"PENTAGON WORKING TO GIVE F-35 JSF NUCLEAR-STRIKE CAPABILITY"
Old May 7th 09, 08:44 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Ken S. Tucker
Default "PENTAGON WORKING TO GIVE F-35 JSF NUCLEAR-STRIKE CAPABILITY"
On May 6, 6:54 pm, J wrote:
On May 4, 4:05 pm, Ed Rasimus wrote:
2.) Disabuse yourself from the notion that a CV is any sort of easy
target. I spent a lot of years trying to successfully do just that in
exercises. It is damn close to impossible.
Ed,
Were you ever successful? (To the extent you can say.)
Thanks . . . J
Ed's comment was directed to me on May 4th.
I *think* he's suggesting a fighter attack on a CVN.
Currently, cruise missiles and/or MRBM's, because
of the wide spread availability of precision electronic
guidance, basically has a CVN as equivalent to a
heavily armored *blimp* in a fluid.
IIRC, the last war where severe attacks were waged
on CV's with a large defensive screen was off Okinawa,
with kamikazes operating as missiles.
Ken
Old May 7th 09, 09:32 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Keith Willshaw[_4_]
"Ken S. Tucker" wrote in message
Ed,
Thanks . . . J
Neither MRBM's nor most cruise missiles are well suited to
attacks on moving targets. The guidance systems on ballistic
missiles are designed to hit a given set of co-ordinates and
the flight dynamics make terminal manoeuvering very difficult
even if you had sensors capable of penetrating the plasma
around the vehicle.
Cruise missiles have the problem of being targets in their own
right and so typically fly low which makes searching for the
target very difficult and makes for a high likelihood of
attacks on the wrong vessel (see Atlantic Conveyor and Falklands)
There are a few systems like the Russian Granit designed to
operate in swarms where one missile will pop up to medium altitude
to provide course correction information for the others but that
of course leaves them open to spoofing and meaconing.
Ken
Okinawa was rather unusual. The CV's were tied to small area by
the requirement to provide air cover for the invasion fleet.
Worse still they were within range of the enemies (large) air force.
That said such refinements as AEW radar rose directly from that
experience.
Keith
Old May 7th 09, 07:41 PM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Ken S. Tucker
On May 7, 12:32 am, "Keith Willshaw"
"Ken S. Tucker" wrote in ...
Ed,
Thanks . . . J
As a back-drop, 27 years ago,
http://en.wikipedia.org/wiki/Exocet#Falklands_Conflict
(Seems like yesterday).
around the vehicle.
Things could have changed. I have a good idea
of what's *technically* possible, I hope you're
right.
ditto.
It's a bit difficult to hide a CVN from a satellite.
Ken
experience.
I deviated the topic to F-35 (nuke able) for the navy
is to be absolutely unnecessary and of nil usefulness.
(The A-5 Vigilante again).
I'll go further, all nuke weapons should be banned by
treaty from international waters and air space.
Ken
Old May 7th 09, 10:09 PM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Keith Willshaw[_4_]
in
Ed,
Thanks . . . J
Delivered by aircraft as a standoff weapon, the target identification
was down on board the aircraft.
around the vehicle.
right.
ditto.
Sure but getting real time location from a satellite is difficult and
VERY expensive
1) Any given low earth recon birds will only revisit any given spot
at infrequent periods typically measured in daysor at best hours
rather than minutes
2) Standard recon satellites use optical or infrared methods which
limits their effectiveness in case of clud cover
3) Even if your satellite happens to fly over a CVN you have to
have people analysing the data in real time.
To get round the problems the Soviets launched a whole series
of Radar satellites (RORSAT). These were BIG and typically
powered by type BES-5 nuclear reactors. They weighed in at
around 4 tons and to get decent coverage of even a fairly small
part of the planet they had to launch a whole constellation of
them at vast expense.
AFAIK there have been no such satelllites in service for more
than a decade.
Ken
experience.
Ken
There goes the US nuclear deterrent
Keith
Old May 7th 09, 10:32 PM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
frank
On May 7, 3:09*pm, "Keith Willshaw"
in
Ed,
Thanks . . . J
around the vehicle.
right.
ditto.
VERY expensive
at infrequent periods typically *measured in daysor at best *hours
rather than minutes
3) Even if your satellite happens to fly over *a CVN you have to
than a decade.
Ken
experience.
Ken
Keith
Back when 'those were the days' the Soviets though nothing of putting
up stuff weekly, even if it had to be replaced in a few months due to
low orbits. Would even launch recon sats just for an exercise. Overfly
this battle group or whatnot.
Way different than how the US did it. But, our stuff was like the
Energizer bunny, kept going and going and going....
cost real money too. No wonder the had a black budget.
Old May 7th 09, 10:48 PM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Jack Linthicum
in
Ed,
Thanks . . . J
around the vehicle.
right.
ditto.
VERY expensive
rather than minutes
than a decade.
Ken
experience.
Ken
Keith
Difference between communications from orbit and the Soviet
requirement to land the bird to get the film out.
Old May 8th 09, 12:29 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Keith Willshaw[_4_]
"Jack Linthicum" wrote in message
Incorrect, the RORSAT's were not optical but radar devices and
the data was sent back to base via telemetery. The problem for the
RORSAT was that because the strength of the return signal from
radar is inversely proportional to the fourth power of the distance.
This meant they had to be in a very low orbit that decayed rapidly.
To avoid radioactive contamination the reactor core was supposed
to be ejected and boosted into a high orbit at the end of a service life
that was typically around 3 months.
This is a very different mission profile to an optical reconnaissance
satellite.
Keith
Old May 8th 09, 05:50 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
frank
in
Ed,
Thanks . . . J
around the vehicle.
right.
ditto.
VERY expensive
rather than minutes
than a decade.
Ken
experience.
Ken
Keith
Jettison film packs were de rigeur for a while. Soviets obviously had
large enough land mass to make it work.
Amazing what sort of job security there were in various types of
specialties. One was counting film packs and matching them to bird in
orbit. Out of film, expect a new launch.
Both sides did this. Paid for lots of brewskis and chiles.
Newer technology is downlinking all that data. Interestingly, a lot
were doing stuff like take film, process in orbit, read it then scan
it and send data down. Engineers got smart and did away with film as
intermediate step. some engineers are smart. Do good stuff.
As opposed to the one who sit as GIB and when told not to touch
anything, not to pull tape off of knobs and dials, do it anyway. Why
they were not ejected is a mystery. Wonder what happens if I pull this
up....
Old May 8th 09, 08:38 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Ken S. Tucker
On May 7, 1:09 pm, "Keith Willshaw"
Keith, I was rather hoping the "27 years ago" might
be a hint.
VERY expensive
This works, it's civilian,
http://en.wikipedia.org/wiki/RADARSAT-1
rather than minutes
than a decade.
Today, using conventional ordinance, an MRBM
put in the ballpark of a CVN will terminal guide to a
probable direct hit, even choosing where to hit.
If the CVN+fleet is converted into a floating nuke
strike base, it becomes #1 target to MIRV, as in
10 100kt bombs detonated over a fleet.
Ken
Keith
Maybe the nuke subs lurkin' off the US coasts on hair
trigger can go home, if it's ok with American citizens.
Ken
Old May 8th 09, 09:51 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
frank
be a hint.
VERY expensive
This works, it's civilian,http://en.wikipedia.org/wiki/RADARSAT-1
rather than minutes
than a decade.
Ken
Keith
Ken
You must have missed Cheney's memo. Its all peace love and
tranquility. Ed has long hair, throws rose petals. They all luv us. no
more hair triggers.
Now, it takes what minutes to get back to a hair trigger alert, but
most people don't understand that.
Guess the politicians are happy. Slip them another beer.
"Pentagon Wants Kill Switch for Planes" Jim Logajan Piloting 24 June 16th 08 04:27 PM
Spinner strobing as a "Bird Strike Countermeasure" Jim Logajan Piloting 259 December 13th 07 06:43 AM
Spinner strobing as a "Bird Strike Countermeasure" Jim Logajan Home Built 212 December 13th 07 02:35 AM
"British trace missile in copter strike to Iran" Mike[_7_] Naval Aviation 8 March 10th 07 09:20 PM
"Pentagon Command Shuffle Rekindles Equity Debate" Mike Naval Aviation 1 January 26th 07 04:04 PM
