Using car exhaust for engine Pre- heat??
Old January 15th 09, 12:12 AM posted to rec.aviation.owning
Bob Noel[_2_]
Default Using car exhaust for engine Pre- heat??
Greetings:
It's winter here in Tennessee a question for the group: If I took a
flexible Aluminim duct,/ hose hooked it up to my car exhaust pipe,
then put the other end in the lower end of the engine cowling to pre-
heat the aircraft's engine would this cause any problems?
I would drill a small hole in the cars exhaust pipe to allow for
exhaust water to escape
Today's cars are very clean burning with almost zero emissions or so
they say? I would not direct the exhaust at the airframe or the
engine just enough to enter the cowling at the nose strut. I would
open the oil door to allow a flow of exhaust. I would leave the cabin
door open on the aircraft to make sure no CO2 besides, my aircraft
has a CO2 detector installed.
I would allow the exhaust to heat the engine up just enough to get it
past freezing give or take plus turn the prop to limber the oil
This seems like a inexpensive idea to pre heat
Any corrosion potential ?? What do you think
I think there would too much water vapor and too much chance
of CO. I don't know if today's engines have a clean enough
exhaust that I would risk my aircraft engine. Besides, I did
spring for a preheater (a red dragon preheater)
btw - flexible aluminum wouldn't be my first choice. I have
some hose that came with my preheater that won't be a hot to
the touch as aluminum ducting would be.
150 exhaust leack [email protected] Owning 5 October 6th 06 05:52 PM
O290 exhaust Ray Toews Home Built 0 February 13th 05 10:14 PM
P-38 Exhaust Stephen Harding Military Aviation 10 April 19th 04 07:03 AM
YF-23 exhaust? Sir Loin of Beef Military Aviation 0 August 1st 03 04:55 AM
Exhaust for VW motor Andre Home Built 0 July 14th 03 03:14 PM
