Preflighting my plane - Video
Old September 19th 08, 09:00 PM posted to rec.aviation.piloting
Default Preflighting my plane - Video
Today's flight, figured to video how I preflight my plane. Comments
here or on the video most welcomed. Always nice to hear input to make
me a safer pilot!
Preflighting an airplane Part 1
Walking to the airplane - Preflight inside the cockpit
http://www.youtube.com/watch?v=7Jnz8ikkAlA
Preflighting an airplane Part 2
Preflighting the airplane walk around.
http://www.youtube.com/watch?v=SAhF-x1kvpQ
Preflighting an airplane Part 3
Inside the plane after preflight.
http://www.youtube.com/watch?v=a4mkhUFHWa0
Old September 19th 08, 09:43 PM posted to rec.aviation.piloting
On Sep 19, 3:28*pm, Bertie the Bunyip wrote:
One, as you walk around, stand back every so often and look at the
airframe. You're looking for wrinkles in the skin or anything else that
might look strange.
Definately good one for the checklist. Never thought of this and
while I always step back after doing the entire check list for a last
once over (long video - part 2, you will see me do this at the very
end) I never thought about skin wrinkles.
mounting holes and such, and perhaps more importantly, it will get any fuel
that might be hiding in the fuel tank away from the sump out of it's
depression and into the sump.
Not quite sure I understand the above??
Obviously has something to do with the sump jiggies, and mine are
"spring loaded" and pressed in using the outer edge of the fuel sump
diddy rather then a center piece like a Cessna.
Does the style of sump make any difference?
Old September 19th 08, 09:47 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
" wrote in
that might look strange.
any fu
el
No, nothing to do with the sump drains themselves. The sump area is a
small depession at the bottom of the tank. All water in the tank should
go there by design. However most tanks have small imperfections in them
where water can get into and stick there. You do a nice calm walkaround
and drain your fuel and then when you start taxying, the water becomes
dislodged and gets into a feed port. With some designs, this can add up
to a lot of water...
Bertie
Old September 19th 08, 10:31 PM posted to rec.aviation.piloting
Gotchya, gotchya and gotchya, never thought of what you say, and makes
perfect sense.
Tanks I have are "stainless steel" and not bladders, so I **think**I
have a lesser risk of water settling where it shouldn't be but like
you say, a good shake would be prudent to better assure the water
indeed does settle down to the sumps so it gets sumped out.
Old September 19th 08, 11:00 PM posted to rec.aviation.piloting
" wrote in news:7b0f558c-1f70-462f-
perfect sense.
Depends on the type, but tin tanks are no kind of insurance against it. Try
it sometime. Drain some fuel, if there's some water, drain it all out and
then shake the airplane. Pretty sure you;ll get some more.
BTW, you're tanks are more than likely aluminum. I could be wrong, but I've
never seen stainless tanks in any airplane.
Bertie
Old September 20th 08, 01:40 AM posted to rec.aviation.piloting
a[_3_]
perfect sense.
Bertie
Big design flaw on the early M20J (Mooney 201) was the fuel tanks were
wet wing, and the seam sealant failed. If one smells gas in flight it
is NOT good, and we did. Huge pain in the ass to reseal. The other
thing about those tanks is the fuel caps were a little tricky to put
back right (this was back in the old days when the fuel truck would
come to the airplane) and if they were not put on right rain got in
big time. Nothing like draining a tank in a rain storm while wearing a
suit!
It was a lot of years ago but I was at a meeting in Rochester NY, got
to the airplane late, heavy rain, and got lots of water in the fuel
because the fuel caps were not on right. I wrote a letter of complaint
to the FBO, they kept it in mind and the next I I stopped there they
fueled the airplane for free. I should have taken a rain check on the
free refueling!
BTW, preflight checks don't end when you start the engine. A couple of
times in my couple of thousand hours I was approaching rotation speed
and a last look at the panel showed something not quite right. You're
not committed to the flight until there is not enough runway left to
stop! I approach every takeoff with the expectation I'll have to about
it, and every landing with the expectation I'll have to go around.
That mind set makes it a LOT easier to make the safe decision when you
have to.
This advice is worth exactly what you paid for it!
Old September 20th 08, 01:50 AM posted to rec.aviation.piloting
a wrote in
" wrote in
is a small depession at the bottom of the tank. All water in the
tank shoul
d
m
walkaroun
d
becomes dislodged and gets into a feed port. With some designs,
this can add u
p
makes perfect sense.
**think**I have a lesser risk of water settling where it shouldn't
be but like you say, a good shake would be prudent to better assure
the water indeed does settle down to the sumps so it gets sumped
out.
it. T
ry
and then shake the airplane. Pretty sure you;ll get some more.
but I'
ve
Bertie
suit!
Yeah, I know the caps you're talking about. They were a bitch to get on.
I sem to remember a lot of Mooneys having bladders, though. Earlier ones
maybe? Maybe wood wing airplanes?
Bertie
Old September 20th 08, 01:53 AM posted to rec.aviation.piloting
Try
Bertie
Surprisingly, I can count on one hand getting water in the fuel and my
bet how it got in there is my carelessness on taking the caps off
after a rain and the residual rain underneath the lever sneaks into
the tank. But I will give what you say above a try, nothing gain,
nothing loss but the adventure.
AND YES, you are right, it's aluminum and I knew that, why stainless
steel came out of my keyboard is beyond my belief :-))
Old September 20th 08, 01:57 AM posted to rec.aviation.piloting
have to.
I do the same :-) as well as set physical parameters that I expect
certain things to happen. I.E wheels up by midfield or designated
1000 foot marker or abort, or if my wheels are not down by a certain
point, go around.
Plane 172 fun video [email protected] Piloting 23 February 2nd 08 01:59 AM
Video of building a plane in the air Jim Logajan Home Built 1 November 20th 06 10:43 PM
Video from the plane Jacob Olsen Soaring 6 December 16th 05 05:23 PM
A Plane is Born Video FLYWITHJAY Home Built 0 July 17th 04 02:27 PM
Preflighting has changed for ever! Robert M. Gary Piloting 9 March 31st 04 08:20 PM
