instrument panel material
Old September 13th 08, 05:48 PM posted to rec.aviation.homebuilt
jan olieslagers[_2_]
Default instrument panel material
Oliver Arend schreef:
So ok, I'll go for 1,5 mm aluminium but am not sure
what grades might be available here in Belgium,
not even sure we have the same codification.
Europe uses the same codification for aluminum alloys, the full name
you would be looking for is "EN AW-6061T6" (AW for wrought aluminum),
which corresponds to "EN AW-Al Mg1SiCu" (for sheet metal see European
norm EN 485, for bars see EN 754 and 755).
Well that's what I'd call a complete answer, danke schoen!
KA
Old September 14th 08, 12:47 AM posted to rec.aviation.homebuilt
jerry wass
KA
If you get all your holes cut with no scratches, you might want to
anodize it that purty purple color you like..Jerry---but remove the
instruments first !!
Old September 14th 08, 01:36 AM posted to rec.aviation.homebuilt
Lou
Mine will be out of wood then covered with laminate.
Lou
Instrument Panel ccwillwerth Home Built 7 February 9th 06 02:15 PM
DG-300 instrument panel [email protected] Soaring 14 January 29th 06 02:48 PM
LS 6 b instrument panel John Brenann Soaring 4 November 19th 05 04:37 AM
Instrument Panel Paint [email protected] Owning 0 May 1st 05 02:54 PM
ASW20A instrument panel available goneill Soaring 1 November 2nd 04 08:32 AM
