On Mon, 12 Jan 2009 22:38:54 -0600, "Maxwell" #$$9#@%%%.^^^ wrote:
There is also the possibility of molding this in plaster, but that's another story. unless you've tried it you would have no idea how dangerous that suggestion actually is. firstly the strength of plaster vanishes to nothing beyond a certain temperature. that temperature is just 5 degrees celcius above the melting point of aloominum. I have tried the technique to cast a mills 0.75cc diesel crankcase. this is a tiny thing about an inch and half by an inch and a half in overall dimensions. relatively tiny and easy to work with. it was done lost wax. a day after the plaster was set the mold went into the oven to melt out the wax. it was then cooked up to about 180 degrees farenheit for a while (2 hours afaik) to evaporate off the moisture. it stayed in the oven overnight (I've never been allowed to use the oven again) it was then given 15 minutes in the microwave to really dry it out. it was wrapped in a cloth and raced out to the workshop hot. it looked alabaster white and as dry as a piece of chalk. when the aluminium was poured into the mold a guyser of molten aluminium ejected to the ceiling of the workshop. this seemed to continue for some time. an examination of the mould later showed it to be totally empty. I dont know how dry you need to get it but I gave it a fair go at getting a bone dry mould. I have to ask you what your experience is in casting. have you ever done any of this yourself or is it something you've watched? Stealth Pilot |
"Stealth Pilot" wrote in message ... On Mon, 12 Jan 2009 22:38:54 -0600, "Maxwell" #$$9#@%%%.^^^ wrote: There is also the possibility of molding this in plaster, but that's another story. unless you've tried it you would have no idea how dangerous that suggestion actually is. firstly the strength of plaster vanishes to nothing beyond a certain temperature. that temperature is just 5 degrees celcius above the melting point of aloominum. I have tried the technique to cast a mills 0.75cc diesel crankcase. this is a tiny thing about an inch and half by an inch and a half in overall dimensions. relatively tiny and easy to work with. it was done lost wax. a day after the plaster was set the mold went into the oven to melt out the wax. it was then cooked up to about 180 degrees farenheit for a while (2 hours afaik) to evaporate off the moisture. it stayed in the oven overnight (I've never been allowed to use the oven again) it was then given 15 minutes in the microwave to really dry it out. it was wrapped in a cloth and raced out to the workshop hot. it looked alabaster white and as dry as a piece of chalk. when the aluminium was poured into the mold a guyser of molten aluminium ejected to the ceiling of the workshop. this seemed to continue for some time. an examination of the mould later showed it to be totally empty. I dont know how dry you need to get it but I gave it a fair go at getting a bone dry mould. I have to ask you what your experience is in casting. have you ever done any of this yourself or is it something you've watched? Stealth Pilot Both. http://www.gp.com/build/product.aspx?pid=1569 |
On Jan 13, 1:00*am, Stealth Pilot
wrote: On Mon, 12 Jan 2009 22:38:54 -0600, "Maxwell" #$$9#@%%%.^^^ wrote: when the aluminium was poured into the mold a guyser of molten aluminium ejected to the ceiling of the workshop. *this seemed to continue for some time. an examination of the mould later showed it to be totally empty. I dont know how dry you need to get it but I gave it a fair go at getting a bone dry mould. Stealth Pilot Your experience pretty much matches mine. I was able to get dry enough plaster to make castings without porosity, but it took WAY to long to dry to that point. My first pour too resulted in a steam geyser and I would have sworn I baked that thing long enough. I was also having fill problems. One plaster cast per go made the experimentation too time consuming. I gave up and went back to sand. I was trying to make fined valve covers for my1/2VW and was having trouble getting molds in sand to stay together while puling the pattern. At that time I didn't have a muller and could not get oil based sand to work at all - thus the try at plaster. I finally managed to modify my sand formula and got satisfactory results. A touch of sugar did the trick. The fins on the valve covers were enough of a challenge that I won't be trying to do any head casting in sand, oil or bentonite based. IMHO buying/building a muller is worth the time and trouble as the oil based sand is good stuff. The humidity in my part of the world is such that an uncovered covered heap of sand will dry out too much in a matter of hours. Oil doesn't and for that reason alone I made the switch. Just in case you don't have the formula, even though I'm sure you do........................... http://www.foundry.ray-vin.com/k-bond/k-bond.htm http://users.hal-pc.org/~lwhill/sandsystems.html ======================= Leon McAtee |
On Tue, 13 Jan 2009 08:42:55 -0800 (PST), "
wrote: On Jan 13, 1:00*am, Stealth Pilot wrote: On Mon, 12 Jan 2009 22:38:54 -0600, "Maxwell" #$$9#@%%%.^^^ wrote: when the aluminium was poured into the mold a guyser of molten aluminium ejected to the ceiling of the workshop. *this seemed to continue for some time. an examination of the mould later showed it to be totally empty. I dont know how dry you need to get it but I gave it a fair go at getting a bone dry mould. Stealth Pilot Your experience pretty much matches mine. I was able to get dry enough plaster to make castings without porosity, but it took WAY to long to dry to that point. My first pour too resulted in a steam geyser and I would have sworn I baked that thing long enough. I was also having fill problems. One plaster cast per go made the experimentation too time consuming. I gave up and went back to sand. I was trying to make fined valve covers for my1/2VW and was having trouble getting molds in sand to stay together while puling the pattern. At that time I didn't have a muller and could not get oil based sand to work at all - thus the try at plaster. I finally managed to modify my sand formula and got satisfactory results. A touch of sugar did the trick. The fins on the valve covers were enough of a challenge that I won't be trying to do any head casting in sand, oil or bentonite based. IMHO buying/building a muller is worth the time and trouble as the oil based sand is good stuff. The humidity in my part of the world is such that an uncovered covered heap of sand will dry out too much in a matter of hours. Oil doesn't and for that reason alone I made the switch. Just in case you don't have the formula, even though I'm sure you do........................... http://www.foundry.ray-vin.com/k-bond/k-bond.htm http://users.hal-pc.org/~lwhill/sandsystems.html ======================= Leon McAtee priceless references. I've never tried oilsand just a seemingly continuous tweaking of my bentonite based mix getting it better and better. maxwells investment reference gives little actual detail but they must do some cunning stuff with the additives that they allude to in their plaster. they've certainly developed the process way beyond what I've achieved. Stealth Pilot |
"Stealth Pilot" wrote in message ... On Tue, 13 Jan 2009 08:42:55 -0800 (PST), " maxwells investment reference gives little actual detail but they must do some cunning stuff with the additives that they allude to in their plaster. they've certainly developed the process way beyond what I've achieved. Stealth Pilot It wasn't an investment reference, just a casting plaster. |
On Jan 13, 3:00*am, Stealth Pilot
wrote: On Mon, 12 Jan 2009 22:38:54 -0600, "Maxwell" #$$9#@%%%.^^^ wrote: There is also the possibility of molding this in plaster, but that's another story. unless you've tried it you would have no idea how dangerous that suggestion actually is. firstly the strength of plaster vanishes to nothing beyond a certain temperature. that temperature is just 5 degrees celcius above the melting point of aloominum. That is because it is water molecules that bind the other molecules together when the plaster cures. When you heat it, you break those bonds and drive off the water. You can test this out by weighing the water and plaster you mix, then weigh the cured solid when it appears dry. It will still weight a lot more than the dry plaster did. After baking it, weigh it again. As long as the weight is greater than the original dry plaster, you know there is still water in there. I have tried the technique to cast a mills 0.75cc diesel crankcase. this is a tiny thing about an inch and half by an inch and a half in overall dimensions. relatively tiny and easy to work with. it was done lost wax. a day after the plaster was set the mold went into the oven to melt out the wax. it was then cooked up to about 180 degrees farenheit for a while (2 hours afaik) to evaporate off the moisture. it stayed in the oven overnight (I've never been allowed to use the oven again) it was then given 15 minutes in the microwave to really dry it out. it was wrapped in a cloth and raced out to the workshop hot. it looked alabaster white and as dry as a piece of chalk. when the aluminium was poured into the mold a guyser of molten aluminium ejected to the ceiling of the workshop. *this seemed to continue for some time. an examination of the mould later showed it to be totally empty. I dont know how dry you need to get it but I gave it a fair go at getting a bone dry mould. I've no experience, but there is a nice newsgroup called rec.crafts.metalworking or something like that where you can get good advice from people who routinely have a less exciting experience. Plaster of Paris retains water of crystalization when it is cured. It takes a lot of heat for a long time to get all of that water out, like maybe 5 or 6 hours at 500 F and you should keep it hot when you our. If I understand the chemistry, by the time it is dry enough to cast aluminum you will have returned it to much the same material that it was before you mixed it. Since you didn't do that, it was the molten aluminum that decomposed the plaster releasing the water with the observed result. Jewelers work with much higher melting point metals, platinum even. They use investment, sometimes called investment plaster. The difference between that and ordinary Plaster of Paris is that it has materials added like silica that do not decompose when the mold is burnt out, and other materials (maybe wood flour) that are there to create microporosity when it is burnt out. A high quality investment may be overkill for casting aluminum, but it will be better than a molten aluminum geyser. But please do check with people who, unlike myself, have actually done this. On to the subject of cooling fins: I HAVE designed cooling fins back in a former life when I was working in the nuclear industry. I believe you will get the best heat transfer with pure aluminum. Alloys will have a lower thermal conductivity, although the more important parameter is heat capacity, the product of thermal conductivity with density. But for an airplane you probably don't want denser (and therefore heavier materials). You can improve the heat transfer and reducing the weight by tapering the cooling fins from root to tip. A good undergraduate engineering book on heat transfer should address the optimization of cooling fins. Remember also that convective heat transfer is governed by Newton's law of cooling: q = mdot * h * A * deltaT DeltaT is the temperature difference, A is the surface area (which you increase with fins), h is the convective heat transfer coefficient (usually a function of Reynold's number) and mdot is the mass transfer rate of the cooling fluid. Bumping up the flow increases both mdot (directly) and h, by increasing the Reynold's number. It helps a lot. IOW, concentrating on improving the airflow may be more helpful than improving the fins. Hope this helps -- FF |
IOW, concentrating on improving the airflow may be more helpful than improving the fins. --------------------------------------------------------------------------------------- Roger that. In spades. Most homebuilt cooling systems aren't. Go over to AirVW and give a gander at what one of the Monnett's had to say about VW heads.... and later what he had to say about VW cooling systems. x-number of inches of water-pressure differential between the inlet plenum and the outlet plenum... takes something on the order of 90mph to get that amount of pressure from ram air alone. And you're driving a plane that cruises @ 75mph So now you REALLY get to see the Wizards at work... guys like John Thrope, with his equations for the inlet AREA of the plenum vs the outlet area, with pieces of duck tape here & there and flat THROWING the stock oil cooler across the hangar because it's making such a huge HOLE in the back wall of his inlet plenum that there ain't no way to get the required about of pressure... and the Great Designer insisting he's NEVER had any 'trouble'... and it reminds you of the guy in Oregon with his three engines but never any trouble, or the guy in Canada with 1300 hrs on the SAME engine over a 20 year period and NEVER ANY TROUBLE... but forgetting to mention the ANNUAL 'freshening of the valves' and the occasional replacing of the bearings because THOSE THINGS DON'T COUNT as 'troublle' since he's never had any in all those long, long twenty whole YEARS of flying.... which worked out to something like 65 HOURS OF FLYING PER YEAR, between June and September, because that is the flying "..season..." according to this particular expert with his high-time VP1 now a'dangling in some museum. The only thing more lovable than a VW-powered air plane is the folks that owns them. -R.S.Hoover |
On Wed, 14 Jan 2009 12:52:18 -0800 (PST), "
wrote: IOW, concentrating on improving the airflow may be more helpful than improving the fins. --------------------------------------------------------------------------------------- Roger that. In spades. Most homebuilt cooling systems aren't. Go over to AirVW and give a gander at what one of the Monnett's had to say about VW heads.... and later what he had to say about VW cooling systems. I changed some baffles on the O-200 to get around a corrosion problem. airborne moisture was impacting the fins, blasting off the paint and then leaving the bare hot steel moisture coated. rust city. later I noticed some harsh running sounds and while investigating some oil leaks had the need to replace rocker gaskets. on one cylinder there was a noticeable build up of carbonised charred oil on the top of the exhaust valve. I've since placed a hole in the baffle face to direct air over the exhaust fins of that cylinder, rather than using the plenum pressure directed airflow. The harsh noises have not reoccurred. during the annual in a few months I'll check for carbon buildup again. do you find in your vw engines that carbon buildup on the exhaust valves is any indication of a cooling deficiency? what indicator do you use for health of a cooling setup? in other words how can anyone know that they have it right? in my case oil temps were all totally normal. it seemed to me that the charred oil was an indicator of a local hot spot that I needed to address. Stealth Pilot |
On Jan 14, 5:23*pm, Stealth Pilot
wrote: do you find in your vw engines that carbon buildup on the exhaust valves is any indication of a cooling deficiency? what indicator do you use for health of a cooling setup? in other words how can anyone know that they have it right? ---------------------------------------------------------------------------------------------- Detonation gets your attention pretty fast. SPLIT in the exhaust valve. Guy sez temps are good and you're standing there with you IR temperature gauge, with it say 530F and he's still yaking on about his 'good temperature,' with the thermocouple under his sparking plug. Ask AGAIN and he starts talkng about fishing or some dum-assed thing. -Bob |
| Thread Tools | |
| Display Modes | |
| Need help with a rocket motor ID unk-rocket- | Dave Kearton | Aviation Photos | 0 | February 2nd 07 09:09 AM |
| Traffic Heads-up | [email protected] | Products | 1 | July 7th 05 05:50 PM |
| 1966 Cessna 172 Control Yokes --- What Alloy? | jls | Home Built | 0 | November 4th 04 06:02 PM |
| TWO EXTREMELY RARE ROCKET BOOKS ON EBAY - INCREDIBLE ROCKET HISTORY! | TruthReigns | Military Aviation | 0 | July 10th 04 12:54 PM |
| SCAM - Heads up | DaveSpringford | Soaring | 0 | December 5th 03 12:13 AM |
