Spot Landings
Old November 6th 08, 01:23 PM posted to rec.aviation.piloting
Mike
Default Spot Landings
"BT" wrote in message
Plopping does not count except for back country strips where it is
needed..
Nor does the technique of dropping the Johnson Bar to the floor count..
Smooth roll on landings please..
Count in whose book? With just a small surplus of energy to enable a bit of
float, combined with dumping the flaps at the right moment, one can hit a
very precise point and get a smooth roll. It's simply a matter of managing
energy and the plane's capabilities. Since the point of the exercise is to
show off short field or off field landing skills, I say use whatever
aerodynamic properties the aircraft has to your advantage. Your reasoning
makes as much sense as telling a glider pilot they can't use their spoilers.
Furthermore if you ever have a real dead stick landing, knowing how to use
your flaps in such a situation is very handy indeed and could make the
difference between a reusable aircraft or a smoking crater.
SPOT on Tuno Soaring 0 May 15th 08 09:36 PM
See SPOT run... [email protected] Soaring 11 April 30th 08 08:57 PM
SPOT GPS jeplane Soaring 17 February 5th 08 05:23 AM
SPOT D.Rizzato General Aviation 0 February 5th 08 01:04 AM
Night landings vs. day landings Gerald Sylvester Piloting 15 February 12th 04 06:38 AM
