On Sep 19, 5:19*pm, (Alan) wrote:
In article writes: * The FAA prohibits the use in flight in 91.21, but that generally doesn't apply to VFR flight in small aircraft. *(It essentially forbids use in airliners and IFR flight.) * The FCC prohibits use in any aircraft when airborne. * The iPhone is being "operated" when it is updating map data. *It is even being operated when it is turned on and talking to cell towers. Yeah, and no one in a small place ever broke that one. But it doesn't matter. Any specialized gliding program can easily be written to preload the relevant maps before takeoff. You do have 8 GB or 16 GB of storage for such things. That's the equivalent of 10 - 20 CDs of data. * To be legal, turn it off, or put it in airplane mode, before takeoff --- and leave it that way until back on the ground. The GPS and accelerometer and so forth will work just fine in airplane mode. Unfortunately they both turn off if the screen turns off (by hitting the button on the top, or after a timeout if you haven't disabled it). * Better to save the battery to make a call if you land out. Operating the GPS continuously eats the battery. Any serious gliding application will want to run the iPhone off the glider's battery in any case. |
Alan wrote:
I just took my new 3G for a flight. gpstracker application works very well to track flights on google earth. Also gives Long/Lat speed as well as altitude every 5 seconds. Check it out. It might be fun, but it is also quite illegal. 47 cfr 22.925 states: 22.925 Prohibition on airborne operation of cellular telephones. [snip] Aside from the use of "airplane mode", I seem to recall a discussion about this a while ago wherein it was concluded that modern mobile phones don't meet the FCC's definition of a "cell phone". The reasoning behind this regulation is that using a cell phone in flight plays merry havoc with the cell network due to seeing towers farther away than the network is designed for. But modern networks work differently and are immune to this problem, and I *think* the conclusion was that the regulation does not apply to them. Anyone know more about it? I'd like to know more than my patchwork memory.... -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon |
On Fri, 19 Sep 2008 10:25:42 -0500, Michael Ash wrote:
Anyone know more about it? I'd like to know more than my patchwork memory.... In the UK, anyway, the base station transmission patterns are quite flat which can stop you getting a signal in the air. A year or two back I wanted to annoy a friend with the "ring him and hold phone by the audio vario" trick, but at 3000ft over Huntingdon, i.e. above a flat bit of Cambridgeshire, there was no signal at all. I was using a GSM phone, so the radiation pattern was evidently flat enough the exclude not only Huntingdon masts but also those further away (Cambridge, Northampton). This makes sense to me. Why should a telco waste electricity transmitting a hemispherical pattern when a pancake pattern will give a better signal strength for less radiated power throughout its service area. IIRC this has been noticed and commented on in the USA too. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
![]() "Martin Gregorie" wrote in message ... On Fri, 19 Sep 2008 10:25:42 -0500, Michael Ash wrote: Anyone know more about it? I'd like to know more than my patchwork memory.... In the UK, anyway, the base station transmission patterns are quite flat which can stop you getting a signal in the air. A year or two back I wanted to annoy a friend with the "ring him and hold phone by the audio vario" trick, but at 3000ft over Huntingdon, i.e. above a flat bit of Cambridgeshire, there was no signal at all. I was using a GSM phone, so the radiation pattern was evidently flat enough the exclude not only Huntingdon masts but also those further away (Cambridge, Northampton). This makes sense to me. Why should a telco waste electricity transmitting a hemispherical pattern when a pancake pattern will give a better signal strength for less radiated power throughout its service area. IIRC this has been noticed and commented on in the USA too. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | My experience with Verizon in the US is that it usually works fine from a glider. I used it once to call a tower after my radio failed - but they didn't answer. They later told me that they couldn't take time to answer the ringing phone, "because there was some guy in a glider with an inoperative radio" they had to deal with. Instead they just shot me a green light and I landed. |
In article Martin Gregorie writes:
On Fri, 19 Sep 2008 10:25:42 -0500, Michael Ash wrote: Anyone know more about it? I'd like to know more than my patchwork memory.... In the UK, anyway, the base station transmission patterns are quite flat which can stop you getting a signal in the air. A year or two back I wanted to annoy a friend with the "ring him and hold phone by the audio vario" trick, but at 3000ft over Huntingdon, i.e. above a flat bit of Cambridgeshire, there was no signal at all. I was using a GSM phone, so the radiation pattern was evidently flat enough the exclude not only Huntingdon masts but also those further away (Cambridge, Northampton). This makes sense to me. Why should a telco waste electricity transmitting a hemispherical pattern when a pancake pattern will give a better signal strength for less radiated power throughout its service area. Interesting. Generally, the attenuation possible from an antenna depends on the angle of elevation, and if you are 5 miles from the tower, at 3000 feet, you would be 6.5 degrees of elevation above horizontal, which should be well within the pattern of the antenna. (Any reduction would be easily made up by the very clear path to the tower.) I have noticed the same effect on top of mountains here -- at 2600 feet elevation, looking out at the populated areas, there is no signal. HOWEVER --- If I walk away and hide behind a building, I get nice strong signal. There are a limited number of channels where the cell system transmits control information. When the phone is not on a call, it listens to one of them. Each cell site (tower) has one (or perhaps more) channel for this control information. Like cell calls, it is not re-used until a "safe" distance away. When on top of a mountain, there are dozens of towers within sight. Unfortunately, every available channel is in use by several of these towers. Thus, the phone cannot receive a clear control signal on any of the control channels -- each is a jumbled mess of several sites transmitters. Much the same happens in the glider. Hiding behind the building, a few feet back from the edge of the mountaintop blocks many of these signals. The phone found a good one, and used it. IIRC this has been noticed and commented on in the USA too. And I strongly believe that the signal pattern of the antennas is not the cause of the problem, or stepping a bit behind the building would not have made the phone work, as the pattern would have been the same. Alan |
Alan wrote:
A year or two back I wanted to annoy a friend with the "ring him and hold phone by the audio vario" trick, but at 3000ft over Huntingdon, i.e. above a flat bit of Cambridgeshire, there was no signal at all. I was using a GSM phone, so the radiation pattern was evidently flat enough the exclude not only Huntingdon masts but also those further away (Cambridge, Northampton). This makes sense to me. Why should a telco waste electricity transmitting a hemispherical pattern when a pancake pattern will give a better signal strength for less radiated power throughout its service area. Interesting. Generally, the attenuation possible from an antenna depends on the angle of elevation, and if you are 5 miles from the tower, at 3000 feet, you would be 6.5 degrees of elevation above horizontal, which should be well within the pattern of the antenna. (Any reduction would be easily made up by the very clear path to the tower.) More phones means the cells have to be smaller. Many/most of towers around here have a number of what appear to be VERY directional antennas, and the towers are low ( 100'), and surely very low power, because the next tower is only a mile or two away. They aren't going to reach out to 5 miles, even under the best of conditions. The loss of signal at 3000' or so is common where the cells a small, such as near cities. The rural areas often work to higher altitudes, if they have coverage in the area. My old analog/TDMA phone used to work very well to even 15000' agl, but my new TMobile GSM phone is unreliable off the ground, and worthless at our 7000-9000 agl soaring altitudes, even in our mostly rural Eastern Washington. I suspect there is a lot of variation between providers; even so, I think it's just going to get worse as the cells get smaller yet. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
In article %K%Ak.553$8v5.378@trnddc01 Eric Greenwell writes:
More phones means the cells have to be smaller. Many/most of towers around here have a number of what appear to be VERY directional antennas, and the towers are low ( 100'), and surely very low power, because the next tower is only a mile or two away. They aren't going to reach out to 5 miles, even under the best of conditions. On the ground, where there are obstacles, that is true. To an airborne receiver, the range is much farther. Don't be sure about that low power -- the directional antennas have a fair amount of gain. The FCC allows 500 watts per channel of effective radiated power, but 100 watts is a more common figure. (See: http://www.fcc.gov/cgb/consumerfacts/rfexposure.html ). Even a very small amount of power to them will provide far more than 5 miles range. In fact, one of the noted problems of GSM is that the timing of the system is the timing induced range limit of about 25 miles, but an extended variant increases this substantially. Fishermen off the coast of the U.S. use cell phones out well past 25 miles. I have used cellphones over 8 miles offshore, and apparently glider pilots carry them in case of land outs in some pretty remote areas. Alan wa6azp |
Alan wrote:
In article %K%Ak.553$8v5.378@trnddc01 Eric Greenwell writes: More phones means the cells have to be smaller. Many/most of towers around here have a number of what appear to be VERY directional antennas, and the towers are low ( 100'), and surely very low power, because the next tower is only a mile or two away. They aren't going to reach out to 5 miles, even under the best of conditions. On the ground, where there are obstacles, that is true. To an airborne receiver, the range is much farther. And yet, I can have good service on the ground, but poor or no service in the air, over the same area. It's not about obstacles, but antenna patterns, power, and how the system handles a phone that is reaching multiple towers. Don't be sure about that low power -- the directional antennas have a fair amount of gain. The FCC allows 500 watts per channel of effective radiated power, but 100 watts is a more common figure. (See: http://www.fcc.gov/cgb/consumerfacts/rfexposure.html ). From the article: "the majority of cellular or PCS cell sites in urban and suburban areas operate at an ERP of 100 watts per channel or less". The "or less" is important, as a small cell doesn't require much power. The ERP is obtained with directional antennas, so while it might seem high, the vertical angle coverage is very shallow. A cell set up for an Interstate highway will have to use much more power as the cells are farther apart, and the pattern might be broader, so aircraft near a highway might experience better reception. Even a very small amount of power to them will provide far more than 5 miles range. In fact, one of the noted problems of GSM is that the timing of the system is the timing induced range limit of about 25 miles, but an extended variant increases this substantially. Fishermen off the coast of the U.S. use cell phones out well past 25 miles. And maybe a cell phone used in the air in those areas would work well. It's not a place glider pilots have much experience with! THe coast is a different situation than a inhabited area, and I'm guessing the antenna power and pattern are likely quite different because of that. I have used cellphones over 8 miles offshore, and apparently glider pilots carry them in case of land outs in some pretty remote areas. And with the full expectation that it will be pure luck if it works; for example, my phone does not work on sections of major highways in Nevada, so expecting to work in most areas off the highway is unwise. That is why the SPOT device is becoming so popular, along with PLBs, in addition to the usual ELTs and aviation radios. Also, pilots try to radio their position while in air before landing, because they know using a cell phone or aircraft radio on the ground is going to be unreliable. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
On Sep 19, 8:25*am, Michael Ash wrote:
Alan wrote: I just took my new 3G for a flight. gpstracker application works very well to track flights on google earth. Also gives Long/Lat speed as well as altitude every 5 seconds. Check it out. *It might be fun, but it is also quite illegal. *47 cfr 22.925 states: * * 22.925 * Prohibition on airborne operation of cellular telephones. [snip] Aside from the use of "airplane mode", I seem to recall a discussion about this a while ago wherein it was concluded that modern mobile phones don't meet the FCC's definition of a "cell phone". The reasoning behind this regulation is that using a cell phone in flight plays merry havoc with the cell network due to seeing towers farther away than the network is designed for. But modern networks work differently and are immune to this problem, and I *think* the conclusion was that the regulation does not apply to them. Anyone know more about it? I'd like to know more than my patchwork memory.... -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon As pilot in command of a non-IFR flight I grant myself permission to use all kinds of electronic toys in flight. So that gets rid of FAA concerns. However my belief is that 47 CFR. 22.925 does apply to the iPhone since it is quad-band GSM that uses the GSM 850MHz band in the USA. If you have say a different brand PCS phone that exclusively uses 1800MHz then this would not apply to you. There is a wiki entry about this at http://en.wikipedia.org/wiki/Mobile_phones_on_aircraft In reality I turn my phone off to save battery life and distractions like the phone ringing while I'm on final (it's happened). So would I really want some new soaring software running on an iPhone? Sure I could see lots of neat UI things that could be done (Cocoa is a lovely UI to develop for) and the platform is powerful etc. The screen is a bit more visible in sunlight than most PDA screens, but it is still not really great. The downside of that is I'm set in my ways with SeeYou, so if Naviter wanted to port across SeeYou keeping some of it's core behavior/feature but offering an updated Cocoa UI/feel then I might be interested. Except for a few issues... I'm not going to use anything that does not talk to an external flight computer, e.g. for extended NEMA sentences for improved wind calculations etc. and I want to be sure my IGC logger is working OK so getting the GPS from it is a way to test this. Also I really don't want to mess with my iPhone as the display device in my glider, it's my phone that gets messed with a lot. But I'd be happy to dedicate an iPod Touch to this - in which case since it has no GPS you really need an external interface. Unfortunately the iPhone SDK does not give access to the serial port, and even if you had access to the serial port you will need some RS-232 line driver hardware to shift voltages to interface with a real RS-232 serial port in the GPS. The fact that Apple did not include that in the iPhone makes me think they really don't want to expose the serial port. The iPhone has bluetooth but does not support a serial profile, so you can't connect to a bluetooth GPS, or try to run a serial-bluetooth convertor on a flight computer serial port etc. over bluetooth. And it's just a USB slave (like a PDA) so you can't use a USB to serial translator. Then there is the issue of no way to use a CF or SD card or USB dongle etc. for flight log transfers and there is no third party code to run on it to download flight traces from loggers etc. Sure something like ConnectMe could be ported over (oops if there was just access to that danged serial port), oh and opps there is no file management UI in the iPhone so doing things nice and easily with log files etc. will be clumsier than it should). You could use or implement something like FileMagnet or DataCase and transfer log files over WiFi (of course that requires a WiFi setup), or email the file, otherwise you are going to stuck emailing file attachments or having to sync the iPhone to get off any log files. As it currently stands Apple's iPhone SDK license agreement has the restrictions mentioned already in this thread "Applications may not be designed or marketed for real time route guidance; automatic or autonomous control of vehicles, aircraft, or ..." (it is the real time route guidance that likely gets us, the "aircraft" stuff is irrelevant since we are not talking about an automatic or autonomous control". This restriction is in the SDK agreement, not just the iTunes store, so the only way around this is to use a non-Apple SDK with a jail broken phone. Then you are (questionably) violating other agreements. For anybody to put serious effort into developing such software, even if they wanted to open source it or give away binaries I doubt there is a significant enough "market" in jail broken 3G iPhones and their owners who want to put up with this. And while distributing through the AppStore is neat, it has some serious pain in the ass issues for higher end applications, starting with customer support say worthy of 0.99c applications. If somebody was serious and could get around the serial I/O and other issues then they could try talking to Apple, they might agree to modify route guidance restriction for a specific application (but don't hold your breath). Darryl |
iPhone and /G | A Guy Called Tyketto | Piloting | 2 | June 17th 08 12:01 AM |
iPhone and /G | A Guy Called Tyketto | Instrument Flight Rules | 2 | June 17th 08 12:01 AM |
iPhone in the air | Ramy | Soaring | 2 | June 3rd 08 12:03 AM |
IPhone On gliders? | Mitch[_2_] | Soaring | 0 | February 26th 08 08:14 AM |
E6B for iPhone? | C J Campbell[_1_] | Piloting | 16 | September 27th 07 03:54 AM |
