Rust in tight places
Old February 5th 09, 11:48 PM posted to rec.aviation.homebuilt
Charles Vincent
Default Rust in tight places
stol wrote:
On Feb 5, 5:39 am, mhorowit wrote:
I'm removing surface rust on a 4130 fuselage prior to priming.
Assume I'm in a place where I can't use my sandblaster.
I need to get into the tight places of a cluster to remove surface
rust.
I can get pretty deep in the cluster with emery cloth, but there is
the last 1/8".
There are rust converter chemicals on the market. Is it OK for me to
use
a rust converter prior to priming or am I fooling myself? - Mike
get a finer grade of blasting media.. I can't see how you could get
any better results any other way.
Ben
I think he meant that he was in a location i.e. hanger where
sandblasting was forbidden.
Charles
Old February 6th 09, 12:05 AM posted to rec.aviation.homebuilt
stol
rust.
the last 1/8".
use
get a finer grade of *blasting media.. I can't see how you could get
Ben
Charles- Hide quoted text -
- Show quoted text -
That now does make sense but if the rust is slight there are small,
portable sandblasters that would work using the smallest compressors..
Rust Baver 2 acroman Aviation Photos 0 August 19th 07 04:00 PM
Rust Flying Service Beaver - 1 acroman Aviation Photos 0 August 19th 07 03:59 PM
Shaking off the Rust john smith Piloting 22 March 1st 07 12:36 AM
Fly tight for tight bomb patterns on the ground. ArtKramr Military Aviation 120 August 30th 04 08:42 AM
Rust inhibitor? Steve Thomas Home Built 10 August 30th 03 09:34 PM
