RTFM
Old April 29th 09, 12:41 AM posted to rec.aviation.piloting
Steven P. McNicoll[_2_]
Default RTFM
Private wrote:
RTFM
http://www.rense.com/general85/Airbus340.pdf
Funny, but not quite true.
http://www.snopes.com/photos/airplane/etihad.asp
Old April 29th 09, 01:13 AM posted to rec.aviation.piloting
Private
Default RTFM
RTFM
Old April 29th 09, 01:29 AM posted to rec.aviation.piloting
Dudley Henriques[_2_]
Default RTFM
On Apr 28, 7:41*pm, "Steven P. McNicoll"
Private wrote:
RTFM
Actually it's pretty close to the truth. The SOP for the engine tests
as far as I can determine, called for the tail to be tied down which
it wasn't. I'm not absolutely certain about this, but I believe the
brakes including the parking brake won't restrain this aircraft at
full thrust anyway; hence the tail tie down requirement.
Just as a comparison, I can't hold a T38 after a line check with
brakes at full max thrust, and even a P51 will jump the chocks at 40
inches :-)
At the very least, these guys were an accident waiting to happen and
the wait ran out.
Dudley Henriques
Old April 29th 09, 02:27 AM posted to rec.aviation.piloting
Mike Ash
Default RTFM
In article
Private wrote:
RTFM
inches :-)
the wait ran out.
It's not all that close to the truth. The overall story is more or less
true. The details are somewhat off. The anti-Arab sentiment is
completely wrong.
This made the rounds on my flying club mailing list a month back and
here is the response I wrote to summarize my research:
Interesting accident! I got hungry for more information and found the
report from the French equivalent of the NTSB. (Located here, in French:
http://www.bea.aero/docspa/2007/f-cj...f-cj071115.pdf)
That report paints a slightly different picture in the details, although
the major points (bad test procedures, bad responses, totaled expensive
airplane) are right. Notably:
- Two out of the three people in the cockpit were Airbus employees. (The
third was present on behalf of Etihad to receive the new plane.)
- The aircraft's parking brake was used for the test. The plane started
to slowly roll forward after sitting still for three minutes at full
power. Apparently the parking brake was almost perfectly matched with
full engine thrust.
- No mention of circuit breakers or brake disablement that I saw, but
frequent mention is made of the fact that the test was performed without
chocks, despite an explicit requirement for them in the relevant manuals.
- The Airbus technician at the controls fixated on the brakes and did
not think to pull the throttles back. He did however attempt to turn
away from the wall. Unfortunately for this aircraft, the steering system
and braking system are connected and steering inhibits braking in the
center wheels.
- The other Airbus technician finally pulled power, but far too late.
- A total of nine people were on board, four of whom were seriously
injured in the accident.
Lessons to be learned that I saw:
- Don't get fixated.
- When the manual says to do things a certain way, it's usually a good
idea to do things that way.
- The ability to make unimaginably expensive boneheaded mistakes
transcends all cultural boundaries.
Mike Ash
Radio Free Earth
Broadcasting from our climate-controlled studios deep inside the Moon
Old April 29th 09, 02:31 AM posted to rec.aviation.piloting
Default RTFM
On Apr 28, 7:41 pm, "Steven P. McNicoll"
Private wrote:
RTFM
Actually, "pretty close to the truth" and "not quite true" are pretty much
the same thing.
Old April 29th 09, 04:28 AM posted to rec.aviation.piloting
Default RTFM
On Apr 28, 9:31*pm, "Steven P. McNicoll"
Private wrote:
RTFM
the same thing.
True.
This accident came in to our safety group via one of our airline guys
as a "note of interest"
rather than something we would be working on.
After reading the report, the only opinion I formed was that the tail
should have been tied down for any test at max thrust and that whoever
was in charge of the test (presumably the left seat) should have been
familiar with the test procedures AND checked out enough on power
lever use to know completely the emergency shutdown procedure if
something went wrong. Not bringing the power back prior to and
coincident with brake application seemed to me an inexcusable error.
Task overload shouldn't have been an issue as far as power reduction.
That was a normal procedure failure.
As to the Arab question; I didn't even consider nationality in my
rationale; simply the body in charge :-)
-DH
Old April 29th 09, 04:35 AM posted to rec.aviation.piloting
Default RTFM
On Apr 28, 9:27*pm, Mike Ash wrote:
In article
Private wrote:
RTFM
inches :-)
the wait ran out.
completely wrong.
report from the French equivalent of the NTSB. (Located here, in French:http://www.bea.aero/docspa/2007/f-cj...f-cj071115.pdf)
full engine thrust.
center wheels.
Mike Ash
Radio Free Earth
The ultimate failure here seems to have been the lack of experience of
the tech on the power levers. I'm sure much of the investigation
centered on this, and as well the process and people responsible for
putting him in the left seat to conduct the test.
Power reduction to idle HAD to be accomplished before braking could
be effective. This should have been a trained reaction to the
emergency rather than a checklist task item that he missed.
Shame. It was a beautiful aircraft to be lost in this way.
-DH
Old April 29th 09, 12:39 PM posted to rec.aviation.piloting
Steve Foley[_4_]
Default RTFM
m...
the same thing.
But not quite the same thing g
Old April 29th 09, 01:54 PM posted to rec.aviation.piloting
Default RTFM
On Apr 29, 7:39*am, "Steve Foley" wrote:
"Steven P. McNicoll" wrote in messagenews:KrudnRC5wISKM2rUnZ2dnUVZ_hKdnZ2d@earth link.com... Actually, "pretty close to the truth" and "not quite true" are pretty much
the same thing.
One might say it was exactly the same only just a bit different :-))
-DH
Old April 29th 09, 01:56 PM posted to rec.aviation.piloting
Mike Ash
Default RTFM
In article
As with most accidents it's a chain of events, but pulling power is an
obvious last step that would have saved the day.
I wonder just how much training these technicians got on the aircraft. I
have no idea if it's a lot or a little, but seeing as how they never
leave the ground I could imagine that they are being put out there
without enough. I can certainly see some penny-pinchers saying, "they
never leave the ground, how hard can it be?"
Mike Ash
Radio Free Earth
