On Jun 2, 9:20*am, jan olieslagers
wrote: Veeduber schreef: Lots of interesting ideas coming out. Indeed, certainly to the eyes of this non-mechanic. But few seem to answer your original search for an alternative for the VW: a light engine of 40-60 HP, typical for a single seater. Or what did I miss? For that application, the Citroen 2-cylinder aircooled boxer seems one of the rare alternatives; though it is smaller than the VW. ---------------------------------------------------------------------------- "Or what did I miss?" The Atlantic Ocean :-) The 2CV is an excellent engine, suitable for single-seaters having low drag and a generous wing. But so few of them were exported it is virtually unknown in the United States. The engine received excellent coverage in auto magazines some years ago when two engines were fitted to a vehicle which was then used as a 4WD for crossing the Sahara Desert. Overhauling this engine is not for the inexperienced. It uses specially shaped pistons which must be installed properly or the valve will contact the piston, which usually results in a trashed engine. -Bob |
Veeduber schreef:
On Jun 2, 9:20 am, jan olieslagers wrote: Veeduber schreef: Lots of interesting ideas coming out. Indeed, certainly to the eyes of this non-mechanic. But few seem to answer your original search for an alternative for the VW: a light engine of 40-60 HP, typical for a single seater. Or what did I miss? For that application, the Citroen 2-cylinder aircooled boxer seems one of the rare alternatives; though it is smaller than the VW. ---------------------------------------------------------------------------- "Or what did I miss?" The Atlantic Ocean :-) OK Bob, thanks for the reminder... Still, you asked for a 40-60 HP engine and all and sundry came up with 80-100 hp ideas, that's my concern now. Seems the US market has a hole, indeed, between the 30-40 HP range and 80HP upwards. Europe has _some_ offer there, but not too much and indeed each with its limitations. And we badly want information about Asian offerings, as you already pointed out before. |
Veeduber schreef: On Jun 2, 9:20 am, jan olieslagers wrote: Veeduber schreef: Lots of interesting ideas coming out. Indeed, certainly to the eyes of this non-mechanic. But few seem to answer your original search for an alternative for the VW: a light engine of 40-60 HP, typical for a single seater. Or what did I miss? For that application, the Citroen 2-cylinder aircooled boxer seems one of the rare alternatives; though it is smaller than the VW. ---------------------------------------------------------------------------- "Or what did I miss?" The Atlantic Ocean :-) OK Bob, thanks for the reminder... Still, you asked for a 40-60 HP engine and all and sundry came up with 80-100 hp ideas, that's my concern now. Seems the US market has a hole, indeed, between the 30-40 HP range and 80HP upwards. Europe has _some_ offer there, but not too much and indeed each with its limitations. And we badly want information about Asian offerings, as you already pointed out before. Rotax - 503 or 582 (618). Yes, they are two stroke engines. When installed and operated correctly they are very reliable. They run turbine smooth, and the power to weight ratio is tops. |
![]() "cavelamb" wrote Rotax - 503 or 582 (618). When installed and operated correctly they are very reliable. When installed and operated correctly they are very reliable. Say that again. When installed and operated correctly they are very reliable. Again. When installed and operated correctly they are very reliable. When installed and operated correctly they are very reliable. When installed and operated correctly they are very reliable. Therein lies the problem. When. When, When, When. Too often they are not operated correctly, partially because they are too many different ways to screw up. When goes all to hell, then. Logically then, the sentence becomes: When _NOT_ installed and operated correctly they are _NOT_ very reliable. In my opinion, no two strokes belong in any plane that does not fly so slowly that crashes into any object are not survivable. -- Jim in NC |
Morgans wrote:
"cavelamb" wrote Rotax - 503 or 582 (618). When installed and operated correctly they are very reliable. When installed and operated correctly they are very reliable. Say that again. When installed and operated correctly they are very reliable. Again. When installed and operated correctly they are very reliable. When installed and operated correctly they are very reliable. When installed and operated correctly they are very reliable. Therein lies the problem. When. When, When, When. Too often they are not operated correctly, partially because they are too many different ways to screw up. When goes all to hell, then. Logically then, the sentence becomes: When _NOT_ installed and operated correctly they are _NOT_ very reliable. In my opinion, no two strokes belong in any plane that does not fly so slowly that crashes into any object are not survivable. Now HERE'S an interesting thread. I have seen ultralights go quiet, crash and the tales of resulting dire injury. But I have no insight into correctly handling the aero 2-stroke. What constitutes "install and operate correctly." You could save somebody a whole spoiled day if you will tell. Thanks Brian W |
Brian Whatcott wrote:
Morgans wrote: "cavelamb" wrote Rotax - 503 or 582 (618). When installed and operated correctly they are very reliable. When installed and operated correctly they are very reliable. Say that again. When installed and operated correctly they are very reliable. Again. When installed and operated correctly they are very reliable. When installed and operated correctly they are very reliable. When installed and operated correctly they are very reliable. Therein lies the problem. When. When, When, When. Too often they are not operated correctly, partially because they are too many different ways to screw up. When goes all to hell, then. Logically then, the sentence becomes: When _NOT_ installed and operated correctly they are _NOT_ very reliable. In my opinion, no two strokes belong in any plane that does not fly so slowly that crashes into any object are not survivable. Now HERE'S an interesting thread. I have seen ultralights go quiet, crash and the tales of resulting dire injury. But I have no insight into correctly handling the aero 2-stroke. What constitutes "install and operate correctly." You could save somebody a whole spoiled day if you will tell. Thanks Brian W Installation and operation: http://www.ultralightnews.ca/rotax50...tionmanual.pdf Maintenance Schedule: http://www.ultralightnews.ca/rotax50...ancemanual.pdf As you said... While not installed or operated correctly ANY engine will fail. Do you think a home made engine will be any better? |
On Jun 3, 5:51*am, cavelamb wrote:
While not installed or operated correctly ANY engine will fail. Do you think a home made engine will be any better? ----------------------------------------------------------------------- It is only 'home-made' in the same sense that the Aero-Vee is home- made. And you don't have to be a rocket-scientist to do better than that. -R.S.Hoover |
On Jun 2, 11:41*am, jan olieslagers
wrote: Still, you asked for a 40-60 HP engine and all and sundry came up with 80-100 hp ideas, that's my concern now. -------------------------------------------------------------------------------------------------------------- Dear Jan, Yes. That is always the case on the internet, where the reader must sort the wheat from the chaff. The thread originated with Stealth Pilot (an Australian) pointing out the dearth of Volkswagen engines in his country or locale, leaving a hole for LOW COST engines suitable for conversion to power-plants suitable for use in home-built airplanes. He implied that a 40 horsepower engine would fill the needs of the home-builder, probably because that is about all a converted VW is good for if you want an acceptable mean-time before overhaul. I then jumped in and said this problem was not unique to Australia but would soon be felt world-wide, especially as more home-builders in S.E. Asia and China begin to stretch their home-built wings, suggesting we should try to come up with a solution in the form of an affordable engine in that power- range. ----------------------------------------------------------------------------------------------------- Seems the US market has a hole, indeed, between the 30-40 HP range and 80HP upwards. Europe has _some_ offer there, but not too much and indeed each with its limitations. And we badly want information about Asian offerings, as you already pointed out before. ---------------------------------------------------------------------------------------------------- Home-builders ere in the States are unlikely to feel there is a gap so long as the Corvair remains in good supply. Nor is their a shortage world-wide if we are willing to consider heavier, liquid-cooled engines. Unfortunately such engines are best suited for larger airframes or fairly complex biplanes, typically beyond the means of most first-time home-builders, which lead to my wondering about what engines might be available from TATA, the GM of India, or from the sleeping tiger of Chinese industrial might. I feel it is important for us to identify engines suitable for conversion and to do whatever we can to facilitate grass-roots aviation in those countries. -R.S.Hoover |
On Tue, 2 Jun 2009 19:59:09 -0700 (PDT), Veeduber
wrote: On Jun 2, 11:41*am, jan olieslagers wrote: Still, you asked for a 40-60 HP engine and all and sundry came up with 80-100 hp ideas, that's my concern now. -------------------------------------------------------------------------------------------------------------- Dear Jan, Yes. That is always the case on the internet, where the reader must sort the wheat from the chaff. The thread originated with Stealth Pilot (an Australian) pointing out the dearth of Volkswagen engines in his country or locale, leaving a hole for LOW COST engines suitable for conversion to power-plants suitable for use in home-built airplanes. He implied that a 40 horsepower engine would fill the needs of the home-builder, probably because that is about all a converted VW is good for if you want an acceptable mean-time before overhaul. I then jumped in and said this problem was not unique to Australia but would soon be felt world-wide, especially as more home-builders in S.E. Asia and China begin to stretch their home-built wings, suggesting we should try to come up with a solution in the form of an affordable engine in that power- range. ----------------------------------------------------------------------------------------------------- Seems the US market has a hole, indeed, between the 30-40 HP range and 80HP upwards. Europe has _some_ offer there, but not too much and indeed each with its limitations. And we badly want information about Asian offerings, as you already pointed out before. ---------------------------------------------------------------------------------------------------- Home-builders ere in the States are unlikely to feel there is a gap so long as the Corvair remains in good supply. Nor is their a shortage world-wide if we are willing to consider heavier, liquid-cooled engines. Unfortunately such engines are best suited for larger airframes or fairly complex biplanes, typically beyond the means of most first-time home-builders, which lead to my wondering about what engines might be available from TATA, the GM of India, or from the sleeping tiger of Chinese industrial might. I feel it is important for us to identify engines suitable for conversion and to do whatever we can to facilitate grass-roots aviation in those countries. -R.S.Hoover bang on the money Bob. Stealth Pilot |
Another home-made helicopter | Dave Whiley | Aviation Photos | 0 | November 19th 07 11:45 PM |
Home Made Helicopter | J.F. | Aviation Photos | 0 | November 17th 07 02:02 PM |
Good news for scratch builders of metal airplanes - Home Depot rents bending brakes | flybynightkarmarepair | Home Built | 7 | January 6th 07 04:22 PM |
Home made plane crashes | Bill Smith | Piloting | 0 | August 7th 06 06:07 AM |
Home made aviation websites are cool! | CFLav8r | Piloting | 2 | January 21st 04 05:31 AM |
