On Apr 16, 2:50*pm, "Morgans" wrote:
How long it will last is another story. *If you set it to not boost too high, it might last a thousand hours. I doubt it. They're an 1800-hour engine that almost always need top overhauls well before then, sometimes before mid-time. Boosting it would overstress already-weak valves and it wouldn't go too far at all. And with the traditionally low oil pressure these things have, the bottom ends wouldn't last too long either. The crank was not nitrided and wears rather rapidly anyway. The same basic engine was boosted to 75 hp (A-75) using a higher redline and heavier piston pins and a slightly larger carb venturi and main jet. They got 80 hp (A-80) by raising the compression to 7.55:1 from 6.5 as well as the higher redline and bigger carb. And that's about as much as they dared get from 140 cubic inches with the engine being as light as it is. Dan |
hmmm....
thought to replace my Revmaster with this Conti, but now, mybe I better stay with the VDub? schrieb im Newsbeitrag ... On Apr 16, 2:50 pm, "Morgans" wrote: How long it will last is another story. If you set it to not boost too high, it might last a thousand hours. I doubt it. They're an 1800-hour engine that almost always need top overhauls well before then, sometimes before mid-time. Boosting it would overstress already-weak valves and it wouldn't go too far at all. And with the traditionally low oil pressure these things have, the bottom ends wouldn't last too long either. The crank was not nitrided and wears rather rapidly anyway. The same basic engine was boosted to 75 hp (A-75) using a higher redline and heavier piston pins and a slightly larger carb venturi and main jet. They got 80 hp (A-80) by raising the compression to 7.55:1 from 6.5 as well as the higher redline and bigger carb. And that's about as much as they dared get from 140 cubic inches with the engine being as light as it is. Dan |
On Apr 17, 3:13*am, "oilsardine" wrote:
hmmm.... thought to replace my Revmaster with this Conti, but now, mybe I better stay with the VDub? Now you have me confused. If you are thinking that you need to up the hp of the Cont to match the performance of the Revmaster you've been drinking someones Kool-aid....................by the pool full :-) Seriously, more info would help. What is you goal? What kind of plane? If your plane can handle the extra weight, required prop length and the C 65 is a good buy you might be better off with the C 65. If your flying something like a KR originally designed around a VW your probably going to be better off letting the C 65 rest. Is your Reve giving you problems or less than expected performance? There are other options to consider. Subaru n 'Vair pop to mind. ============== Leon McAtee |
![]() schrieb im Newsbeitrag ... ..... Seriously, more info would help. What is you goal? What kind of plane? I have a Revmaster (normal aspirated) in an slightly :-) overweight Sonex. The plane hasn't flown yet. Some extra HP could help. The Conti would fit weight-wise, but seems also underpowered for this application. The Conti turns slower than the Revmaster, but my prop diameter is limited by ground clearance... |
On Apr 17, 8:41*am, "oilsardine" wrote:
schrieb im ... .... Seriously, more info would help. *What is you goal? *What kind of plane? I have a Revmaster (normal aspirated) in an slightly :-) overweight Sonex.. The plane hasn't flown yet. Some extra HP could help. The Conti would fit weight-wise, but seems also underpowered for this application. The Conti turns slower than the Revmaster, but my prop diameter is limited by ground clearance... Kinda spected this was where we was headed. Unfortunately I don't know of a good solution to your problem. The prop diameter limitation and intended cruise speed (common on lots of VW based designs) means for all practical purposes you are stuck with a direct drive solution, and in this power range the options are limited. The Subaru won't gain much over the VW in direct drive configuration and adds the complexity of water cooling. Making some assumptions about your Sonex, a Rotax with a 3 blade prop might be an improvement? But it too is water cooled. Some seem to like the Jabiru as a VW substitute. How much over weight? Would a diet be a better solution? Too bad there isn't an inexpensive controllable pitch prop available for this kind of application........................other than the Ivo? Editorial comment: 2 place VW powered planes are practical IF BUILT LIGHT and the true limitations of a VW based engine are kept in mind. Unfortunately it seems that builders of everything from Cygnets to Qs and Vari EZs fixate on advertised numbers and we end up with dissatisfied builders due to less than advertised performance. In most cases it's not due to "embellished" factory numbers but the fact that in this weight and Hp range there just isn't any more to give and a hundred, even 50, pounds more makes a drastic cut in performance. This is one of the oldest stories in home built aviation, and not limited to VW designs. It's sad that it keeps getting repeated. If expectations were more realistic, and thus met, maybe our sport/hobby would have more active members? ========================== Leon McAtee |
![]() schrieb im Newsbeitrag ... .... Kinda spected this was where we was headed. Unfortunately I don't know of a good solution to your problem. The prop diameter limitation and intended cruise speed (common on lots of VW based designs) means for all practical purposes you are stuck with a direct drive solution, and in this power range the options are limited. yes, and financial options are limited as well at this times... The Subaru won't gain much over the VW in direct drive configuration and adds the complexity of water cooling. Subaru may be over the Sonex 200 lb firewall forward limit Making some assumptions about your Sonex, a Rotax with a 3 blade prop might be an improvement? But it too is water cooled. financial limits... Some seem to like the Jabiru as a VW substitute. 6-cyl. Jab is the optimal powerplant but $$$$$.... How much over weight? Would a diet be a better solution? I said the SONEX is overweight, not me ;-)) Too bad there isn't an inexpensive controllable pitch prop available for this kind of application........................other than the Ivo? Ivo and direct drive 4-cyl., not a good match... Editorial comment: .... very true |
On Apr 17, 10:31*am, "oilsardine" wrote:
I said the SONEX is overweight, not me ;-)) I didn't mean you needn' a diet, though I could use one ..... again :-) 20 pounds in a plane designed for 18 HP makes a huge difference. I was thinking maybe your - Sonex - had a few "extras" that could be shed? Given the 200# FWF limit (less than I expected which shows my ignorance of the Sonex) your options get fewer. Wish I could be of more help..................... ================== Leon McAtee |
On Apr 17, 9:41*am, "oilsardine" wrote:
schrieb im ... .... Seriously, more info would help. *What is you goal? *What kind of plane? I have a Revmaster (normal aspirated) in an slightly :-) overweight Sonex.. The plane hasn't flown yet. Some extra HP could help. The Conti would fit weight-wise, but seems also underpowered for this application. The Conti turns slower than the Revmaster, but my prop diameter is limited by ground clearance... You may be able to rework your Revmaster with a different stroker crank for better thrust, Bob Hoover's made a believer of me on this as well as using the right prop combination. Another option that has greatly impressed me is the BMW 1150 or 1200 M/C engines set up with a good redrive. These produce good performance numbers with a lot of positive feedback. HP varies per engine and set up from 90 to 100-100+. One of these in a Sonex looks very appealing to me, but again I expect that you can do a bit better with your Revmaster than you expect. |
On Apr 17, 11:30�pm, Copperhead wrote:
On Apr 17, 9:41�am, "oilsardine" wrote: schrieb im ... .... Seriously, more info would help. �What is you goal? �What kind of plane? I have a Revmaster (normal aspirated) in an slightly :-) overweight Sonex. The plane hasn't flown yet. Some extra HP could help. The Conti would fit weight-wise, but seems also underpowered for this application. The Conti turns slower than the Revmaster, but my prop diameter is limited by ground clearance... You may be able to rework your Revmaster with a different stroker crank for better thrust, Bob Hoover's made a believer of me on this as well as using the right prop combination. Another option that has greatly impressed me is the BMW 1150 or 1200 M/C engines set up with a good redrive. These produce good performance numbers with a lot of positive feedback. HP varies per engine and set up from 90 to 100-100+. One of these in a Sonex looks very appealing to me, but again I expect that you can do a bit better with your Revmaster than you expect. Tundra tires will give you more ground/prop clearance (;o) |
Isn't someone flying a Sonex with a Corvair?
Continental 757 18R @ MCO | Glen in Orlando | Aviation Photos | 4 | November 30th 06 03:15 AM |
Continental O-200 ? | Stealth Pilot | Home Built | 48 | September 23rd 06 06:32 PM |
continental 4 banger | Philippe Vessaire | Home Built | 2 | May 19th 06 04:27 AM |
Continental 0-200 | Robert | Home Built | 0 | August 31st 05 11:57 AM |
Continental 0-200 | Robert | Home Built | 0 | April 3rd 04 03:08 AM |
