I see that pricing is available for a self-launch capable 304S from HPH but- what system are they using, Jet or Solo?
The pricing is not yet available for a turbo model alone Pricing is available for jet-sustainer No mention of the actual mechanics are made, they must know though, as there is an exact pricing for self launch. Does this mean the self-launch is jet as well? Anyone know? |
The price list for the 304S including option is on my website
http://www.wingsandwheels.com/pdf/HP..._E_1%20(2).pdf The Jet as of today is as a sustainer, completely computer controlled and fixed power. Though it is designed as a sustaine the factory test flights were accomplished with a short 50' auto tow with rather remarkable climb and cruise performance. Also to be offered are conventional solo sustainer (recip) and self launch "Binder" system Solo 2625-01 systems (also now on this page) as used on most other self launch sailplanes. The 304S prototype has already shown pretty remarkable contest performances as a pure sailplane and the only thing better will likely be the production models..the 304S prototype is currently in 3rd place in the Hungarian nationals after 7 contest days http://www.lhdv.cwi.hu/dokument_eng.html ....not bad since it's the only 304S to compete in any contest against a fleet of gliders from DG(LS), S-H, AS and the rest and always is well in the top of the pack and always flying with a new pilot with littel or no previous experience in the 304S until contest day 1 ..the first USA 304S is also due to land in Texas within days....hopefully Dick Johnson will be up to another sailplane evaluation in the not too distant future best regards Tim -- Please visit the Wings & Wheels website at www.wingsandwheels.com "bagmaker" wrote in message ... I see that pricing is available for a self-launch capable 304S from HPH but- what system are they using, Jet or Solo? The pricing is not yet available for a turbo model alone Pricing is available for jet-sustainer No mention of the actual mechanics are made, they must know though, as there is an exact pricing for self launch. Does this mean the self-launch is jet as well? Anyone know? -- bagmaker |
The Jet as of today is as a sustainer, completely computer controlled and fixed power. Though it is designed as a sustaine the factory test flights were accomplished with a short 50' auto tow with rather remarkable climb and cruise performance. Thanks Tim- Fixed power as in non-throttling? Can you give us a burn time/saw-tooth range estimate yet? Everyone will be hanging on with questions like -altitude loss before full power time, noise output, electric requirements, actual thrust available -all the details so sparse from eastern europe. Thanks, bagger |
On 12 Jul, 02:25, bagmaker
wrote: - The Jet as of today is as a sustainer, completely computer controlled and fixed power. Though it is designed as a sustaine the factory test flights were accomplished with a short 50' auto tow with rather remarkable climb and cruise performance. - Thanks Tim- Fixed power as in non-throttling? Can you give us a burn time/saw-tooth range estimate yet? Everyone will be hanging on with questions like -altitude loss before full power time, noise output, electric requirements, actual thrust available -all the details so sparse from eastern europe. Thanks, bagger -- bagmaker The Schempp-Hirth website says the jet Ventus 2cxaJ gets a pretty marginal 0.6 to 0.7 m/sec (say 130 f/min) climb from the AMT Olympus turbine which [according to the very detailed pdf specification sheet available through their website at http://www.amtjets.com] produces 230N max thrust. Fuel burn is quoted as 0.6 to 0.8 litres/min. The HPH Shark uses the TBS-J40 turbine which produces 400N rated max thrust. [http://www.wingsandwheels.com/pdf/30...Turbine01.pdf] The (proposed but in abeyance) Hollister jet club say about the Jet Shark's performance: "The best rate of climb is about 550 fpm at 75 knots and you still get 125 fpm at 95 knots." [http:// www.soarhollister.com/jet_club.htm] If correct that would be a big difference in performance between the two gliders for an extra 70% or so of thrust in the Shark. The Hollister site quotes a fuel consumption of 12 gal/hour which (assuming it is small US gallons) equates to 0.76 litres/min - pretty much the same as SH quote for the much less powerful Olympus. I am not sure that it all adds up - but it would be a hoot if it did! John Galloway |
This data is I believe all quite accurate. The 304S isn't just another new
version of an existing glider design with a model aircraft Jet attached. the engine used for the 304S is totally unlike the tiny jets used on other gliders it is computerized also so extension, starting and running are all done by one switch, shut-down and retraction are essentially the same. The complete extension, start up takes only a few seconds....and doesn't require priming, diving ect like the current sustainer systems, shut down is the same. Reasons being obvious, glider pilots may fly a motorized sailplane without having an airplane rating and even few airplane rated pilots are Jet trained....jest are quite simple in design, but are not operated as simply as your lawn mower and handing a Jet over to the would-be F-18 sailplane pilot without such controls could create some problems of it's own...even many recip sustainers have little or no controls the pilot can actually change. http://www.wingsandwheels.com/Hph%20new.htm tim -- Please visit the Wings & Wheels website at www.wingsandwheels.com wrote in message ... On 12 Jul, 02:25, bagmaker wrote: - The Jet as of today is as a sustainer, completely computer controlled and fixed power. Though it is designed as a sustaine the factory test flights were accomplished with a short 50' auto tow with rather remarkable climb and cruise performance. - Thanks Tim- Fixed power as in non-throttling? Can you give us a burn time/saw-tooth range estimate yet? Everyone will be hanging on with questions like -altitude loss before full power time, noise output, electric requirements, actual thrust available -all the details so sparse from eastern europe. Thanks, bagger -- bagmaker The Schempp-Hirth website says the jet Ventus 2cxaJ gets a pretty marginal 0.6 to 0.7 m/sec (say 130 f/min) climb from the AMT Olympus turbine which [according to the very detailed pdf specification sheet available through their website at http://www.amtjets.com] produces 230N max thrust. Fuel burn is quoted as 0.6 to 0.8 litres/min. The HPH Shark uses the TBS-J40 turbine which produces 400N rated max thrust. [http://www.wingsandwheels.com/pdf/30...Turbine01.pdf] The (proposed but in abeyance) Hollister jet club say about the Jet Shark's performance: "The best rate of climb is about 550 fpm at 75 knots and you still get 125 fpm at 95 knots." [http:// www.soarhollister.com/jet_club.htm] If correct that would be a big difference in performance between the two gliders for an extra 70% or so of thrust in the Shark. The Hollister site quotes a fuel consumption of 12 gal/hour which (assuming it is small US gallons) equates to 0.76 litres/min - pretty much the same as SH quote for the much less powerful Olympus. I am not sure that it all adds up - but it would be a hoot if it did! John Galloway |
Tim Mara wrote:
This data is I believe all quite accurate. Tim, when is HpH going to release to the public their performance figures from actual testing of the jet? It seems odd that the only figures available come from the Hollister web site. And those figures have been on the website for quite a while, so I believe they are (very optimistic?) projections, not results from actual testing. By now, HpH should have a very good idea of fuel consumption, climb rate, speed, and range. Yet I sure don't see this information anywhere on their site. The 304S isn't just another new version of an existing glider design with a model aircraft Jet attached. the engine used for the 304S is totally unlike the tiny jets used on other gliders it is computerized also so extension, starting and running are all done by one switch, shut-down and retraction are essentially the same. The complete extension, start up takes only a few seconds....and doesn't require priming, diving ect like the current sustainer systems, shut down is the same. Reasons being obvious, glider pilots may fly a motorized sailplane without having an airplane rating and even few airplane rated pilots are Jet trained....jest are quite simple in design, but are not operated as simply as your lawn mower and handing a Jet over to the would-be F-18 sailplane pilot without such controls could create some problems of it's own...even many recip sustainers have little or no controls the pilot can actually change. http://www.wingsandwheels.com/Hph%20new.htm tim |
I can't say when they will do any web updates.....sorry..they are naturally
more concerned and involved with production than web publishing but I'm sure this data will be published soon....the data from Hollister was from data given to them by HpH. The only delivered gliders so far have been pure gliders but all are built to accept any of the available engine options I have the latest published data on my website when I get it.... tim -- Please visit the Wings & Wheels website at www.wingsandwheels.com "Greg Arnold" wrote in message ... Tim Mara wrote: This data is I believe all quite accurate. Tim, when is HpH going to release to the public their performance figures from actual testing of the jet? It seems odd that the only figures available come from the Hollister web site. And those figures have been on the website for quite a while, so I believe they are (very optimistic?) projections, not results from actual testing. By now, HpH should have a very good idea of fuel consumption, climb rate, speed, and range. Yet I sure don't see this information anywhere on their site. The 304S isn't just another new version of an existing glider design with a model aircraft Jet attached. the engine used for the 304S is totally unlike the tiny jets used on other gliders it is computerized also so extension, starting and running are all done by one switch, shut-down and retraction are essentially the same. The complete extension, start up takes only a few seconds....and doesn't require priming, diving ect like the current sustainer systems, shut down is the same. Reasons being obvious, glider pilots may fly a motorized sailplane without having an airplane rating and even few airplane rated pilots are Jet trained....jest are quite simple in design, but are not operated as simply as your lawn mower and handing a Jet over to the would-be F-18 sailplane pilot without such controls could create some problems of it's own...even many recip sustainers have little or no controls the pilot can actually change. http://www.wingsandwheels.com/Hph%20new.htm tim |
| Thread Tools | |
| Display Modes | |
| Shark Mouth! | Jack G[_2_] | Aviation Photos | 0 | April 5th 08 02:37 AM |
| From The Movies: Black Shark - Black Shark(1993).jpg | Stas | Aviation Photos | 0 | November 12th 06 03:09 PM |
