Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Aerobatics
Inverted turn
Old September 6th 04, 05:04 PM
Some
Default Inverted turn
Hi,
I have a quite stupied question - I am sorry...
If an aerobatic program dictates a 360 degree inverted turn to the left....
will that be a left circle when viewed from the ground ie. right rudder left
stick ? I tried to look it up in the "IAC Official Contest Rules" but I
can't seem to find it...
Best regards
Some rules-novice
Old September 6th 04, 08:56 PM
DSowder
Neither....or either. The direction of turn is up to the pilot, as long as he
ends up going the right direction. So you'd probably make the 360 in the
direction of the most open box, just to reduce the liklihood of going "out".
Similarly, 90 and 270 degree turns from the X (main) axis to the Y axis may be
made either way, so you choose based on other needs such as positioning the
next figure, not going out, wind direction, etc.
90 and 270 turns FROM the Y axis TO the X axis must be made in whatever
direction results in your heading the correct direction once you're back on the
X axis.
The Aresti symbols for rolls and spins are also non-directional. However, if
there are consecutive roll symbols on a figure, they'll be either "same" or
"opposite" and must be so flown. Spins and vertical (up or down) rolls must
result in going the direction you want (or need) to go, and the "same" and
"opposite" concepts hold true also. Otherwise the symbols are non-directional.
If there's a looping figure between rolls in a figure, for example a roll, half
loop up, then half roll, the roll directions don't affect each other. Similarly
a roll up on a hammer or humpty, and a roll down. Either can be made either
direction, subject to the need to be going the right direction when you're
done.
Doug Sowder
Old September 6th 04, 10:45 PM
Some
Dear Sir,
Thank you for the explanation, I am very glad you took the time to explain
it in such detail.
Best regards
"DSowder" wrote in message
left....
left
he
"out".
may be
on the
X axis.
if
or
must
non-directional.
half
Similarly
either
done.
Doug Sowder
inverted spin recovery explanation Alan Wood Aerobatics 18 August 19th 04 04:32 PM
Boeing 757 turn rate? Garyurbach Aerobatics 6 June 14th 04 05:43 PM
Calculating vertical time and distance in a stall turn (US Hammerhead) Dave Aerobatics 3 November 20th 03 11:48 AM
