not corrode over a long period of time. A secondary problem is that the antenna gets as much "connection" to the metal skin of an airplane through the capacitance between the metal base and the skin through a very thin rubber gasket acting as a dielectric as it does with the metal screw contact. WItness the fact that most of those fiberglass whip antennas have a rather sturdy epoxy paint job on the base. 99 out of 100 times you take the antenna off and you find that the paint in the bolt holes is still quite intact, meaning that the screw never DID cut through that paint to give you the ground you were hoping for. Me? If it is a tupperware airplane or toothpicks and tissue paper airplane I go down to the hardware store and buy some thin (1 or 2 mil) shim brass or copper. Cut me a plate using the base of the antenna as a template and four strips 22.5" long. Solder the strips to the brass plate near the center, stuff the strips through a hole in the fuselage where the antenna is going to go, leaving the plate on the OUTside of the fuselage, bolting the antenna through the brass plate and through the fuselage, and then tidy up the brass strips by "attaching" (glue, RTV, epoxy) them flat to the underside of the fuselage. Jim -- "It is the mark of an educated mind to be able to entertain a thought without accepting it." --Aristotle "Dan" wrote in message ... Would perforated aluminum foil or aluminum screen embedded in the skin and bonded to ground do the job? I'm assuming it wouldn't make for a strong lamination, but as a ground plane it seems kind of tidy. Dan, U.S. Air Force, retired |
GPS Antenna | 150flivver | Owning | 14 | December 11th 05 05:38 AM |
Best VHF Antenna | Steve | Home Built | 6 | January 25th 05 02:04 PM |
ELT Antenna | Gary | Home Built | 18 | November 5th 04 02:17 AM |
VHF Antenna | David Wilson | Home Built | 1 | June 14th 04 03:25 AM |
ADF antenna | Dan Luke | Owning | 3 | August 14th 03 02:48 PM |
