#11
On Jul 29, 9:50*am, Bob Kuykendall wrote:
On Jul 27, 5:29*am, "01-- Zero One" wrote: For power especially, use ONLY Tefzel wire! Here we are again. Is Tefzel the best stuff to use these days? Yeah, pretty much, no disagreement there. Is it important to use good materials? Yup, pretty important. Is it the only stuff to use, the stuff that you must use? All-caps and exclamation point aside, it depends. I have only a couple of always/ never rules about aircraft wiring, and they're about fuses, not Tefzel. Comparatively speaking, I happen to think that how you wire things is more important than what you wire them with. Given the choice between organized bundles, well supported, appropriately fused, protected from abrasion, and kept away from moving parts, all executed in Electron Hut automotive wire, versus a rats nest of unmarked white Tefzel going every which way, I'll take my chances with the Electron Hut system. But, that's just me. I've written that all before. But here's some new information content: Be careful about drilling holes around wiring bundles, especially where you're drilling metal. In one of my current projects, we've found chips of aluminum swarf embedded in the Tefzel insulation of wires pretty deep within wiring bundles. We undertook a program to unwrap every accessible wiring bundle and clean out the chips, and now are taking special precautions to keep chips out in the first place. It's certainly a thing to think on. Thanks, Bob K. Bob, I actually agree, and while harping on components/tools it is what you do with them that matters. A good wiring job should just really look neat and tidy and organized. A look at the guts of a Duo- X had me impressed at factory wiring (for a change). Amongst the articles at http://www.aeroelectric.com/articles.html are some related good discussions on proper workmanship and fuses/breakers etc. And why several glider manufacturers use no color coding or labeling or seem happy to put out a rats nest of wiring is beyond me. Part of my grumpiness about this stuff is having experienced wiring relate problems, including electrical shorts etc. Darryl |
On Jul 28, 9:10*pm, ContestID67 wrote:
Couldn't agree more on the use of tefzel. It is an FAA requirement. Would you please tell me what regulation specifes the use of Tefzel wiring in gliders. I'm particularly interested since my nearly new glider came from the factory with wiring that appears to be PVC insulated. Although my serial number is Experimental the model now has an FAA standard airworthiness certificate. thanks Andy |
On Jul 29, 1:00*pm, Andy wrote:
On Jul 28, 9:10*pm, ContestID67 wrote: Couldn't agree more on the use of tefzel. *It is an FAA requirement. Would you please tell me what regulation specifes the use of Tefzel wiring in gliders... Color me confuseled as well. I've designed sailplane control systems to the dictates of 14 CFR part 23 (and JAR 22, they're quite similar), and I often use AC43.13 as a guideline, so I'm pretty familiar with those FAA resources. But I can't find any material in either that dictates the use of Tefzel or its generic ETFE. Furthermore, those of us operating Experimental, Amateur-built aircraft are not bound by the dictates of either part 23 or AC43.13. Those of us operating Experimental, Exhibition or Experimental, Racing may or may not be so bound, depending on the specific language of the operating limitations document that must accompany the special airworthiness certificate. Thanks, Bob K. |
Bob, we don't really disagree about much of anything in this discussion.
However, this is not an Advisory Circular. It is a discussion on "usenet" where opinions are like buttholes... everybody has one. That is why when I say "For power especially, use ONLY Tefzel" I am hoping that if folks do not pickup on anything else said in this exchange, they will remember that. It is the same reason that I say emphatically "ABSOLUTELY mount a 3-5 amp fuse on each battery!!!!!" As you have surely found in your considerable experience, glider wiring as a whole is abysmal! If the plane is more than a couple of years old, there is going to be some sort of rube goldberg, thrown together battery connection, or what-have-you. So if they have a rats nest but somehow replaced the zipcord and speaker wire with Tefzel along the way, they will at least not be filling up the cockpit instantaneously with acrid, harmful smoke when the accidental short happens under the seatpan. And if they heard my second point and actually put a fuse on the battery, they will do nothing but blow the fuse and not roast their rump. So, while I agree that if they used all the best aviation wiring practices that you mention below about organization, strain relief, abrasion free, etc. but chose to use Radio shack wire, they would most likely never have a problem. But that, from my experience, is never going to happen. Some of the brightest pilots I know somehow believe that when it comes to wiring, just throwing something together will suffice. Regards, Larry "Bob Kuykendall" wrote in message : On Jul 27, 5:29 am, "01-- Zero One" wrote: For power especially, use ONLY Tefzel wire! Here we are again. Is Tefzel the best stuff to use these days? Yeah, pretty much, no disagreement there. Is it important to use good materials? Yup, pretty important. Is it the only stuff to use, the stuff that you must use? All-caps and exclamation point aside, it depends. I have only a couple of always/ never rules about aircraft wiring, and they're about fuses, not Tefzel. Comparatively speaking, I happen to think that how you wire things is more important than what you wire them with. Given the choice between organized bundles, well supported, appropriately fused, protected from abrasion, and kept away from moving parts, all executed in Electron Hut automotive wire, versus a rats nest of unmarked white Tefzel going every which way, I'll take my chances with the Electron Hut system. But, that's just me. I've written that all before. But here's some new information content: Be careful about drilling holes around wiring bundles, especially where you're drilling metal. In one of my current projects, we've found chips of aluminum swarf embedded in the Tefzel insulation of wires pretty deep within wiring bundles. We undertook a program to unwrap every accessible wiring bundle and clean out the chips, and now are taking special precautions to keep chips out in the first place. It's certainly a thing to think on. Thanks, Bob K. |
On Jul 28, 9:10*pm, ContestID67 wrote: Couldn't agree more on the use of tefzel. *It is an FAA requirement. On Jul 30, 6:18 am, Bob Kuykendall wrote: Would you please tell me what regulation specifes the use of Tefzel wiring in gliders... Valid comment. I shouldn't be so blith with my use of the "FAA" word. Let me rephrase. Every book I have ever read about aviation wiring, and every aviation tech I have ever worked with, and every A&P who has every looked over my shoulder and signed my log book, has always required Tefzel (ETFE). Now, if that isn't an implicite FAA requirement, I don't know what is. However, there must be something in the regs that is driving all this. While there probably isn't a reg that says "you must use ETFE", is there one that says something about wiring being; Abrasion resistant? Burn resistant? Doesn't release toxins? Doesn't fray? If there isn't an FAA reg on this, I can start going back to Radio Shack. ;-) Only kidding...really. However, when I council a newbie about why his wiring is just plain wrong, why he shouldn't use spade lugs, and why fuses at batteries (!) are a necessary thing, etc, etc, I often blithly spead the "FAA" word around to put the fear of God in them. I will probably continue that habit. And I don't care if it is standard certified or experimental, my (high) standards are all the same. It keeps life simpler that way. My $0.02. - John DeRosa |
On Jul 30, 4:31*am, ContestID67 wrote:
However, when I council a newbie about why his wiring is just plain wrong, why he shouldn't use spade lugs, and why fuses at batteries (!) are a necessary thing, etc, etc, I often blithly spead the "FAA" word around to put the fear of God in them. I will probably continue that habit. *And I don't care if it is standard certified or experimental, my (high) standards are all the same. *It keeps life simpler that way. Thanks for your well-reasoned approach. We definitely agree on the major points he It's important to think things out before you do them, to do quality work, and to use good materials. But I'm still concerned that saying something is an "FAA requirement" when it's really not sets a bad precedent. As we've see with the 337 process, when you say something like that too often, pretty soon even the FAA believes it, and then they start to demand it even in cases where it's downright silly. The next thing you know, you get ramp- checked and then lose a day at the Nationals because the 24ga wire to the 9-volt battery of your gear warning system, a wire carrying at most a few milliamps, isn't FAA-PMA stamped Tefzel(tm) brand wire. And don't laugh, sillier things have happened. Thanks again, Bob K. |
However, when I council a newbie about why his wiring is just plain wrong, why he shouldn't use spade lugs.. Ok, now I'm curious again. What sort of battery do you use to power your glider systems and what sort of terminals does it have? thanks Andy |
I dont think he's referring to batteries with this phrase. He's
probably talking about not using spade lugs on terminal blocks (where ring connectors should be used). All of the small VRLA batteries that I've seen in sailplanes have Faston connectors, so Faston "spade lugs" would have to be used there. -John On Jul 31, 10:15 am, Andy wrote: On Jul 30, 4:31 am, ContestID67 wrote: However, when I council a newbie about why his wiring is just plain wrong, why he shouldn't use spade lugs.. Ok, now I'm curious again. What sort of battery do you use to power your glider systems and what sort of terminals does it have? thanks Andy |
On Jul 31, 7:15*am, Andy wrote:
On Jul 30, 4:31*am, ContestID67 wrote: However, when I council a newbie about why his wiring is just plain wrong, why he shouldn't use spade lugs.. Ok, now I'm curious again. *What sort of battery do you use to power your glider systems and what sort of terminals does it have? thanks Andy Faston = blade connector (typically used in 1/4 wide blades for glider applications) is not a spade connector. AGM batteries will typically have a Faston style connector or larger ones will have a screw binding post (like the batteries on my ASH-26E - which gets crimp on ring connectors not a spade connector to connect to the batteries) . Faston blade connectors (use nylon fully insulated where possible) are very suitable for use in aircraft, see again my favorite source http://www.aeroelectric.com/articles/faston3.pdf Crimp on ring connectors should be used on binding posts instead of spade connectors which can simply fall out easily. However like the article above advocates a Faston style binding block is even easier to use, and is tool free. Properly done the Faston style binding blocks will not come undone. Many things like fuse holders and switches also are available with Faston blade connections, if nothing else they are a good idea since you do not need to get a screwdriver down inside some hard to reach place and/or risk dropping a screw into the guts of your glider. Schleicher uses Faston style binding blocks in their gliders. Cobra uses them in their trailers, ... Darryl |
On Jul 31, 8:35*am, Darryl Ramm wrote:
Spade ... blade.... I thought they were the same thing so obviously I don't speak American very well yet. When I look up spade connector it looks more like a fork to me. In fact fork lug is also, perhaps more commonly, used to describe this terminal type. Agree they are not the best choice but they do make life a lot easier if one terminal has to be removed from a stack. Andy |
| Thread Tools | |
| Display Modes | |
| Caption This !! (2 sizes) | Square Wheels[_2_] | Aviation Photos | 18 | December 18th 06 01:01 AM |
| instrument sizes | Bill Chernoff | Home Built | 9 | September 21st 06 09:28 PM |
| Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) | Striker Cat | Home Built | 6 | October 15th 04 09:51 PM |
| Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) | Striker Cat | General Aviation | 0 | October 12th 04 06:11 PM |
| Cockpit sizes of standard Jantar | goneill | Soaring | 2 | December 28th 03 12:29 PM |
