Battery cable selection
Old August 4th 08, 08:21 PM posted to rec.aviation.homebuilt
Default Battery cable selection
I am putting two 12V batteries together
http://www.batterymart.com/p-hawker-...t-battery.html
to make a 24V battery.
What size cable should I use to make the serial connection?
http://shop.genuinedealz.com/Marine%...ttery%20Cable/
Thanks,
Karl
Old August 4th 08, 08:31 PM posted to rec.aviation.homebuilt
Morgans[_2_]
Same size as the main battery cable. It will see the same amperage.
Jim in NC
Old August 4th 08, 09:36 PM posted to rec.aviation.homebuilt
oilsardine[_2_]
no, it will see half the amperage at same wattage
"Morgans" schrieb im Newsbeitrag
Jim in NC
Old August 4th 08, 10:08 PM posted to rec.aviation.homebuilt
Vaughn Simon
"oilsardine" wrote in message ...
Huh? You are joking...right?
Vaughn
Capt. Geoffrey Thorpe
No Jim was correct. The amperage is the same.
It is a series circuit - the amperage is the same throughout.
If you were wiring two batteries in parallel (and getting 12 volts from the
pair), then each battery would deliver 1/2 the amps (approx.)
Geoff
Old August 4th 08, 11:45 PM posted to rec.aviation.homebuilt
RST Engineering
Kirchoff is rolling over in his grave.
"It is the mark of an educated mind to be able to entertain a thought
without accepting it."
--Aristotle
Old August 5th 08, 12:54 AM posted to rec.aviation.homebuilt
Peter Dohm
"RST Engineering" wrote in message
m...
He obviously needs the exercise.... ;-)
Peter
Node theory sux!
Old August 5th 08, 07:32 AM posted to rec.aviation.homebuilt
jan olieslagers[_2_]
I guess that should read Kirchhof, should anyone wish to google it up.
For one example, see http://www.allaboutcircuits.com/vol_1/chpt_6/4.html
Old August 5th 08, 07:41 AM posted to rec.aviation.homebuilt
Hm. Actually it is Kirchhoff.
Nothing like German for spelling confusion.
Old August 5th 08, 07:46 AM posted to rec.aviation.homebuilt
oilsardine[_2_]
not sooo fast, Mr.L'ectrzity!
supposed this guy got some bargain instuments (or radios, or starter or
whatever else) BUT these are 24 volt units then you could come to this
conclusion to join two batteries. In this case you will have half of the
current flow compared to a 12V system. So you can use half the cross section
of your cabling. Basic electics.
"RST Engineering" schrieb im Newsbeitrag
m...
--Aristotle
Battery Cable Connectors Paul Remde Soaring 0 September 15th 06 05:33 AM
France from the air : selection Benoit Piloting 1 December 19th 04 05:42 PM
Engine selection Omri Kalinsky Home Built 1 November 18th 04 10:06 PM
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) Striker Cat Home Built 6 October 15th 04 08:51 PM
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) Striker Cat General Aviation 0 October 12th 04 05:11 PM
