Hmmm... Judging by weight and weave, I've always thought 7725 was a
direct replacement for 92125. I can't help with 92145, but the grainy photo in the ASW 12/15/17 repair manual makes it look a lot like 7781. Thanks, Bob K. Not quite. Check this direct comparison chart of 92125 vs 7725. It also shows 92145 vs 7715, which I think is 92145's closest US brethren. They are both close, but definitely not direct replacements... http://tinyurl.com/4gm27m FWIW, here's a more broad Interglas equivalency chart: http://www.canardzone.com/forum/atta...8&d=1205405858 I've already located the glass need and need only to fork over the cash. Thanks for the tips. -Paul |
On Sep 29, 8:09*am, sisu1a wrote:
Hmmm... Judging by weight and weave, I've always thought 7725 was a direct replacement for 92125. I can't help with 92145, but the grainy photo in the ASW 12/15/17 repair manual makes it look a lot like 7781. Thanks, Bob K. Not quite. Check this direct comparison chart of 92125 vs 7725. It also shows 92145 vs 7715, which I think is 92145's closest US brethren. They are both close, but definitely not direct replacements...http://tinyurl.com/4gm27mFWIW, here's a more broad Interglas equivalency chart:http://www.canardzone.com/forum/atta...ntid=1398&d=12... Yup, I was wrong about 92145 vs 7781, the closer match is definitely between 92145 and 7715, sometimes known as "Rutan uni" (except, of course, in Rutan-free zones). However, as far as I can tell, 7725 is near enough equivalent to 92125 as makes no difference, and 7715 is close enough to 92145 as anybody this side of Boeing needs to get. There is no seeeeeekrit ingredient to the Interglas stuff that makes it stronger or stiffer per unit mass than the Hexcel style equivalents. Of course, I am perfectly prepared to be demonstrated wrong in this. Feel free to send me 4" square, 5-ply test coupons of 92125 and 92145. I'll match them with 7725 and 7715 equivalents, pull them apart on the Break-o-tron, and post the results on YouTube. I'm not set up to collect anything but the most rudimentary modulus measurements, but I can easily do ultimates. Thanks, and best regards to all Bob K. |
On Sep 29, 10:55*am, Bob Kuykendall wrote:
On Sep 29, 8:09*am, sisu1a wrote: Hmmm... Judging by weight and weave, I've always thought 7725 was a direct replacement for 92125. I can't help with 92145, but the grainy photo in the ASW 12/15/17 repair manual makes it look a lot like 7781.. Thanks, Bob K. Not quite. Check this direct comparison chart of 92125 vs 7725. It also shows 92145 vs 7715, which I think is 92145's closest US brethren. They are both close, but definitely not direct replacements...http://tinyurl.com/4gm27mFWIW, here's a more broad Interglas equivalency chart:http://www.canardzone.com/forum/atta...ntid=1398&d=12... Yup, I was wrong about 92145 vs 7781, the closer match is definitely between 92145 and 7715, sometimes known as "Rutan uni" (except, of course, in Rutan-free zones). However, as far as I can tell, 7725 *is near enough equivalent to 92125 as makes no difference, and 7715 is close enough to 92145 as anybody this side of Boeing needs to get. There is no seeeeeekrit ingredient to the Interglas stuff that makes it stronger or stiffer per unit mass than the Hexcel style equivalents. Of course, I am perfectly prepared to be demonstrated wrong in this. Feel free to send me 4" square, 5-ply test coupons of 92125 and 92145. I'll match them with 7725 and 7715 equivalents, pull them apart on the Break-o-tron, and post the results on YouTube. I'm not set up to collect anything but the most rudimentary modulus measurements, but I can easily do ultimates. Thanks, and best regards to all Bob K. What I find difficult to believe is that there ISN'T a table (cheat sheet) available somewhere that lists the interglas numbers and the amurrican equivelant. F'rinstance: (all numbers and descriptions just made up) 92110 - 5.2 oz/yd plain weave 92125 - 8.75 oz/yd 2 x 2 twill etc. |
sheet) available somewhere that lists the interglas numbers and the amurrican equivelant. *F'rinstance: (all numbers and descriptions just made up) 92110 * - *5.2 oz/yd plain weave 92125 * - *8.75 oz/yd 2 x 2 twill etc. Ummm, the chart I linked has exactly that, except weights are in g/sq m instead of oz/yd (easy conversion). Only problem, is there are NO direct equivalents for 92125 or 92110 (or the 92145 I was also looking for, in addition to several other common Interglas weaves...) and that's the REAL problem. http://www.canardzone.com/forum/atta...8&d=1205405858 (in case you didn't look at it from my earlier post...) has the comparison chart that has the US equals for them in the column second from the left--IF one actually exists. I myself am not comfortable with using something other than exactly what the manufacture says (I find 'close' to be unacceptable in this regard) when it comes to structure but hey, what's the worse that could happen? -Paul |
On Oct 10, 2:44*pm, sisu1a wrote:
...I myself am not comfortable with using something other than exactly what the manufacture says (I find 'close' to be unacceptable in this regard) when it comes to structure but hey, what's the worse that could happen? I think that the worst is pretty deep. We could end up convincing the retulatory agencies to partake in such paranoia as we'd never get anything at all done and flying. Note the marginalia at the left edge of the table you cite. Clearly somebody thinks that 92125 is a reasonable substitution for Rutan bid, and 92145 for Rutan uni. As for why they don't show entries in the "US Styles" column, consider that 7725 and 7715 were not at all common in the US until Rutan popularized them in the moldless foam core craze of the mid 1970s. And judging by the font and layout of the table cited, it might well predate that era. Please do send me those materials coupons if you can, and I'll do a round of pulls. Loser buys beer. Thanks, Bob K. |
Where did you end up finding the glass? I am in need of some as well. Thanks.
"Budget" suppliers | [email protected] | Soaring | 4 | March 7th 07 07:36 PM |
Fiberglass vs. Fabric | Lou | Home Built | 35 | July 6th 06 05:08 PM |
Fabric coverings | AIRRAP | Restoration | 0 | January 2nd 05 01:59 PM |
Wax for fabric | Jim Martin | Restoration | 1 | November 23rd 03 05:50 AM |
