Mxsmanic wrote: Was this correct? I'm confused by the references to the NDB and the pointers towards the east and the procedure turn. Do I have multiple options for this approach? Was the way I flew it one of them? Or what? There are three initial approach fixes--the two on the DME arcs and the NDB. The procedure turn is for the NDB used as the initial approach fix. The idea is it's close enough to the airport that you get established outbound on the localizer. It sounds like, other than using the autopilot (which doesn't really give you any experience tracking the localizer) you flew one of the published approaches. Depending on local radar coverage, you might get vectored to the localizer, in which case you don't worry about the initial approach fix. I'm not current, and I'm not an instructor, so like the other poster said, don't take this advice if you're actually going to FLY the approach.... Mike Beede |
Mxsmanic wrote:
Kindly take a look at the ILS runway 26 approach to Astoria (KAST). I tried to fly this in my sim and I'm not at all sure that I did it correctly. In my case, this is what I did: I was on V187 from Seattle at 6000. Once I was within 25 nm of AST, I descended to 4300. About 12 nm away from AST, I turned roughly north and flew back out to 19 DME from AST, then turned east to follow the 19 DME arc until I was within a few degrees of the localizer course. At that point I started a turn towards the localizer and armed the autopilot, which captured the localizer and glide slope immediately and took over. About a mile away from the airport I disengaged the AP and flew the landing by hand. Was this correct? I'm confused by the references to the NDB and the pointers towards the east and the procedure turn. Do I have multiple options for this approach? Was the way I flew it one of them? Or what? I almost thought that maybe I was supposed to fly to the VOR then outbound to the NDB then make a procedure turn and come back in. But the DME arc had IAFs at each end so I finally figured I could just come in towards the VOR then fly back out to the arc and finally turn towards the airport, which is what I did. You did it wrong about every way possible. How long have you been playing real pilot and still don't know the basic rules? First, by what authority did you descend 700 feet flow the MEA for V-187 simply because you were within 25 miles of AST? The MEA is 5,000 all the way to AST VOR. That is basic chart reading. Then, when you turn around at about 12 miles and headed north you departed protected airspace. At some locations that could kill you but, of course, not with your MS toy. The 19 DME arc is available only to non-radar arrivals on on V-27 (R-328) from the northwest or V-27 (R-166) from the south. For any other arrival the approach begins at AST via the feeder route to KARPEN, then the procedure turn. With this one, Anthony, you demonstrate you haven't grasped even the fundamentals after how many years of ****ing around on this forum. |
Sam Spade writes:
You did it wrong about every way possible. Okay. Please describe the right way ... and provide references. First, by what authority did you descend 700 feet flow the MEA for V-187 simply because you were within 25 miles of AST? The MEA is 5,000 all the way to AST VOR. That is basic chart reading. The plate gives the MSA within a 25-nm radius. Once I was within the 25-nm radius, I could safely descend to the MSA, and I did so, because it facilitated entering the approach. Then, when you turn around at about 12 miles and headed north you departed protected airspace. I'm not sure what you mean by protected airspace. Once I was clear of the Seattle Class B, the rest of the flight was conducted entirely in Class E airspace, right up to landing. The 19 DME arc is available only to non-radar arrivals on on V-27 (R-328) from the northwest or V-27 (R-166) from the south. For any other arrival the approach begins at AST via the feeder route to KARPEN, then the procedure turn. Okay. How do you know this? Explain where and how it is documented on the plate, or where it is documented elsewhere, so that I can look it up. |
Mxsmanic wrote:
Sam Spade writes: You did it wrong about every way possible. Okay. Please describe the right way ... and provide references. First, by what authority did you descend 700 feet flow the MEA for V-187 simply because you were within 25 miles of AST? The MEA is 5,000 all the way to AST VOR. That is basic chart reading. The plate gives the MSA within a 25-nm radius. Once I was within the 25-nm radius, I could safely descend to the MSA, and I did so, because it facilitated entering the approach. You must think you are in Canada. MSAs are emergency altitudes only in the U.S. Then, when you turn around at about 12 miles and headed north you departed protected airspace. I'm not sure what you mean by protected airspace. Once I was clear of the Seattle Class B, the rest of the flight was conducted entirely in Class E airspace, right up to landing. Airspace protected from obstacles. The 19 DME arc is available only to non-radar arrivals on on V-27 (R-328) from the northwest or V-27 (R-166) from the south. For any other arrival the approach begins at AST via the feeder route to KARPEN, then the procedure turn. Okay. How do you know this? Explain where and how it is documented on the plate, or where it is documented elsewhere, so that I can look it up. Chief counsel's November, 1994 legal ruling on use of IAP's in non-radar conditions. It is available on Summit's Aviation Reference Library: The letter states in part: "You also ask whether a Distance Measuring Equipment (DME) arc initial approach segment can be substituted for a published IAF along any portion of the published arc. A DME arc cannot be substituted for a published IAF along a portion of the published arc." |
Sam Spade writes:
You must think you are in Canada. MSAs are emergency altitudes only in the U.S. Even if I grant this (the FARs mention it but do not define it), how would I then determine the minimum altitude when moving from the airway to the DME arc? The airway MEA applies only on the airway, which I had left. The sectional MEF for the quadrant in which I was operating was 1100 feet below the MSA. If I'm off-airway, and not within an area for which a MSA is published, how do I determine my minimum instrument altitude? If the MEA on the airway had been 14,000 feet, how would I get from that altitude to the appropriate altitude to capture the ILS glide slope in the distance available to me? Airspace protected from obstacles. By remaining at or above the MSA, I was protected from obstacles. This is true whether an emergency existed or not. Chief counsel's November, 1994 legal ruling on use of IAP's in non-radar conditions. It is available on Summit's Aviation Reference Library: The letter states in part: "You also ask whether a Distance Measuring Equipment (DME) arc initial approach segment can be substituted for a published IAF along any portion of the published arc. A DME arc cannot be substituted for a published IAF along a portion of the published arc." I have the letter in front of me, but I do not see the relevance of it. Explain how it applies here. I also don't see any indication of feeder routes on the IAP plate. Can you point these indications out to me? I'll ask again: Describe exactly how I should have flown this, and explain why, step by step. |
Mxsmanic wrote:
Sam Spade writes: You must think you are in Canada. MSAs are emergency altitudes only in the U.S. Even if I grant this (the FARs mention it but do not define it), how would I then determine the minimum altitude when moving from the airway to the DME arc? The airway MEA applies only on the airway, which I had left. The sectional MEF for the quadrant in which I was operating was 1100 feet below the MSA. If I'm off-airway, and not within an area for which a MSA is published, how do I determine my minimum instrument altitude? If the MEA on the airway had been 14,000 feet, how would I get from that altitude to the appropriate altitude to capture the ILS glide slope in the distance available to me? Airspace protected from obstacles. By remaining at or above the MSA, I was protected from obstacles. This is true whether an emergency existed or not. Chief counsel's November, 1994 legal ruling on use of IAP's in non-radar conditions. It is available on Summit's Aviation Reference Library: The letter states in part: "You also ask whether a Distance Measuring Equipment (DME) arc initial approach segment can be substituted for a published IAF along any portion of the published arc. A DME arc cannot be substituted for a published IAF along a portion of the published arc." I have the letter in front of me, but I do not see the relevance of it. Explain how it applies here. I also don't see any indication of feeder routes on the IAP plate. Can you point these indications out to me? I'll ask again: Describe exactly how I should have flown this, and explain why, step by step. If you don't see the relevance of the letter and you don't understand MSAs, then just go play with yourself. You are up to the same bull**** game. |
On Mar 15, 5:34*pm, Mxsmanic wrote:
Kindly take a look at the ILS runway 26 approach to Astoria (KAST). *I tried to fly this in my sim and I'm not at all sure that I did it correctly. In my case, this is what I did: *I was on V187 from Seattle at 6000. *Once I was within 25 nm of AST, I descended to 4300. *About 12 nm away from AST, I turned roughly north and flew back out to 19 DME from AST, then turned east to follow the 19 DME arc until I was within a few degrees of the localizer course. *At that point I started a turn towards the localizer and armed the autopilot, which captured the localizer and glide slope immediately and took over. *About a mile away from the airport I disengaged the AP and flew the landing by hand. Was this correct? *I'm confused by the references to the NDB and the pointers towards the east and the procedure turn. *Do I have multiple options for this approach? *Was the way I flew it one of them? *Or what? I almost thought that maybe I was supposed to fly to the VOR then outbound to the NDB then make a procedure turn and come back in. *But the DME arc had IAFs at each end so I finally figured I could just come in towards the VOR then fly back out to the arc and finally turn towards the airport, which is what I did. There is absolutely nothing ambiguous about this approach. Any rated pilot, from 50 miles out at 6000 feet on V187 would not be happy to hear center say "Cleared ILS 26, report to the tower at the outer marker inbound" but would know what to do. It would be the same thing we would do had we lost radio communication and our last clearance was to that airport. Have you any clue as to why we would not be happy to get that clearance? What would YOU do? And provide references. |
On Mar 19, 9:42*am, a wrote:
On Mar 15, 5:34*pm, Mxsmanic wrote: Kindly take a look at the ILS runway 26 approach to Astoria (KAST). *I tried to fly this in my sim and I'm not at all sure that I did it correctly. In my case, this is what I did: *I was on V187 from Seattle at 6000. *Once I was within 25 nm of AST, I descended to 4300. *About 12 nm away from AST, I turned roughly north and flew back out to 19 DME from AST, then turned east to follow the 19 DME arc until I was within a few degrees of the localizer course. *At that point I started a turn towards the localizer and armed the autopilot, which captured the localizer and glide slope immediately and took over. *About a mile away from the airport I disengaged the AP and flew the landing by hand. Was this correct? *I'm confused by the references to the NDB and the pointers towards the east and the procedure turn. *Do I have multiple options for this approach? *Was the way I flew it one of them? *Or what? I almost thought that maybe I was supposed to fly to the VOR then outbound to the NDB then make a procedure turn and come back in. *But the DME arc had IAFs at each end so I finally figured I could just come in towards the VOR then fly back out to the arc and finally turn towards the airport, which is what I did. There is absolutely nothing ambiguous about this approach. *Any rated pilot, from 50 miles out at 6000 feet on V187 would not be happy to hear center say "Cleared ILS 26, report to the tower at the outer marker inbound" but would know what to do. It would be the same thing we would do had we lost radio communication and our last clearance was to that airport. Have you any clue as to why we would not be happy to get that clearance? What would YOU do? And provide references.- Hide quoted text - - Show quoted text - Apparently I don't understand the question. This approach does not seem to be unusual, and your scenario would not make me unhappy (unless you just don't like doing full approaches). Maurice Givens CSEL, CSES, CMEL, CFI-A, CFI-I, AGI, IGI CAP Check Pilot |
On Mar 19, 1:08*pm, wrote:
On Mar 19, 9:42*am, a wrote: On Mar 15, 5:34*pm, Mxsmanic wrote: Kindly take a look at the ILS runway 26 approach to Astoria (KAST). *I tried to fly this in my sim and I'm not at all sure that I did it correctly.. In my case, this is what I did: *I was on V187 from Seattle at 6000.. *Once I was within 25 nm of AST, I descended to 4300. *About 12 nm away from AST, I turned roughly north and flew back out to 19 DME from AST, then turned east to follow the 19 DME arc until I was within a few degrees of the localizer course. *At that point I started a turn towards the localizer and armed the autopilot, which captured the localizer and glide slope immediately and took over. *About a mile away from the airport I disengaged the AP and flew the landing by hand. Was this correct? *I'm confused by the references to the NDB and the pointers towards the east and the procedure turn. *Do I have multiple options for this approach? *Was the way I flew it one of them? *Or what? I almost thought that maybe I was supposed to fly to the VOR then outbound to the NDB then make a procedure turn and come back in. *But the DME arc had IAFs at each end so I finally figured I could just come in towards the VOR then fly back out to the arc and finally turn towards the airport, which is what I did. There is absolutely nothing ambiguous about this approach. *Any rated pilot, from 50 miles out at 6000 feet on V187 would not be happy to hear center say "Cleared ILS 26, report to the tower at the outer marker inbound" but would know what to do. It would be the same thing we would do had we lost radio communication and our last clearance was to that airport. Have you any clue as to why we would not be happy to get that clearance? What would YOU do? And provide references.- Hide quoted text - - Show quoted text - Apparently I don't understand the question. *This approach does not seem to be unusual, and your scenario would not make me unhappy (unless you just don't like doing full approaches). Maurice Givens CSEL, CSES, CMEL, CFI-A, CFI-I, AGI, IGI CAP Check Pilot- Hide quoted text - - Show quoted text - The question was directed to the OP, Maury. Consider again the clearance and your position. My own preference is to not have to hurry down from en route altitudes. |
On Mar 19, 2:28*pm, a wrote:
On Mar 19, 1:08*pm, wrote: On Mar 19, 9:42*am, a wrote: On Mar 15, 5:34*pm, Mxsmanic wrote: Kindly take a look at the ILS runway 26 approach to Astoria (KAST). *I tried to fly this in my sim and I'm not at all sure that I did it correctly. In my case, this is what I did: *I was on V187 from Seattle at 6000. *Once I was within 25 nm of AST, I descended to 4300. *About 12 nm away from AST, I turned roughly north and flew back out to 19 DME from AST, then turned east to follow the 19 DME arc until I was within a few degrees of the localizer course. *At that point I started a turn towards the localizer and armed the autopilot, which captured the localizer and glide slope immediately and took over. *About a mile away from the airport I disengaged the AP and flew the landing by hand. Was this correct? *I'm confused by the references to the NDB and the pointers towards the east and the procedure turn. *Do I have multiple options for this approach? *Was the way I flew it one of them? *Or what? I almost thought that maybe I was supposed to fly to the VOR then outbound to the NDB then make a procedure turn and come back in. *But the DME arc had IAFs at each end so I finally figured I could just come in towards the VOR then fly back out to the arc and finally turn towards the airport, which is what I did. There is absolutely nothing ambiguous about this approach. *Any rated pilot, from 50 miles out at 6000 feet on V187 would not be happy to hear center say "Cleared ILS 26, report to the tower at the outer marker inbound" but would know what to do. It would be the same thing we would do had we lost radio communication and our last clearance was to that airport. Have you any clue as to why we would not be happy to get that clearance? What would YOU do? And provide references.- Hide quoted text - - Show quoted text - Apparently I don't understand the question. *This approach does not seem to be unusual, and your scenario would not make me unhappy (unless you just don't like doing full approaches). Maurice Givens CSEL, CSES, CMEL, CFI-A, CFI-I, AGI, IGI CAP Check Pilot- Hide quoted text - - Show quoted text - The question was directed to the OP, Maury. Consider again the clearance and your position. My own preference is to not have to hurry down from en route altitudes.- Hide quoted text - - Show quoted text - O.K., you're at 6000 ft on V187, AST defines V187, there is a feeder from AST to KARPEN and you're allowed to descend to 4300 ft. on the feeder. The feeder is 12.3 mi from AST to KARPEN. I think I can lose 1700 ft in 12.3 mi., do the procedure turn and intercept. Am I missing something? This does not appear to be that difficult. Maurice Givens CSEL, CSES, CMEL, CFI-A, CFI-I, AGI, IGI CAP Check Pilot |
ILS approach and VOR Alpha Approach video | DOCTOR Mary Ellen Hall McIntire Yasay, Ph.D, (Div.) | Piloting | 3 | May 22nd 08 01:52 PM |
ILS approach and VOR Alpha Approach video | [email protected] | Instrument Flight Rules | 10 | May 22nd 08 02:15 AM |
ILS approach and VOR Alpha Approach video | [email protected] | Piloting | 4 | May 17th 08 01:19 PM |
Garmin 430 rquestion- does the approach always have to be activated via "activate approach"? | Terence Wilson | Instrument Flight Rules | 46 | February 18th 08 05:46 PM |
Completing the Non-precision approach as a Visual Approach | John Clonts | Instrument Flight Rules | 45 | November 20th 03 05:20 AM |
