Grob G102 Astir Spar Spigot Assembly AD NPRM
Old August 10th 07, 02:55 PM posted to rec.aviation.soaring
BDS
Default Grob G102 Astir Spar Spigot Assembly AD NPRM
Looks like we have until the end of the month to try to head this off:
http://www.airweb.faa.gov/Regulatory...8?OpenDocument
BDS
Old August 10th 07, 06:19 PM posted to rec.aviation.soaring
HL Falbaum
When the G103 AD was done, what percentage were found cracked? Have any G102
spigots been found cracked?
Is this a real problem or a CYA move?
Hartley Falbaum
"BDS" wrote in message
BDS
Old August 29th 07, 09:59 PM posted to rec.aviation.soaring
John H. Campbell
That would be today, actually:
DATES: We must receive comments on this proposed AD by August 29, 2007
I counted 9 comments as of this morning (8 negative, 1 misplaced?).
Most everyone that has spoken up seems to find the PR out of date,
unnecessary, unjustified, burdensome, counter-productive and so on. The
75 owners out there ought to speak up right away if they wish to be
heard. It's easily done by electronic submission (fill-in form).
Old August 30th 07, 02:33 PM posted to rec.aviation.soaring
Don Johnstone[_2_]
Hartley Falbaum
The G103 spigot problem was due to faulty materials
in the manufacture of the spigot. Almost all of the
aircraft which used the faulty spec steel were found
to be cracked to some extent. The fix introduced replaceable
spigots so in the event of a future problem with the
spigots they can just be unscrewed and replaced.
The was a mandatory AD from Grob and the LBA in 1992
for the wing spigots to be replaced on G102 gliders
and certainly this mod was carried out in the UK. Looks
like you are just catching up with the rest of the
world.
Old August 30th 07, 05:13 PM posted to rec.aviation.soaring
Bob Kuykendall
in the manufacture of the spigot...
I think it might have been a bit more complicated than that. Back when
the Grob Spigot-Fixin' team was on their US Grand Tour, I saw the old
and new spigots side by side. I don't remember the exact details of
the design beyond that it was a plate of steel with a cylindrical
protrusion emerging from one edge. But I do remember thinking that the
old style was somewhat casual in its execution, while the new looked
much more robust, with much more of the filleting you'd want for good
fatigue resistance.
Grob 102 Astir Std III [email protected] Soaring 0 May 30th 07 10:27 PM
Grob Astir AD spar spigots toad Soaring 20 May 19th 07 05:57 PM
FS - Grob Speed Astir IIB Fred Soaring 3 February 18th 06 04:22 PM
FS - Grob Speed Astir IIB Steve Leonard Soaring 0 February 17th 06 04:42 AM
Grob G102 Setup BDS Soaring 11 August 30th 05 04:42 PM
