4-blade Pawnee Performance?
Can anyone out there with experience behind both 2-bladed and 4-bladed
Pawnees give me an idea of what the performance losses are? My club has debated this off and on, but I was recently at a field with a 4-bladed Pawnee and was much impressed with the lower noise. Problem is, I've got club members claiming that it'll cost over $10k to do the job, and we'd give up 25% to 30% in performance due to the extra blades. Can anyone corroborate those numbers? Thanks, take care, --Noel |
On Nov 19, 3:59*pm, "noel.wade" wrote:
Can anyone out there with experience behind both 2-bladed and 4-bladed There are several Pawnees with 4-blade props and a few with 2-blade props in Colorado. Yes, it will cost you $10k and be somewhat quieter overhead and much quieter on approach, taxi and takeoff. The main effect seems to be 4-blade props shifts the prop noise to a higher pitch which is somehow less annoying. As for performance, I've towed behind most of them and I'd estimate that there is a small gain in initial acceleration followed by a small loss in rate of climb - somewhere around 5% each way. Mile High Gliding, the dealer for the Hoffmann 4-blade, uses them on their 230HP Pawnees to tow over gross 2-32's from a 2200' runway with a density altitude sometimes over 10,000'. Many of these tows go to 10,500 for their "Mile High Glider Ride". There's no way this would work if there were a 25% performance loss. Pawnees give me an idea of what the performance losses are? My club has debated this off and on, but I was recently at a field with a 4-bladed Pawnee and was much impressed with the lower noise. Problem is, I've got club members claiming that it'll cost over $10k to do the job, and we'd give up 25% to 30% in performance due to the extra blades. Can anyone corroborate those numbers? Thanks, take care, --Noel |
On Nov 19, 5:59*pm, "noel.wade" wrote:
Can anyone corroborate those numbers? Numbers? No... A four blade Pawnee going low overhead at full power is still very loud. The prop does nothing for the engine noise and the Pawnee has quite a lot of that. What it eliminates is the 'snarl' from high speed prop tips that is most noticeable to an observer in the plane of the prop. If 'snarl' is your problem, maybe this is your solution. The performance loss is noticeable and annoying, but not a deal breaker in itself. Clubs I know who've bought them have not been real impressed. For the price, I'd like to be impressed. Ymmv. -T8 |
On Nov 20, 9:09*am, wrote:
On Nov 19, 5:59*pm, "noel.wade" wrote: Can anyone corroborate those numbers? Numbers? *No... A four blade Pawnee going low overhead at full power is still very loud. *The prop does nothing for the engine noise and the Pawnee has quite a lot of that. *What it eliminates is the 'snarl' from high speed prop tips that is most noticeable to an observer in the plane of the prop. If 'snarl' is your problem, maybe this is your solution. The performance loss is noticeable and annoying, but not a deal breaker in itself. Clubs I know who've bought them have not been real impressed. *For the price, I'd like to be impressed. *Ymmv. -T8 It's interesting to do some highly oversimplified "back of the envelope" numbers on Pawnee tugs. (The following ignores some important stuff.) Assume a 40:1 glider weighing 1000 pounds being towed at its best L/D airspeed of 60KTS and climbing at 500FPM. 1000/40 = 25 pounds of aerodynamic drag. 60x25/325 = 4.6HP to overcome that drag. Of course the tug is lifting the glider at 500FPM or 8.33 FPS so 8.33x1000/550 = 15.14HP to lift the weight of the glider. 15.14+4.6 = 19.74HP which is the rate at which work being done on the glider by the Pawnee. In other words, only approximately 20HP is used to tow the glider. If the tug engine is actually producing 230HP (highly doubtful), 210HP is being wasted somewhere - most of which is probably just the Pawnee hauling itself through the air. That wasted energy is where most of the noise is coming from. The above suggests that a tug with a highly aerodynamic airframe could use far less HP which is why 80HP motorglider tugs seem to work so quietly. |
use far less HP which is why 80HP motorglider tugs seem to work so quietly. A tug like this: http://www.sportaircraftworks.com/ot...dynamicnew.htm According to John Roake, turnaround on a 600m launch with this plane averaged 4-5 minutes (takeoff to landing) and it only took 100 Euros worth of fuel for 8 of these planes to launch a field of 60 gliders (no other stats provided unfortunately). With efficiency like that I bet these planes don't make a lot of noise though... -Paul |
On Nov 20, 8:51*am, bildan wrote:
On Nov 20, 9:09*am, wrote: On Nov 19, 5:59*pm, "noel.wade" wrote: Can anyone corroborate those numbers? Numbers? *No... A four blade Pawnee going low overhead at full power is still very loud. *The prop does nothing for the engine noise and the Pawnee has quite a lot of that. *What it eliminates is the 'snarl' from high speed prop tips that is most noticeable to an observer in the plane of the prop. If 'snarl' is your problem, maybe this is your solution. The performance loss is noticeable and annoying, but not a deal breaker in itself. Clubs I know who've bought them have not been real impressed. *For the price, I'd like to be impressed. *Ymmv. -T8 It's interesting to do some highly oversimplified "back of the envelope" numbers on Pawnee tugs. *(The following ignores some important stuff.) Assume a 40:1 glider weighing 1000 pounds being towed at its best L/D airspeed of 60KTS and climbing at 500FPM. *1000/40 = 25 pounds of aerodynamic drag. *60x25/325 = 4.6HP to overcome that drag. Of course the tug is lifting the glider at 500FPM or 8.33 FPS so 8.33x1000/550 = 15.14HP to lift the weight of the glider. 15.14+4.6 = 19.74HP which is the rate at which work being done on the glider by the Pawnee. *In other words, only approximately 20HP is used to tow the glider. If the tug engine is actually producing 230HP (highly doubtful), 210HP is being wasted somewhere - most of which is probably just the Pawnee hauling itself through the air. *That wasted energy is where most of the noise is coming from. The above suggests that a tug with a highly aerodynamic airframe could use far less HP which is why 80HP motorglider tugs seem to work so quietly. Or lets guess around 30 hp assuming prop (in)efficiency, ~80% best case?, but who knows in practice. And the wasted energy is where *all* the noise comes from :-) And as a data point, the ~50 shp engine in my ASH-26E give up to 700 fpm climb... on a good day. A more efficient tug could reduce the amount of prop thrust needed and therefore noise that needs to be made in the first place. If prop noise is a significant factor, which it seems to be, adding blades definitely seems to help. BTW I agree with your earlier post about the apparent differences in towing behind a Pawnee with a Hoffman 4 bladed prop. Soar Truckee switched to a four bladed prop and did some good community PR work around reducing noise, including a positive article in the local newspaper. See - www.soartruckee.com/pdfs/Pickle_part_1_0612.pdf and www.soartruckee.com/pdfs/Pickle_part_2_0612.pdf The rate of climb with a heavy glider (e.g. DG-1000S with two occupants) at ~7k'+ density altitude seemed a little lower than a two bladed prop, but that's not a scientific comparison. Mile High may be able to provide data on that as well. Hopefully a tow pilot with experience with these will weigh in. Darryl |
sisu1a wrote:
The above suggests that a tug with a highly aerodynamic airframe could use far less HP which is why 80HP motorglider tugs seem to work so quietly. A tug like this: http://www.sportaircraftworks.com/ot...dynamicnew.htm According to John Roake, turnaround on a 600m launch with this plane averaged 4-5 minutes (takeoff to landing) and it only took 100 Euros worth of fuel for 8 of these planes to launch a field of 60 gliders (no other stats provided unfortunately). With efficiency like that I bet these planes don't make a lot of noise though... -Paul The European "ultralight" tugs do a fine job. The Dynamic is really quiet, fast, economical and tows well. The difference in towing behind something like a Dynamic or Samba versus one of the heavier aircraft is substantial. With the modern ultralight being a much better match to the glider. |
On Nov 20, 12:12*pm, Bruce wrote:
sisu1a wrote: The above suggests that a tug with a highly aerodynamic airframe could use far less HP which is why 80HP motorglider tugs seem to work so quietly. A tug like this:http://www.sportaircraftworks.com/ot...dynamicnew.htm According to John Roake, turnaround on a 600m launch with this plane averaged 4-5 minutes (takeoff to landing) and it only took 100 Euros worth of fuel for 8 of these planes to launch a field of 60 gliders (no other stats provided unfortunately). With efficiency like that I bet these planes don't make a lot of noise though... -Paul The European "ultralight" tugs do a fine job. The Dynamic is really quiet, fast, economical and tows well. The difference in towing behind something like a Dynamic or Samba versus one of the heavier aircraft is substantial. With the modern ultralight being a much better match to the glider. Someone said that the typical airplane engine is an excellent transducer that converts money into heat and noise with a small, although useful, amount of thrust as a side effect. |
bildan wrote:
On Nov 20, 12:12 pm, Bruce wrote: sisu1a wrote: The above suggests that a tug with a highly aerodynamic airframe could use far less HP which is why 80HP motorglider tugs seem to work so quietly. A tug like this:http://www.sportaircraftworks.com/ot...dynamicnew.htm According to John Roake, turnaround on a 600m launch with this plane averaged 4-5 minutes (takeoff to landing) and it only took 100 Euros worth of fuel for 8 of these planes to launch a field of 60 gliders (no other stats provided unfortunately). With efficiency like that I bet these planes don't make a lot of noise though... -Paul The European "ultralight" tugs do a fine job. The Dynamic is really quiet, fast, economical and tows well. The difference in towing behind something like a Dynamic or Samba versus one of the heavier aircraft is substantial. With the modern ultralight being a much better match to the glider. Someone said that the typical airplane engine is an excellent transducer that converts money into heat and noise with a small, although useful, amount of thrust as a side effect. Indeed, consider the Wilga... Something like a Samba or Dynamic tows smooth and at half or less of the cost of the fossil fuel converters I am a fan. Last contest I had a quicker ride to release behind a Rotax914 equipped Samba XL than the preceeding run behind a Cessna 182. The Cessna tow cost twice as much though. |
No answer on your questions . . . however, I do know there was at least one
incidence of the 4-blade prop making like a Frisbee. One minute it was dragging the Pawnee through the air, the next it was on it's own and accelerating away from the plane. Guess it's important to re-torque the prop bolts? bumper "noel.wade" wrote in message ... Can anyone out there with experience behind both 2-bladed and 4-bladed Pawnees give me an idea of what the performance losses are? My club has debated this off and on, but I was recently at a field with a 4-bladed Pawnee and was much impressed with the lower noise. Problem is, I've got club members claiming that it'll cost over $10k to do the job, and we'd give up 25% to 30% in performance due to the extra blades. Can anyone corroborate those numbers? Thanks, take care, --Noel |
Similar Threads | ||||
To Pawnee or not to Pawnee...that is the question... | Travis Beach | Soaring | 56 | March 24th 14 06:21 AM |
To Pawnee or not to Pawnee...that is the question... | Travis Beach | Soaring | 4 | October 17th 07 01:31 PM |
3-blade prop? | Jay Honeck | Owning | 19 | September 27th 06 09:29 AM |
Complex / High Performance / Low Performance | R.T. | Owning | 22 | July 6th 04 08:04 AM |
Pawnee t/o performance-towing | Kurt | Soaring | 2 | September 24th 03 08:39 AM |
