Welded Patch Repair question
Old July 19th 08, 05:08 PM posted to rec.aviation.homebuilt
Michael Horowitz
Default Welded Patch Repair question
I'm working with 4130.
I have a piece of tubing with a series of rust holes which do not
cover an area greater than 1/2 ", so it appears a welded patch repair
would be appropriate.
Reading 43.13,, Figure 4-36, it appears the patch tube will have to be
expanded in diameter in order to fit over the injured tube (can't slip
the patch over the injured tubefrom an end).
Will there be any problem if I heat the patch so I can open open it
and slip it over the injured tubing? - Mike
Old July 19th 08, 09:14 PM posted to rec.aviation.homebuilt
Bruce A. Frank
You should use the next diameter of tube to get easy conformation the the shape of the tube you are repairing. But, if you have no choice but  to use a patch from the same diameter tube, there is no problem with heating the patch to make it plastic enough to conform to the outside contour of the tube being repaired. If it doesn't lay down smoothly you can tack welt the patch where it makes contact with the tube, then heat the patch with the torch and gently tap it into place, till it lies down tightly with the tube, with a small hammer. You can tap and tack as you go until the patch is a tight fit, the weld it.
If you want to make a slip over repair using a whole piece of tube, you will have to use the next diameter tube as it would be virtually impossible to expand the diameter of a tube uniformly and continuously around its circumference.
Michael Horowitz wrote: I'm working with 4130.
Old July 19th 08, 11:58 PM posted to rec.aviation.homebuilt
Michael Horowitz
Bruce - can't open it. Recommendation? - MIke
On Sat, 19 Jul 2008 19:14:38 GMT, "Bruce A. Frank"
Old July 20th 08, 12:01 AM posted to rec.aviation.homebuilt
Michael Horowitz
Nevermind; got it - Mike\
On Sat, 19 Jul 2008 17:58:18 -0400, Michael Horowitz
Old July 20th 08, 12:14 AM posted to rec.aviation.homebuilt
Michael Horowitz
Old July 20th 08, 11:43 AM posted to rec.aviation.homebuilt
Bruce A. Frank
Michael Horowitz wrote: Bruce - can't open it. Recommendation? - MIke
Old July 20th 08, 03:22 PM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Sat, 19 Jul 2008 11:08:36 -0400, Michael Horowitz
take a piece of flat 4130 of about the width needed for the job but a
little longer.
(think of toilet paper on the roll. width to match but longer)
tack weld one edge along the tube. it will hang out like b
now heat the flat sheet to red heat with an oxyacetylene torch and
while it is soft bend or gently hammer it down onto and around the
tube.when about half way through the bending trim to shape as
necessary. complete the bend then complete the edge weld all around
the piece.
I have a very neat repair on the auster done just this way.
Stealth Pilot
Old July 20th 08, 04:41 PM posted to rec.aviation.homebuilt
Michael Horowitz
On Sun, 20 Jul 2008 21:22:42 +0800, Stealth Pilot
little longer.
the piece.
Stealth Pilot
Thanks - Mike
Michael Horowitz
Old July 20th 08, 10:10 PM posted to rec.aviation.homebuilt
mhorowit
On Jul 20, 9:22*am, Stealth Pilot
I have a piece of tubing with a *series of rust holes which do not
Will there be any problem if I *heat the patch so I can open open it
little longer.
tack weld one edge along the tube. it will hang out like * * b
the piece.
Stealth Pilot
Stealth - so you placed a rectangle patch over the injury as opposed
to a diamond shape, or is that what you ment when you said "trim to
shape"? - Mike
Stressed Skin Repair Question RPM the A&P Home Built 9 July 16th 08 05:59 AM
4130 can't be OA welded? wright1902glider Home Built 61 January 4th 08 06:19 AM
Magneto Repair vs Overhaul Question. Ebby Home Built 6 February 24th 07 06:55 PM
172 Repair question Brad Mallard Home Built 2 June 11th 04 03:54 AM
172 Repair question Brad Mallard Aviation Marketplace 3 June 11th 04 03:54 AM
