On Apr 2, 4:13*pm, "Tim Mara" wrote:
better you than me! I had a Libelle that had the tail cone broken and repaired by a good fiberglass glider repair shop....though unfortunately, they knew nothing about radios and used TV RF Connectors pinched onto the old coax.....which of course were incorrect type and then fell off anyway...I spent a day fishing a new coax cable through a Libelle from the panel to the antenna in the tail only because I was told it couldn't be done...never missed a single tiny hole in the bulkheads with the new leads (Had the old cable been left in place I could have spliced to it and dragged the new cable through, it however fell loose about 1/2 way in the fuselage.... Anyway, you have to have patience.....and be creative....the 2x4 idea isn't half bad, seriously..I could envision a tool (something smaller than a 2x4) that could hold a tube *in a way you could reach back there with and reinstall....but, aside from this you could, simply pull out, drill out, push out the old TE socket and epoxy in a new and better one, that would be pretty quick and easy (I also have sockets and probes for this) and /or better yet again, run the tube all the way back to the vertical fin and put a proper fin TE probe in...in any case, again glad it's not mine ![]() can help with parts and ideas... been there.....done that Tim Please visit the Wings & Wheels website atwww.wingsandwheels.com wrote in message ... The tubing from the instrument panel to the total energy probe has fallen off. * The total energy probe on my asw-15b is located half way from the cockpit to the rudder. *It's mounted from the inside of the fuselage. *There are no external bolts. *The only thing outside is a metal hole that curves aft 2.5 inches inside at the bottom of the metal sleeve. If my arm was 9 feet long I could easily reach back and slip the tubing on it. *Unfortunately my arm is about 3 feet long. *Seems like if I had a 2X2X8 with some sort of contraption built to hold the tubing at the end, I could use that to place it on. *I can't think of any ideas to have a good firm grip to slide the tubing over the inside mounting of the total energy probe. Any thoughts? Anyone know a midget I can fly into Mississippi?- Hide quoted text - - Show quoted text You'll never be able to build anything with the dexterity and precision needed to get a piece of tygon or similar tubing over a barbed fitting from 9 feet away (okay, maybe shouldn't use "never", but you get the idea). I helped somebody out with an older Grob that had the dorsal-mounted TE probe, and the only way we found to do it was to cut out out the probe very carefully, re-attach the tubing, then glass it back in. We drilled a 1/8" pilot hole right up against the flange of the probe, then slipped a hobbyists coping saw blade in and had at it. If you're very careful, you can minimize the work area. There may be a secret to the ASW-15 mounting which I'm not aware of... |
never say never
![]() but you may never do it "again" tim Please visit the Wings & Wheels website at www.wingsandwheels.com You'll never be able to build anything with the dexterity and precision needed to get a piece of tygon or similar tubing over a barbed fitting from 9 feet away (okay, maybe shouldn't use "never", but you get the idea). I helped somebody out with an older Grob that had the dorsal-mounted TE probe, and the only way we found to do it was to cut out out the probe very carefully, re-attach the tubing, then glass it back in. We drilled a 1/8" pilot hole right up against the flange of the probe, then slipped a hobbyists coping saw blade in and had at it. If you're very careful, you can minimize the work area. There may be a secret to the ASW-15 mounting which I'm not aware of... |
On Apr 2, 7:41*pm, "Tim Mara" wrote:
never say never ![]() but you may never do it "again" tim Please visit the Wings & Wheels website atwww.wingsandwheels.com You'll never be able to build anything with the dexterity and precision needed to get a piece of tygon or similar tubing over a barbed fitting from 9 feet away (okay, maybe shouldn't use "never", but you get the idea). * *I helped somebody out with an older Grob that had the dorsal-mounted TE probe, and the only way we found to do it was to cut out out the probe very carefully, re-attach the tubing, then glass it back in. *We drilled a 1/8" pilot hole right up against the flange of the probe, then slipped a hobbyists coping saw blade in and had at it. * If you're very careful, you can minimize the work area. There may be a secret to the ASW-15 mounting which I'm not aware of... I'm building up a long list of jobs I will only attempt once :-) |
For what its worth... A couple of years ago the Late Great Dick Johnson
wrote a article in Soaring, about installing a TE probe on his Ventus. It was placed on top of the fuselage not far behind his canopy. He had all the tests of heights, sizes etc and test results of the the performance..It looked like it worked quite well. This may be way easier than the other options...And very easy to troubleshoot leaks. It seemed to me to be very simple and very functional. Nick Kennedy At 23:50 02 April 2009, Papa3 wrote: On Apr 2, 7:41=A0pm, "Tim Mara" wrote: never say never ![]() but you may never do it "again" tim Please visit the Wings & Wheels website atwww.wingsandwheels.com You'll never be able to build anything with the dexterity and precision needed to get a piece of tygon or similar tubing over a barbed fitting from 9 feet away (okay, maybe shouldn't use "never", but you get the idea). =A0 =A0I helped somebody out with an older Grob that had the dorsal-mounted TE probe, and the only way we found to do it was to cut out out the probe very carefully, re-attach the tubing, then glass it back in. =A0We drilled a 1/8" pilot hole right up against the flange of the probe, then slipped a hobbyists coping saw blade in and had at it. =A0 If you're very careful, you can minimize the work area. There may be a secret to the ASW-15 mounting which I'm not aware of... I'm building up a long list of jobs I will only attempt once :-) |
Come on guys. We can be more creative that this! We are the best at
this sort of thing, right? How about inserting a pin or wire coat hanger through the TE hole to act as a temporary guide for the tubing on the inside. You could push a video camera down the fuselage near the hole so you could see what you were doing on a monitor. How about a little hair spray inside the end of the Tygon tubing to lube it up and then lock it in place when it drys? Bicycle shops use this technique to put grips on handle bars. Instead of a coat hangar through the TE hole, how about something that could temporarily expand on the inside and grab the inside of the tygon. Something like a small molly bolt? Or one of those 4 pronged picker-uppers. Or make something out of small brass tubing from the hobby shop that flairs the end when you pull a wire through the middle. Then you could pull the tubing over the inside nipple from the outside by pulling on the molly bolt or whatever. How about suction on the outside TE tube to help grab the tygon when it gets close to the inside nipple with the long pole you made out of lightweight PVC pipe. Or just get a string through the TE probe hole, then thread the string all the way down the Tygon, then just pull into place. You should be able to apply lots of force by pulling on the string through the TE hole if you tie the string off on the cockpit side to the end of the tubing. I like this last idea best, but I bet this list can come up with 10 better ones. Matt |
OK, now I can't stop. Details on the string idea
1) Thread a foot or so of string into the TE hole from the outside. 2) Put a wad of duct tape, sticky side out, on the end of a broom stick and use that to fetch the end of the string from the inside of the fuselage. 3) use a #11 Exacto knife to gently chamfer the inside of the tubing so it will start more easily over the inside of the TE tube 4) thread the string through the tubing by taping the far end of the tubing (non chamfered) to a vacuum cleaner and letting it suck the string all the way through the tubing. 5) Unhook the vacuum cleaner and tie of the string to that end of the tubing. 6) Have a helper pull the string back through the TE hole, and apply some tension as you giggle the tube around from the inside with the broomstick 7) Inspect your work with the family video cam, then pull the string back through the tubing from the vacuum end. 8) Celebrate with a frosty beverage of your choice, as you bask in the knowledge that Glider pilots are more resourceful than any other species on the planet. Might be worth a try. At least I know you can accomplish #8 ;-) |
These things are so obvious once someone has explained them!
The vacuum cleaner you need for this enterprise is clearly the Rowland Emmett "Little Dragon Carpet Cleaner" (visible at http://www.picturetrail.com/sfx/album/view/2472299). Nothing less will do. BTW, I really do hope this works. Matt wrote: OK, now I can't stop. Details on the string idea 1) Thread a foot or so of string into the TE hole from the outside. 2) Put a wad of duct tape, sticky side out, on the end of a broom stick and use that to fetch the end of the string from the inside of the fuselage. 3) use a #11 Exacto knife to gently chamfer the inside of the tubing so it will start more easily over the inside of the TE tube 4) thread the string through the tubing by taping the far end of the tubing (non chamfered) to a vacuum cleaner and letting it suck the string all the way through the tubing. 5) Unhook the vacuum cleaner and tie of the string to that end of the tubing. 6) Have a helper pull the string back through the TE hole, and apply some tension as you giggle the tube around from the inside with the broomstick 7) Inspect your work with the family video cam, then pull the string back through the tubing from the vacuum end. 8) Celebrate with a frosty beverage of your choice, as you bask in the knowledge that Glider pilots are more resourceful than any other species on the planet. Might be worth a try. At least I know you can accomplish #8 ;-) |
Matt wrote:
OK, now I can't stop. Details on the string idea 1) Thread a foot or so of string into the TE hole from the outside. 2) Put a wad of duct tape, sticky side out, on the end of a broom stick and use that to fetch the end of the string from the inside of the fuselage. 3) use a #11 Exacto knife to gently chamfer the inside of the tubing so it will start more easily over the inside of the TE tube 4) thread the string through the tubing by taping the far end of the tubing (non chamfered) to a vacuum cleaner and letting it suck the string all the way through the tubing. 5) Unhook the vacuum cleaner and tie of the string to that end of the tubing. 6) Have a helper pull the string back through the TE hole, and apply some tension as you giggle the tube around from the inside with the broomstick 7) Inspect your work with the family video cam, then pull the string back through the tubing from the vacuum end. 8) Celebrate with a frosty beverage of your choice, as you bask in the knowledge that Glider pilots are more resourceful than any other species on the planet. Might be worth a try. At least I know you can accomplish #8 ;-) Just before you pull the new TE tube, insert a pair of needle nose pliers into the end of the tube and pull apart on the grips to stretch the tubing out. This may take a while, but it will open up, . Once it's in place it will slowly reform to it's initial shape. And the hairspray idea will help too. |
I'm on pins and needles awaiting the exciting conclusion to this
soaring drama. Can't wait to hear how it all turns out. ============== Here is my idea: I had to do something like this to get some ductwork through a crawlspace. If you can feed something down into the hole from the outside, you are a long way towards solving this puzzle. I would push down some stiff wire like fencing wire or some 0.041 aviation safety wire. You might need to start with light string. It will be an somewhat easy matter to retrieve the string, then wire, from inside the fuselage (long stick, etc). Now feed the tubing back along this stiff wire (wire goes inside the tubing of course). Champhering the inside lip or streaching it with needlenose (warm the tubing first) is a great idea to get it started on the tubing. I definately don't like putting any type of lube on the inside of the tubing as this could get into your vario. Bad news. Now, how to force the tubing onto the stem? You need something long, light weight which won't deform. One inexpensive idea is a suspended ceiling T shapped main runner. Find them at DIY stores. They are 10 feet long, cheap, and fulfill the other requirements. Attach the tubing to the end of the T runner. I don't think that tape will do. I am thinking some type of lasso through a hole at the end of the T runner so that you can grip the tubing strongly and still be able to release it. Now, how to apply upward force 9 feet out? Tricky. I think that you can get something about 4 feet into the fuselage that could be used as a fulcrum for a lever for the T runner. A box might do. Be sure to tie a string to it to retrieve it. A second T runner could be used as a kind of "hammer" to bang on the bottom of the first runner which may help. Good luck. Take deep breaths. Find a friend to help. May the force be with you. |
Flexible exhaust tubing | Stuart & Kathryn Fields | Home Built | 16 | July 13th 08 02:48 AM |
Relesable instrument tubing | [email protected] | Soaring | 6 | February 13th 07 05:38 AM |
pvc tubing/sleeve source? | Jim Burns | Home Built | 4 | September 28th 06 03:36 AM |
Gauge of tubing??? | Michael Horowitz | Home Built | 7 | June 6th 06 01:32 PM |
Tubing strength | Ernest Christley | Home Built | 0 | January 16th 04 11:43 PM |
