I am looking for a source of the AD 92-190/2 SB 315-45/2 on the web without
	luck. Anybody out there can help? MC  |
For current AD's you can go to FAA.gov and look under the aircraft
	tab. There you will find all sorts of good info including type certificates and AD's.  |
On May 17, 5:52*pm,  wrote:
	For current AD's you can go to FAA.gov and look under the aircraft tab. *There you will find all sorts of good info including type certificates and AD's. You are actually looking for the LBA 92-190-2 that mandates the Service Life Extension inspection at 3000, 6000, 9000, and 12000 hours. The LBA mentions the Grob SB 315/45 and 315/45-2. I could find the LBA via Google, but could not find the referenced SB on the Grob web page. Check with the new Grob Rep in Moriarty NM  |
| Thread Tools | |
| Display Modes | |
| Grob 103 Twin II Life Extension | Mike McCarron[_2_] | Soaring | 2 | May 18th 09 02:15 PM |
| Grob Twin III Must read! | [email protected] | Soaring | 3 | June 9th 08 08:08 AM |
| LS-6A and B life extension | JS | Soaring | 0 | December 8th 05 11:56 PM |
| Life extension LS6 a-b | Stuart | Soaring | 1 | January 20th 05 06:16 AM |
| Puchacz life extension | Janusz Kesik | Soaring | 0 | November 9th 03 10:49 AM |
