Actually I think it was determined in the sailplane circles.. that having
the CG at the 85% point was the most efficient.. too far aft was too much and caused nose down stick putting the elevator down into the slip stream, and not far enough aft caused back stick or up elevator into the slip stream. Heavier pilots do add tail ballast which increases the minimum pilot weight for club gliders. BT Just to add a bit of noise to the discussion, an airplane operating at maximum allowed aft CG is actually more aerodynamically efficient. Sailplane pilots often add tail ballast for just this reason. -- Vaughn |
Ground adjustable prop | [email protected] | Home Built | 1 | January 30th 05 06:15 AM |
adjustable prop bearing | Joe | Home Built | 5 | October 23rd 04 12:00 PM |
Cessna Prop Needed | Cy Galley | Aviation Marketplace | 0 | January 23rd 04 01:23 AM |
Hydraulic CS prop converting to Adjustable prop? | Scott VanderVeen | Home Built | 0 | December 5th 03 05:54 PM |
Adjustable prop experience? | Richard Lamb | Home Built | 0 | July 1st 03 04:07 AM |
