Building an electronic Angle of Attack indicator
Old May 9th 09, 06:58 PM posted to rec.aviation.homebuilt
Jim Logajan
Default Building an electronic Angle of Attack indicator
Jim Logajan wrote:
I'd post a link to a picture of what it would look like
(pretty simple concept) but can't see to find one!
Okay, found some, like this one:
http://commons.wikimedia.org/wiki/Fi...ndicator_1.jpg
And a simple mechanical kit (looks like no longer available):
http://www.aircraftspruce.com/catalo...baconsaver.php
My suspicion is that designers get fancy and use things like two non-
parallel pitots and use some mechanism to compute the AoA from their
differential pressures, which is then presented in some fancy digital
display. The irony is that AoA is easy to show, and if one is flying a
glider or pusher, a simple mechanical device could probably be mounted so
it is visible out front (i.e. "heads up") so that one can see the AoA at
the same time one is controlling their approach. But I suppose it'd be too
distracting during crusing flight and mess up the "look" of the airplane.
Just think of the yaw string on gliders (e.g. the red string in this
pictu
http://www.highonadventure.com/Hoa08...eYawString.jpg) but
used to show vertical component of the relative wind, not horizontal.
Use variable capacitance, variable reluctance, resistor strip or
synchro connected to a vane. For a real giggle do as some Air Force
systems and employ a slotted, rotating cone for a probe. It involves
a feedback loop.
Dan, U.S. Air Force, retired
Old May 9th 09, 09:15 PM posted to rec.aviation.homebuilt
cavelamb[_2_]
My favorite one has no moving parts.
Just two thermosistors in the pitot tube...
and an opamp circuit to read differential cooling.
Prop angle of attack vs age sid Piloting 47 July 13th 08 04:46 PM
Glider angle of attack indicator by SafeFlight Bill Daniels Soaring 53 December 20th 07 12:29 PM
Angle of attack Bill Daniels Soaring 27 December 19th 07 06:17 AM
preferrred bank angle indicator? Matt Herron Jr. Soaring 34 July 10th 06 02:22 PM
Lift and Angle of Attack Peter Duniho Simulators 9 October 2nd 03 10:55 PM
