G102 spigot AD??? What's the status...
Old August 21st 08, 12:45 PM posted to rec.aviation.soaring
toad
Default G102 spigot AD??? What's the status...
On Aug 21, 4:24*am, Don Johnstone wrote:
Is this alarming?
In 1971 the Design Authority issued an Airworthiness Directive mandating
the replacement of wing spigots on the Grob 102, following a failure on
the Grob 103. Aircraft manufacturers/Design Authorities do not issue
directives, which by their name are mandatory, for the fun of it, in fact
doing so indicates that have screwed up. The work mandated is essential.
Unless I have this completely wrong the FAA decided they knew better and
did not pass this on.
My concern is, how many other AD issued by Design Authorities have been
ignored by the FAA and is it really safe to fly in a glider, or any other
aircraft on the USA register? Can we be assured that essential safety
maintenance has been done?
Looking at the evidence of the Grob 102 the answer has to be no.
Have the FAA ignored other ADs issued by European manufacturers, Airbus
Industrie perhaps?
Scary!!!!!!!
Well, if the European/German equivalent of the FAA issues an AD then
the FAA pretty much automatically issues one as well, but since Grob
only issued a service bulletin, the FAA did not automatically issue an
AD.
Todd Smith
Old August 21st 08, 01:39 PM posted to rec.aviation.soaring
Gary Emerson
Is this alarming?
Industrie perhaps?
Scary!!!!!!!
At 00:23 16 August 2008, Gary Emerson wrote:
I heard an AD was being considered for the wing spigots on the Grob 102s
(US version AD). Any definite info on where this is headed and when?
Thanks,
Gary
This is a question, not a statement...
There is reference to an incorrect material selection in the G103
spigots. Does anyone know if the correct material was used in the G102
spigots?
Old August 21st 08, 02:09 PM posted to rec.aviation.soaring
Don Johnstone[_3_]
Is this alarming?
mandating
on
fact
essential.
and
been
other
Airbus
Industrie perhaps?
Scary!!!!!!!
102s
Thanks,
Gary
spigots?
Difficult, the problem with the G103 spigots was that allegedly they were
manufactured from steel which did not meet the design specification,
however this appears to have prompted a rethink on the whole question of
wing spigot material spec and it would appear that the design authority
was of the view that the existing spec was not good enough, hence the
redesign.
The answer to your specific question is that the G102 spigots were
manufactured to the spec in force at the time they were made but did not
meet the later required spec.
It is true that a service bulletin was issued but make no mistake this was
an Airworthiness Directive taken up by the LBA and the CAA and as far as I
am aware the rest of the world excluding America.
This is getting more scary by the minute.
Don Johnstone[_3_]
Is this alarming?
mandating
on
fact
essential.
and
been
other
Airbus
Industrie perhaps?
Scary!!!!!!!
102s
Thanks,
Gary
spigots?
redesign.
Old August 21st 08, 02:40 PM posted to rec.aviation.soaring
Tim[_1_]
redesign.
I'm flying one and I'm not the least bit scared. Seems to me that if there
was going to be a problem it would have shown itself sometime in the last 19
yrs or so, eh?
Old August 21st 08, 03:31 PM posted to rec.aviation.soaring
JJ Sinclair
redesign.
I'm flying one and I'm not the least bit scared. *Seems to me that if there
yrs or so, eh?
And now, JJ's take on the big Grob spigot (and other) screw-ups! Grob
welded the spigots on the G-102 and G-103 to a steel plate and the
British air academy tested a wing and got a crack to form after 10,000
simulated winch launches. Grob came out with a fix where the spigot
screwed into the steel plate. While performing this AD, they also
fixed another little problem to make sure the spigot from one wing
went into the bearing on the other wing, correctly...........some were
found to be a good 10mm short of where they should have been which
meant the spigot arm was loaded farther out than intended. While they
were at it, they also fixed a bunch of control cranks and fittings
that an idiot could see weren't string enough. I owned two G-103's at
the time and had to fork out about $3000 bucks each to fix Grob's
mistakes. A service bulletin was also published to fix the spigots on
the G-102, but for some reason it didn't appeas as an AD at that
time.
Anybody want to discuss Grob's using cast aluminum parts in flight
controls? Type in Grob on the FAA's AD page and just look at what
comes up! I think the G-102 is one of the nicest handling ships I have
ever flown, it has good control harmonics...................but Grob's
engineering sucks.
RIP Grob,
JJ
Old August 22nd 08, 12:09 AM posted to rec.aviation.soaring
Don Johnstone[_3_]
there
last
19
yrs or so, eh?
Funny old thing, nobody noticed anything wrong with the Grob 103 until the
spigot sheared, at least it happened on the rig.
The design authority, LBA and CAA considered it vital enough to issue a
mandatory AD but who are they to know.
When I said scary I was thinking more of all the other aircraft on the US
register that are flying about. Have ADs for them been ignored as well?
Grob G102 Astir Spar Spigot Assembly AD NPRM BDS Soaring 4 August 30th 07 04:13 PM
Grob G102 Setup BDS Soaring 11 August 30th 05 03:42 PM
Wheel Brake on G102 Ken Pruchnick Soaring 4 March 2nd 05 07:01 AM
