Yo! Fuel Tank!
Old October 21st 03, 06:04 PM
Kyle Boatright
For what it is worth, most of today's RV builders DON'T use slosh in their
tanks. In the old days, some builders were having problems with slosh
coming loose. Imagine having to open up a tank to remove mis-applied slosh
(or risk clogging your fuel filter with the stuff when it flakes off). Some
builders who didn't slosh had a leak or two, but it was easier dealing with
the leaks than with slosh that wasn't staying attached...
In the end, if you do everything right, you don't need slosh. Beyond that,
if you slosh *properly* the slosh won't come loose. It comes down to
following proper fitting, cleaning, and prep procedures all the way through
the process - slosh or not.
KB
Old October 21st 03, 11:47 PM
Veeduber
To All:
Someone wrote to ask where they might find 'dimensioned drawings' as mentioned
in the post on fuel tanks.
Welll... they aren't all that good but you'll find simple drawings for most of
the stuff I've written about in the FILES archives of the Fly5kfiles mailing
list over on Yahoo, or one of the other mailing lists (FlyVW, etc). The
drawings are in DeltaCAD format. There's a link to the free DeltaCAD reader
software. The drawings are usually supported by a .txt file, an article or a
posted message but the linkage isn't always given.
These drawings are meant mostly for scratch builders trying to fly on the
cheap. If that's you, you probably already know about the drawings and their
related files. If any of this is news to you, you might want to scan the
archives of groups devoted to flying on the cheap and lo-buck building.
-R.S.Hoover
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 07:09 PM
Protecting fiberglass from fuel & oil Paul Lee Home Built 2 September 18th 03 06:14 AM
Fuel pressure Problems smf Home Built 3 September 7th 03 08:25 PM
Hot weather and autogas? Rich S. Home Built 33 July 30th 03 11:25 PM
Question ~ Does fuel injection add weight? Barnyard BOb -- Home Built 0 July 6th 03 09:47 PM
