Jay Maynard wrote:
On 2008-07-06, B A R R Y wrote: You've NEVER had the bar slip past the next (or all the way to the floor) notches? You know, your finger has a touch of pressure on the button? This happened to me on my Archer checkout with the club's chief pilot as CFI. I just pulled the first notch back in while holding pitch attitude, and wiped away the sudden sweat. Keep flying the airplane, and it'll be fine. Were you crossing the threshold @ 40 AGL and seconds from a landing? I agree it's not such a big deal at altitude. Personally, I want to avoid leaning over to grab the bar at the moment I mentioned above. Thursday afternoon, I landed in a varying 45 to 60 degree crosswind 15 gusting to 27. With my luck, that would be the day I drop the bar. 8^( |
Jay Maynard wrote: On 2008-07-06, B A R R Y wrote: You've NEVER had the bar slip past the next (or all the way to the floor) notches? You know, your finger has a touch of pressure on the button? This happened to me on my Archer checkout with the club's chief pilot as CFI. I just pulled the first notch back in while holding pitch attitude, and wiped away the sudden sweat. Keep flying the airplane, and it'll be fine. Were you crossing the threshold @ 40 AGL and seconds from a landing? No, I'd just started a go-around at not a lot higher, and a bit further down the runway. Thursday afternoon, I landed in a varying 45 to 60 degree crosswind 15 gusting to 27. With my luck, that would be the day I drop the bar. 8^( I do have to admit I feel a lot more comfortable with an electric flap system. -- Jay Maynard, K5ZC http://www.conmicro.com http://jmaynard.livejournal.com http://www.tronguy.net Fairmont, MN (FRM) (Yes, that's me!) AMD Zodiac CH601XLi N55ZC (got it!) |
On Jul 7, 4:38*am, B A R R Y wrote:
Jay Maynard wrote: On 2008-07-06, B A R R Y wrote: You've NEVER had the bar slip past the next (or all the way to the floor) notches? *You know, your finger has a touch of pressure on the button? This happened to me on my Archer checkout with the club's chief pilot as CFI. I just pulled the first notch back in while holding pitch attitude, and wiped away the sudden sweat. Keep flying the airplane, and it'll be fine. Were you crossing the threshold @ 40 AGL and seconds from a landing? I agree it's not such a big deal at altitude. *Personally, I want to avoid leaning over to grab the bar at the moment I mentioned above. Thursday afternoon, I landed in a varying 45 to 60 degree crosswind 15 gusting to 27. *With my luck, that would be the day I drop the bar. 8^( Try doing a flapless for more control in a strong xwind? Cheers |
On Jul 7, 8:22*am, Clark wrote:
More_Flaps wrote in news:1d23a864-9d7f-4d01-ac12- : On Jul 7, 4:38*am, B A R R Y wrote: Jay Maynard wrote: On 2008-07-06, B A R R Y wrote: You've NEVER had the bar slip past the next (or all the way to the floor) notches? *You know, your finger has a touch of pressure on th e button? This happened to me on my Archer checkout with the club's chief pilot a s CFI. I just pulled the first notch back in while holding pitch attitude , and wiped away the sudden sweat. Keep flying the airplane, and it'll be fin e. Were you crossing the threshold @ 40 AGL and seconds from a landing? I agree it's not such a big deal at altitude. *Personally, I want to avoid leaning over to grab the bar at the moment I mentioned above. Thursday afternoon, I landed in a varying 45 to 60 degree crosswind 15 gusting to 27. *With my luck, that would be the day I drop the bar. 8^( Try doing a flapless for more control in a strong xwind? Cheers Hmmmm, other points of view: I don't see that idea contradicted in that article -just discussion of correct x-wind aeleron technique and nailing speeds. Having minimum or no flaps (1) reduces ground effect (2) greatly reduce the risk of upwind wing lifting (3) allows landing a slightly higher air speed which will reduce the x-wind component and (4) a slightly higher landing speed allows more rudder authority -so better control. All these factors help in a strong x-wind and that is what I was told by all my CFI's and it agrees with my experiences so far... Flaps are not required for landing any plane that I'm aware of -they help energy management but a pilot should be able to make a flapless landing just as good as as a full flap landing -with a slightly longer ground roll of course. Where is this wrong? Cheers |
On Jul 6, 4:41*pm, More_Flaps wrote:
all my CFI's and it agrees with my experiences so far... *Flaps are not required for landing any plane that I'm aware of -they help energy management but a pilot should be able to make a flapless landing just as good as as a full flap landing -with a slightly longer ground roll of course. Where is this wrong? The above is exactly my experience. My take is that the less I have hanging out the plane (flaps), the more streamline and wind resistant I am. Main reason of course the higher ground roll is due to the higher stall speed sans flaps. Even with my level of experience (about 850 hours), I wouldn't do any high Xwinds landings at Carthage. I'd just go select a more wind favorable airport and land there or not launch at all. |
In article
, " wrote: Even with my level of experience (about 850 hours), I wouldn't do any high Xwinds landings at Carthage. I'd just go select a more wind favorable airport and land there or not launch at all. I highly recommend reading Leighton Collins' book, TAKEOFFS AND LANDINGS. |
On Jul 6, 7:05*pm, John Smith wrote:
I highly recommend reading Leighton Collins' book, TAKEOFFS AND LANDINGS. Actually I have. While most books always touch base on technique and such, this is my self imposed limits. Now, I can land my plane on a 50 foot wide runway at maximum Xwind component when called to task, but why? I have yet to find any reason in my short 7 years of flying to add more risk or try to shoe horn a landing on a shorter or narrower then **my normally encountered** runways. I have very conservative limits when it comes to go and no go and have not and will not deviate from that. If winds were above my safety factors, then I'd go to a neighboring airport or concede and use my car. The Carthage exercise was to expand on my experiences, not test my limits as the airplane doesn't care how far the edges of the runway are as long as I maintain centerline and the edges are wider then the foot print of my plane. I wanted to experience the narrow runway illusions that I had never experienced before. My Xwind landing limits is 17 knots direct Xwind at my own airport with a 75 foot wide runway. The Jackson (KJAN) exercise was for working with Ground controllers, just to keep me sharper in the movement area of an airport that has more then one taxiway. It is very rare I even go to a controlled airport, not that I avoid them, just much more convenient for people I meet up with when I fly (thus the beauty of GA) |
On Jul 7, 12:29*pm, " wrote:
On Jul 6, 7:05*pm, John Smith wrote: I highly recommend reading Leighton Collins' book, TAKEOFFS AND LANDINGS. Actually I have. *While most books always touch base on technique and such, this is my self imposed limits. Now, I can land my plane on a 50 foot wide runway at maximum Xwind component when called to task, but why? I have yet to find any reason in my short 7 years of flying to add more risk or try to shoe horn a landing on a shorter or narrower then **my normally encountered** runways. I have very conservative limits when it comes to go and no go and have not and will not deviate from that. *If winds were above my safety factors, then I'd go to a neighboring airport or concede and use my car. The Carthage exercise was to expand on my experiences, not test my limits as the airplane doesn't care how far the edges of the runway are as long as I maintain centerline and the edges are wider then the foot print of my plane. *I wanted to experience the narrow runway illusions that I had never experienced *before. My Xwind landing limits is 17 knots direct Xwind at my own airport with a 75 foot wide runway. The Jackson (KJAN) exercise was for working with Ground controllers, just to keep me sharper in the movement area of an airport that has more then one taxiway. *It is very rare I even go to a controlled airport, not that I avoid them, just much more convenient for people I meet up with when I fly (thus the beauty of GA) Fair enough but honing those skills may pay off for the real FLWOP... Cheers |
On Jul 7, 12:16*pm, Clark wrote:
More_Flaps wrote in news:2b709d3b-fa90-4373-a3e8- : On Jul 7, 8:22*am, Clark wrote: More_Flaps wrote in news:1d23a864-9d7f-4d01-ac12- : On Jul 7, 4:38*am, B A R R Y wrote: Jay Maynard wrote: On 2008-07-06, B A R R Y wrote: You've NEVER had the bar slip past the next (or all the way to the floor) notches? *You know, your finger has a touch of pressure on *th e button? This happened to me on my Archer checkout with the club's chief pilo t a s CFI. I just pulled the first notch back in while holding pitch attitude , and wiped away the sudden sweat. Keep flying the airplane, and it'll be fin e. Were you crossing the threshold @ 40 AGL and seconds from a landing? I agree it's not such a big deal at altitude. *Personally, I want to avoid leaning over to grab the bar at the moment I mentioned above. Thursday afternoon, I landed in a varying 45 to 60 degree crosswind 15 gusting to 27. *With my luck, that would be the day I drop the bar. |
Landings in Bessemer AL and Madison MS KEKY and KMBO | [email protected] | Piloting | 0 | January 14th 08 12:02 AM |
Jackson Hole TFR | [email protected] | Piloting | 24 | August 23rd 06 04:35 PM |
video of cross-wind landings | jbaloun | Home Built | 0 | June 2nd 06 01:56 AM |
Video surveillance / recording of airport operations (landings, etc)? | Fly Guy | General Aviation | 1 | August 5th 05 01:20 AM |
FA : King TakeOff Video : Takeoffs And Landings Made Easy | BTB | Aviation Marketplace | 0 | May 21st 05 07:12 AM |
