vintage powered glider
Old August 13th 08, 08:25 PM posted to rec.aviation.soaring
Bob Kuykendall
Default vintage powered glider
On Aug 13, 11:10*am, Chip Starr wrote:
...It is a Hawk model 3 *1963 powered sailplane...
Never heard of it. Is it a production unit, or a one-off homebuilt? Do
you have a photo of it? Also, the N-number might give us a clue.
One thing to watch for is that aircraft homebuilders will sometimes
construct an aircraft from a kit or from plans, and then register it
as having a type completely unrelated to original design. For example,
I've seen RVs and HPs show up as type "QS-1" and stuff like that.
There is absolutely no rule that says that a homebuilder has to
register the aircraft they built from their RV-6 kit as an "RV-6." The
homebuilder is the manufacturer of record, and they can call it
anything they want.
As for value, that could be anywhere on the map depending on
condition, performance, utility, and historical value. If you're the
owner, the most practical way of determining the value is to offer it
for sale and see what people offer for it. And for that, you might
find that eBay is your best bet.
Thanks, Bob K.
Old August 13th 08, 09:15 PM posted to rec.aviation.soaring
vontresc
anything they want.
Thanks, Bob K.
Wow that is one ugly airplane.....
http://1000aircraftphotos.com/Contri...avidJ/7500.htm
Pete
Old August 13th 08, 09:23 PM posted to rec.aviation.soaring
Vaughn Simon
"vontresc" wrote in message
Ugly yes! But it has an amazingly unique propeller stowing scheme.
Vaughn
Nothing personal, but if you are posting through Google Groups I may not receive
your message. Google refuses to control the flood of spam messages originating
in their system, so on any given day I may or may not have Google blocked. Try
a real NNTP server & news reader program and you will never go back. All you
need is access to an NNTP server (AKA "news server") and a news reader program.
You probably already have a news reader program in your computer (Hint: Outlook
Express). Assuming that your Usenet needs are modest, use
http://news.aioe.org/ for free and/or http://www.teranews.com/ for a one-time
$3.95 setup fee.
Will poofread for food.
Old August 13th 08, 09:36 PM posted to rec.aviation.soaring
Bob Kuykendall
Good catch! I did a few searches before giving up.
Does anybody else think that the fuselage and vertical fin (what we
can see of them) looks a lot like LK-10A/TG-4 truncated at the front
cockpit? The wing is obviously in the wrong location for an LK
fuselage, but that could easily be a modification.
Say what you want about the aesthetics, but the retractable cowl
cheeks and pivoting engine are a pretty nifty solution to the problems
of engine-off cooling drag and prop drag.
Thanks, Bob K.
Old August 13th 08, 09:49 PM posted to rec.aviation.soaring
JJ Sinclair
Yep, it looks like the illegitimate offspring of an LK-10 with a put-
put.
JJ
Vintage glider newsreels. Excellent! [email protected] Soaring 2 May 3rd 08 09:08 AM
FAA Powered Glider Definition Mike Schumann Soaring 4 July 20th 07 06:26 PM
jet powered personal glider [email protected] Owning 18 March 15th 05 11:07 PM
Powered gliders = powered aircraft for 91.205 Mark James Boyd Soaring 2 December 12th 04 03:28 AM
Odp: Vintage Glider PWS 102 PWS 101 Janusz Kesik Soaring 0 September 29th 03 08:25 PM
