We are having a argument about what is better to do after takeoff. Some mechanics say pull power back first after takeoff and then adjust prop speed after, my mechanic says prop speed back first and then manifold pressure after that.
What the "right" thing to do that will not damage the prop governor and motor??? You opinion is greatly appreciated.. PS: this is in reference to my 1965 210. thanks rg |
On Mar 6, 11:37*am, cyberflyrg
wrote: We are having a argument about what is better to do after takeoff. Some mechanics say pull power back first after takeoff and then adjust prop speed after, my mechanic says prop speed back first and then manifold pressure after that. What the "right" thing to do that will not damage the prop governor and motor??? You opinion is greatly appreciated.. PS: this is in reference to my 1965 210. Refer to your POH when in doubt. However, the rule of thumb most of us fly under is that when reducing power you work left to right (throttle, then prop, then mixture). When increasing power you work the other way (mixture, prop, then throttle). This sequence ensures you don't lug the engine. If your airframe POH or engine manual says otherwise, go for it. -Robert, CFII |
On 03/06/09 12:48, Robert M. Gary wrote:
On Mar 6, 11:37�am, cyberflyrg wrote: We are having a argument about what is better to do after takeoff. Some mechanics say pull power back first after takeoff and then adjust prop speed after, my mechanic says prop speed back first and then manifold pressure after that. What the "right" thing to do that will not damage the prop governor and motor??? You opinion is greatly appreciated.. PS: this is in reference to my 1965 210. Refer to your POH when in doubt. However, the rule of thumb most of us fly under is that when reducing power you work left to right (throttle, then prop, then mixture). When increasing power you work the other way (mixture, prop, then throttle). This sequence ensures you don't lug the engine. If your airframe POH or engine manual says otherwise, go for it. -Robert, CFII Yes but right after take off, don't people reduce the rpm just a bit (to 2500 in the Archer I flew) to reduce noise? -- Mark Hansen, PP-ASEL, Instrument Airplane, USUA Ultralight Pilot Cal Aggie Flying Farmers Sacramento, CA |
On Mar 6, 12:52*pm, Mark Hansen wrote:
On 03/06/09 12:48, Robert M. Gary wrote: Yes but right after take off, don't people reduce the rpm just a bit (to 2500 in the Archer I flew) to reduce noise? I don't because I personally don't believe in touching power below 1000 feet. However, a lot of aircraft require a power reduction for sustained climb or noise. For instance in the C-182T you pull power and fuel flow back to the top of the green, etc. However, I still don't touch anything below 1000 feet, even coming out of SMO in my Mooney (where the noise nazi's live) -Robert |
cyberflyrg wrote: We are having a argument about what is better to do after takeoff. Some mechanics say pull power back first after takeoff and then adjust prop speed after, my mechanic says prop speed back first and then manifold pressure after that. What the "right" thing to do that will not damage the prop governor and motor??? You opinion is greatly appreciated.. PS: this is in reference to my 1965 210. thanks rg On my bonanza, I keep full throttle then pull back the prop as per the manual. Keep the throttle in until I reach my enroute altitude. Dave |
The Seneca II take off is 40in MP and full RPM for takeoff.
"Stabilized in the climb".. you pick when you think that is time to do that. Reduce to "Climb Power" 30in MP and 2500RPM. Cruise Power "as required" normally between 28-30in MP 2300-2400RPM and about 13gph per side. Some one already mentioned the take off procedure for the C-182T (Turbo). Reduce the MP and the Fuel Flow to the Top of the Green. Arrow, 25square works, MP first then Prop. The thing about "older" POH, like your 1965 C-210.. they were not that explict. Dependent on the engine, some say keep RPM higher than MP, some don't. "cyberflyrg" wrote in message ... We are having a argument about what is better to do after takeoff. Some mechanics say pull power back first after takeoff and then adjust prop speed after, my mechanic says prop speed back first and then manifold pressure after that. What the "right" thing to do that will not damage the prop governor and motor??? You opinion is greatly appreciated.. PS: this is in reference to my 1965 210. thanks rg -- cyberflyrg |
BT wrote:
The thing about "older" POH, like your 1965 C-210.. they were not that explict. The POH on my 1941 Taylorcraft doesn't say a thing about when to adjust the prop :-) Danny Deger |
On Mar 6, 7:31 pm, "BT" wrote:
The thing about "older" POH, like your 1965 C-210.. they were not that explict. Dependent on the engine, some say keep RPM higher than MP, some don't. But moving the controls in the wrong order can put the engine outside its operational limitations. For instance, if the POH allows 24" and 2200 RPM, that setting isn't within the old "square" rule-of- thumb but it won't hurt the engine. Now, if you pull the prop back to 2200 with the throttle wide open, you're going to get may 25 or 26" MP and 2200 RPM, well outside the limits set by the manufacturer. The risk with large-bore, slow-turning engines is detonation, and the POH tables are designed with avoiding detonation and the awesome damage it causes. So that's why we teach people to avoid high cylinder pressures by reding MP first, then setting RPM. If increasing power, get the RPM up first and then increase MP. It's no different than upshifting or downshifting your car; you don't just mash the throttle to the floor when you come to a steep hill; you downshift first and then apply the power, and when you get to the top of the hill you don't upshift until the car's speed is such that the engine won't have to drop to some very low RPM when you let the clutch out and apply the power again. We older guys can remember a time when cars would "ping" or "knock" when the engine was driven at a low RPM and too much throttle. That was detonation and it would break rings and knock holes in pistons and trash the bearings and sometimes heads and cylinder walls would crack. It was considered very poor driving technique. Now we have cars with computers and knock sensors and all sorts of electronic wizardry that keeps the driver from breaking stuff, but it also dumbs down young drivers and they can't grasp the RPM/MP thing quite so easily. And automatic transmissions and ABS brakes have made driving habits even worse, IMHO. Dan |
the prop :-) Yeah, there's nothing in my '48 Ercoupe's POH (er, "pamphlet") about that, either. Nuthin' about flaps or rudders, either! :-) The Pathfinder we always work left-to-right, as someone else stated. Throttle, prop, mixture. -- Jay Honeck Iowa City, IA Pathfinder N56993 Ercoupe N94856 www.AlexisParkInn.com "Your Aviation Destination" |
On Mar 6, 7:31*pm, "BT" wrote:
Some one already mentioned the take off procedure for the C-182T (Turbo). Reduce the MP and the Fuel Flow to the Top of the Green. That is true but the C-182T is *not* turbo. -Robert |
| Thread Tools | |
| Display Modes | |
| Right prop, wrong prop? Wood prop, metal prop? | Gus Rasch | Aerobatics | 1 | February 14th 08 11:18 PM |
| Head wind takeoff into rising hills, or crosswind takeoff to open space ?? | P S | Piloting | 7 | September 20th 07 08:29 PM |
| Question on Baron 58 prop control | Mxsmanic | Piloting | 62 | December 3rd 06 06:26 AM |
| You Want Control? You Can't Handle Control! -- Was 140 dead | ArtKramr | Military Aviation | 0 | March 2nd 04 09:48 PM |
| Hydraulic CS prop converting to Adjustable prop? | Scott VanderVeen | Home Built | 0 | December 5th 03 06:54 PM |
