Rudder from a different Mudder
Old August 14th 08, 03:04 AM posted to rec.aviation.soaring
Default Rudder from a different Mudder
On Aug 13, 9:17*pm, Brad wrote:
I finally finished the rudder for the HP-24 today. It weighs without
mass balance 5 pounds. Wondering if any folks out there know what
there rudder might weigh, with or without mass balance. I am curious
where on the curve I am with the one I designed and built. I should
say, this has an antenna inside and a lot of paint on it.
I painted it with Prestec. After a few less than satisfactory spray
results with a lacquer gun I went out and bought an HVLP conversion
gun. Maybe because it is a really cheap gun, but the thing sucks. So I
called Simtec, the makers of Prestec for some advice. I set the HVLP
gun up as recommended, did a few test sprays on some cardboard, and
immediately knew this was not going to work...............so I poured
the paint into the lacquer gun, bumped the PSI to 45, opened up the
flow rate and got the results I was after. The first cut was easily
done with 600 grit wet, tomorrow I pick up a sleeve of 800, then on to
1000-1200-1500-2000 and the buff and cut process.
So far am pretty happy, may have to fix a few pin holes, but we'll
see.
Cheers,
Brad
From ASW-27 Manual- rudder about the same size.
Mass- 3.4- 4.2 kg.
Permissible moment 1.94-2.34 kgcm.
Don't worry about gelcoat not looking nice. It almost never does. It
ain't paint!
Fun watching you guys do your thing.
Good Luck
UH
Old August 15th 08, 08:35 AM posted to rec.aviation.soaring
Bob Kuykendall
Mass- 3.4- 4.2 kg.
Permissible moment *1.94-2.34 kgcm.
Thanks for that data, it is very helpful!
Bob K.
more rudder to the right???? [email protected] Piloting 1 August 6th 08 04:09 PM
WTD. SGS 2-33 Rudder [email protected] Soaring 0 December 20th 06 04:31 AM
WTB. SGS 1-35 Rudder [email protected] Soaring 0 July 22nd 06 07:28 PM
c-152 rudder??? houstondan Owning 39 December 21st 04 09:21 PM
c-152 rudder??? houstondan Owning 28 December 15th 04 09:55 PM
